Question about Philips Televison & Video
My Philips TV model 37PFL9604H1 was used in the
My Philips TV model 37PFL9604H1 was used in the TV showroom, and I have tried to set it up and these problems occur:
Philips screen appears each time then
this message appears
This TV is set up for store location with fixed settings etc -Question should I press Disable or Close ?
  • ireneweepers Jul 06, 2010
    Thanks for your quick response but where do I find image settings?
    Many thanks that worked.
    2nd problem which I would really appreciate your help with and the last! After using the DVD the TV screen shows this message:
    The DV device is not connected -how do I get rid of the message? (i did play a DVD earlier that day obviously I pressed something incorrectly -can you help me sort this one out?
  • Philips Master
  • 11,800 Answers
Close, then you should go in the image settings and change the main setting from Store to Home
Posted on Jul 06, 2010
Testimonial: "Quick helpful response-in layman's terms which help!"
  • Azrael SRL Jul 06, 2010
    Press Menu on the remote, select Setup, select Install, select Preferences, select Location, select Home.
TV picture not clear
First we need to know a little more details about the kind of TV you have, the kind of service (Cable, Satellite or off Air).
Comparing showroom to your home is also something we need to know. Was the showroom using Cable or Satellite. Satellite will always have a better picture quality wise.
If you are using composite input for the signal path between TV and source this would not produce a High Dif picture Composite = Yellow for video, red and white for audio. If you are using Component source that will produce a HD signal cable is RED/BLUE and Green with different audio.
The best quality is using an HDMI cable, this is all in one cable and the sources is the best. One last thing, if you are using the RF *cable as source it will not give you a quality signal.
Apr 22, 2014 | Intellian i9P US HD System with 85cm Dish...
We have a Philips Magnavox Model #TP3284C101 TV and plugged in a Durabrand DVD Model #DVD1002 player to it. It will only play in black and white on this TV. But when we plug the DVD player into another TV...
It sounds like you have a standard problem.
Is the TV you are using, that gives the black and white picture, the same as the other ie, both NTSC or PAL and both on RGB or Y-C or S-Video?
Check to see what is required and set the DVD player accordingly.
Hope that helps.
Dec 10, 2010 | Philips Magnavox 27MS343S 27" TV
No tv channels with Philips 42FD9935/17
If you are using a Cable Box, then select the Cable Box option in the TV. If you have connected the Antenna directly to the TV, then select the Antenna option in the TV under Menu options. Try performing the Auto program.......If using a Cable Box, then no need to perform the Auto program. If the issue persists, try resetting the TV to the factory settings and check if it helps.
Jul 25, 2010 | Philips FTR-9964 Tuner/Receiver for Plasma
The TV is in what appears to be a showroom mode- it only will display a video and then a message about the TV. It won't even turn off with the power button. How can I reset the TV. Unplugging didn't even...
Hi and welcome to FixYa,
On the front panel controls, press and hold the VOL- & VOL+ buttons for 10 seconds or more.
Others with similar concern have tried variations of the above steps as posted by other members here.
Good luck and thank you for asking FixYa.
Mar 30, 2010 | Philips Magnavox MT1905B 19" TV
Hello, please help.. I have a 14" Bluesky TV set(NR BK 36 GR)but my channels had vanished and when I push the menu button on the remote control I get only the image menu (contrast ecc..) and essential...
Try unplugging the set for about 8 hours,press and hold power button for 3 seconds, wait 1/2 hour more, plug back in and see if the tv has reset itself.
Nov 10, 2009 | Televison & Video
Tv pic keeps going to vivid mode and settings. how do i get the picture mode to stay on a setting other then vivid
Yes if the TV is in Showroom mode it will do that. It is to correct for all the would-be button pushers. There is key combination to fix that on my Samsung DLP. I hope to never set and thus have to remove it. I recommend AVSforum.com and for you to find the thread on your model. Vivid is a good word as is showroom to use to search. You might try Google with KDL... and those words to search but the board is better. First check how many responses before reading all, it can run to hundreds of pages and they have their own search engine. Sorry, I could not find it in a medium search, so good luck. Calibration thread
-Ken
Aug 20, 2009 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
I need to know how to reset the tv (olevia model #lt37hvs) the tv is unable to scan the d-tv channles because of it being locked
Go to menu -picture- mode- power up - put it on home setting than all controls should be unlocked I think ur in showroom setting 99% of people who reset there factory settings get this problem
Jul 08, 2009 | Olevia LT37HVS 37 in. LCD HDTV
Screen flips to set-up screen immediately after powering up..
Go to the philips website. Download the current software onto a thumd drive and upgrade your tv. The problemn will go away. Once on the philips website, you will have to input your model number and it will explain how to upgrade your tv
May 21, 2009 | Philips 42PF7220A 42 in. Plasma Television
Sony bravia 46"
It sounds like either the remote is bad, or this TV may have a "showroom" setting to keep people from messing with th TV while it is on display. I would download the manual to see if it mentions a showroom setting, if not, try a new remote
Sep 25, 2008 | Sony BRAVIA KDL52XBR2 Television
Can I use another remote?
I have the same model TV, also without a remote. I found a Philips universal remote model CL019 at Big Lots and it works just fine. However, for some reason when I tried to program in the channels it would only program in up to channel 23, and then after about 15 seconds add channel 60. Can anyone help?
Jan 19, 2008 | Philips CCB092AT 9 in. TV/VCR Combo
Televison & Video Logo
98 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
