Question about Dell E151FP 15" Flat Panel LCD Monitor
Monitor flickers, LED light starts out green and changes to amber and blinks. Connected tower to new monitor and it works fine, problem withing monitor. How can I fix it and is it worth fixing?
    Problem Solver:
  • 17 Answers
THIS IS LOGIC CARD PROBLEM,U CAN CONTRACT YOUR NEAREST SERVIC CENTER.
Posted on Jul 06, 2010
My monitor no display and light is blinking
if the monitor light is blinking this suggests that, there is no display signal coming from the tower. This could be because of the following .
1. Bad video card 2. Bad video software
To check,where the problem is , power of the system tower and remove the power cord from the back of the tower. Press and hold the power buttoon for 10 seconds and the reconnect the power cord and turn the tower on. Check if there is any display or the status of the light changes from amber to green for even a small instance.
If the light changes to green and back to amber the video port on the tower is bad
Alternatively you can connect the monitor to another desktop or laptop to check if the same is working correctly.
Thanks for using fixya
Proton
Oct 13, 2012 | Computers & Internet
My flatron L1710S flat screen will not come out of power saving mode. When I turn on the monitor the power button/light is green for a few seconds, the screen indicated "power saving mode", then...
I switch on my PC, ensuring that all cables, leads and power supplies are connected properly. The tower powers up no problems at all. I switch the screen on, the green led lights up, the screen is completely black. A blue box appears centrally on the screen with the text 'power saving mode'. The green led light turns amber and then the screen just goes black.
Please don't suggest going to control panel, as I can't get that far.
PLEASE PLEASE CAN ANYONE SUGGEST ANYTHING give me
Mar 08, 2011 | LG Flatron L1710S 17" LCD Monitor
Was watching a movie on my computer last night and all the sudden the screen started turning off and on with no picture when it was on. Has the monitor gone bad or is it a video card issue?
The simple way to check if this is a Monitor issue or not, you can unplug the monitor from the Computer and connect it only to the power outlet. If it gives you a "No signal" screen or goes through any sort of other Self test, Your monitor is fine. You can also check if the power led is blinking Amber or Green. A blinking Amber LED while the monitor is only connected to the Wall outlet indicates the monitor is faulty.
Thank you for using Fixya
Oct 08, 2009 | Dell E173FP 17" LCD Monitor
Viewsoniv VA 902 LCD 19" monitor
If the signal cable is detachable from the monitor, you could try with another cable... Regarding the power, I' not an expert, but if you're familiar with electronics basics, like risks of high voltage, soldering, etc, and you'd like to experiment with the unit, then I can give you some hints.
Mar 19, 2009 | ViewSonic VX900 19" LCD Monitor
Can't find video signal
If screen says "Signal cable not connected " all the time till power led switches to Amber chances are monitor is ok and problem is with graphic card or cpu.Connect to Known working CPU and confirm that monitor is the problem.
If same problem persists on another working cpu after changing signal cable,the interface board in the monitor could be defective.
Samir
PLease rate solution and provide feedback.
Jun 09, 2008 | BenQ FP731 17" LCD Monitor
No picture; power LED blinking amber/green 2-2-2-2...
You can TRY to look for cold solder at the board esp popwer section.
Apr 24, 2008 | NEC AccuSync 120 (White) 21" CRT Monitor
Green light blinking screen blank
Hi Suzee,
Is the green flashing on the tower or the monitor?
If it is flashing on the monitor, then it might be tht the monitor is not gettign signal from the tower.
To check, disconnect the monitor from the tower and check the monitor. If you get a msg on the screen like no input signal or check video cable, then 99% monitor is fine.
Check for the power supply light at the back of the tower.
Disconnect everything from the computer and then press and hold the power button on the comp for about 30 seconds.
Then connect the cables and check if it is working.
Jan 14, 2008 | Sony SDM-S73/B Monitor
Monitor Acer Problem
I agree it isn?t the monitor but I would suspect the video card you are connecting it to or the PC itself. Generally if a monitor doesn?t detect a video signal it will go into hibernation mode, typically displaying a no signal warning and changing the LED color from green to amber. When you start the computer is anything displaying at all? Are you sure the PC is powering up and booting?
Jul 22, 2007 | Acer AL1916W 19" LCD Monitor
Green-Amber-Amber Code?
I know that my post is very belated, but I think, will be helpfull for someone henceforth...
First of all, there is one "chronic" problem with LG monitors: solders. Check soldering of Video Amplifier IC303, Flyback Transformer, Q833( ! 210V) , deflection coils socket, Vertical IC601, XTAL X401 and so on...
In Your case, probably the cause of "green, amber, amber" lights is lack of 15V on the Verical Amplifier IC601. DPMS is activated, and monitor does not work at all, even power off.
Replacing Q912 (2SA1273) solve the problem. I replaced him with 2SA1680 PNP 1A 900mW 60V, and all is OK.
This problem is fundamental for ALL 17'' Flatron monitors, repaired by me (over 30).
Wish Happy Repairing!
Best regards, Ico.
Sep 14, 2006 | LG Flatron F700P 17" CRT Monitor
Dell E151FP 15" Flat Panel LCD Monitor Logo
113 people viewed this question
Alun Cox
