Question about Poulan Weed Eater Gas Hedge Trimmer
Hard to start, when it does start it cant be taken
Hard to start, when it does start,the choke cant be taken off. If you move it to run it will die.
4 Suggested Answers
#1 Taper
  • 1040 Answers
SOURCE: starts full choke dies out runs for a few min at half choke
First, you will need to check the fuel lines for cracks/breaks.
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen in the carb. is free of debris. Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. These portals can become blocked. Reassemble and start.
(NOTE: If the carburetor parts are more than four years old, and depending on the use, you will need a new carb. kit if the cleaning doesn't work.)
If you need further assistance, just let me know.
Jim
Posted on Jun 17, 2009
  • 252 Answers
SOURCE: Poulan 4218AV. I start it
hi
have you checked the muffler for restriction and ex port for blockage
have you checked fuel filter is ok and the fuel lines are ok
is the spark ok and the timming good as in the flywheellkey ?
quick test pour some 2 stroke mix through plug hole , fit plug, if fires assume compression and spark are good , the pour some 2 stroke mix into carb throat via air intake ( with filter off )
if it fires again can be pretty sure you are dealing with a carby issue or intake problem
with the latter this could mean a air leak from ie carb joint , cracked manifold block, barrell gasket , c/case joint , crank seals only way to find this out is tp pressure and vacuum test c/case with 7-8 psi of pressure and about 20 -25 inch in vaccuum
if so then i would suspect a possible air leak @ carb manifold block ( check its not cracked )or maybe the barrell gasket is leaking check the bolts are tight
then pull off the carb and check the diaphrams are soft and pliable and are not damaged
chck the fuel inlet screen it maybe not letting fuel mix through
see if this helps
cheers pauly46
Posted on Dec 09, 2010
johndoe541
  • 784 Answers
SOURCE: Put new fuel lines to carb, cleaned carb. and
Check gasket between carburator and cilinder, if ok set newly idle settings on carburator. if its ok but not helping. Maybe cranksaft sealing faulty.
Posted on Mar 19, 2011
My husqvarna 125b leaf blower only runs on full choke. If I move it to half choke it dies. I've taken the carb out and cleaned it and that didn't help.
Sounds like the mixture is out - trial and error really or take to licensed repairer they will let you know if you need a new carb or whatever is stopping it from running normal :)
Good Luck!
May 05, 2017 | Husqvarna Garden
I have a Tomos a35 Sprint and I put a 70cc cylinder jug on it, a techno circuit pipe and I have a new carb. I up jetted it to a #58 and it starts only when the choke is down, once I take the choke off it...
You need to adjust the idle 1st.Main jet #58 is just for wide open throttle. Start by turning air screw all the way in "gently" till it stops, and back it out 1 and a half turns. Back out idle screw until slide is closed " not touching slide" . Turn until just contacts slide plus 1 full turn in opening slide. Start it up with the choke on and turn the air screw slowly in or out and slowly move the choke off till you can get it to run with the choke off. Than adjust idle screw " the one that moves the slide up and down to set the RPM. If you cant get her to idle with the choke off and the carb is air tight on the intake manifold. Carb might be to big. If you can get her to idle but it runs ruff I will try to help you tune the carb further. Good luck.
Apr 24, 2014 | 2005 Tomos Sprint
Yamaha outboard engine. Model f20leha manufactured 5-2011, has about 30 hours on it. Sinse new engine is hard to start, after finally getting engine started, hard to keep it running untill engine gets...
have you left the choke open ? this mixes more fuel to the engine upon starting but will stall it if left open too long . check your fuel filter too it may be full of debris.
May 02, 2012 | Yamaha Boating
I have had my mantis for five years. It has always been hard to start. From the very beginning I had to move the choke in and out after it started to keep it from dying after it started. Each year it has...
I feel it might be time to overhaul the carburetter. Clean out all the passages and jets, especially the little screen that is pressed into a hole under the one diaphragm. Clean out the recess for the needle and seat and replace all the gaskets, the valve plate and the primer bulb. Also check the fuel tubes and the filter at the end of the intake tube (if it has one). If there is too much wear on either the choke shaft or the throttle shaft, it may just pay you to replace the carb completely.
Mar 17, 2011 | Mantis Garden
Will run with full choke on but once i turn choke off it dies
The carb jets are clogged, it will have to be removed and soaked in carb cleaner. Sometimes that will not work either, and the carb will have to be replaced. Reason is, some of the carb passages are as fine as a human hair, so it's hard to get gunk and bad/dried gas deposits out.
You could try running something called Sea Foam (mixed in the gas)from Walmart through the tiller for a while, that MAY help somewhat.
May 23, 2010 | Mantis 2-Cycle Tiller
My troybuilt yard pony riding lawnmower will start with the choke fully open and then dies immediatly when you take the choke off. It will only start and run with the choke fully open, but dies after 20-30...
Do you mean that you can start it normally using the choke (that would be choke CLOSED), but then it dies immediately when you move it to run (that would be choke OPEN)? And if you leave the choke in the starting position that it dies after 20-30 seconds?----- If I have that all right, then you definitely have a restriction in the gas supply. Drain all of the gas from the mower and don't use any old gas. If you have any more old gas (from last season) don't use it. If this mower has a gas filter, replace it. Put just a little fresh gas in the tank plus a little of the cleaner. Start it up, do that a few times if needed. Use a fuel additive such as Sea Foam to keep the gas from gumming up so fast.
Mar 15, 2010 | Troy-Bilt Garden
Last time I STARTED MY VSTAR 1100 I CHOKED IT FOR 10 SECONDS ON HIGH THEN MOVED TO MEDIUM CHOKE FOR 4 THEN TOOK OFF AT NO CHOKE. 2 WEEKS LATER. I started up bike Choke on high bike barely wanted to idle...
Sounds like your flooding it out with the choke out. Try the next time you go to start the bike when it's cold with the choke out and when it starts push the choke all the way in and keep it running with the throtle. If it runs better after doing this then your flooding it on start up. Use 1/2 choke to start cold and see what it does. Good Luck
Sep 29, 2009 | 2001 Yamaha V Star Classic
Homelite leaf blover run with choke soon when chokeis off ,cant rev up and die
if he put fuel in it dump it out & put yours in it , if problem persist there are 2 screws on the carberator turn the 1 on the right or th bottom 1/4 turn to the left!
Jun 02, 2009 | Homelite 'Yard Broom' Leaf Blower
Bike died during poker run
I would eliminate the possibility of bad gas first, considering you had just filled up. Move on to the other possibilities after eliminating the simple ones first. Battery, spark plugs, plug wires, other ignition problem, fuel delivery problem.
May 24, 2009 | 2000 Suzuki VL 1500 Intruder LC
Starts on choke but dies when moved off choke
If it will start on choke and die when choke is taken off...the carb needs to be taken off and cleaned. The main jet in the carb is probably clogged.
Apr 09, 2009 | Husqvarna 160 CC Honda OHC Engine 21 in
Poulan Weed Eater Gas Hedge Trimmer Logo
85 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
