Question about Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed
Poulan Pro riding lawnmower 42" 18.5 hp 6 speed It mowed fine. Would not start when I wanted to mow again. Turns starter a little, but not enough to start. Recharged battery--same condition existed. Switched batteries and re-charged that one as well---same condition. Will make a short beginning of an engine turnover, fail to start and appear to have no battery power left. It must be the starter, but unusual because it ran fine immediately before the failure. Thanks for any input.
    President:
  • 1,033 Answers
Replace the battery. Even though the battery may say it's good, it doesn't have enough of cranking amps. Go purchase a battery with 350 cranking amps. This will fix your problem. The battery power isn't enough to kick the starter completely up to turn the engine.
Posted on Jul 06, 2010
Check for gas in piston. remove spark plug.
Posted on Jul 12, 2010
Craftsman 21 hp lawn tractor motor seems frozen
Did it leak oil & seize up
Can you turn it over by hand
Is a belt or bearing preventing the motor
from turning?
May 08, 2014 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
I have a 18.5 Poulan Pro riding lawnmower that runs fine untill I activate the blades. It then dies after mowing for a few minutes. I disengage the blades and it runs fine. Any solutions?
does it loose power then die or just shut off?does it run rough then die?try and run it with the gas cap loose th event could be plugged and the extra fuel needed to mow the vent might not be keeping up or a plugged fuel filter
Jun 06, 2012 | Garden
Poulan Pro 42" with 17.5
you need to find out if there is spark at the plugs
pull the plug put the wire back on hold it away from the engine then crank it over, you should see a nice blue spark arking from plug the engine body
If not then you need the start checking pug , wire , coil, or magneto wich ever your machine has
Jul 23, 2011 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Mow rund fine for as few minutes and then shuts off. I have replaced the coil and problem still persist.
My suggestion is to clean your carb and try again. Make sure there is no water in gas tank..
Aug 30, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Have a 2005 18.5 hp poulan riding lawn mower, wouldnt start so i replaced battery and solenoid and 20 amp fuses, startyer was checked and fine. Finally got it started and now it won't mow, blows 20 amp...
most likey you have a short . how do you ingage your blades by button or lever. if the button type look for a shorted wire . look for a bad wire some times mice get in to it and chew wires .
Apr 09, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Poulan Pro model 185H42ST dies after 30-45 minutes mowing
Put a carb kit in it. If that does not work replace the gas cap they are supposed to breath and if they get clogged it will create a vacuum in the tank starving the engine for fuel.
Apr 24, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed Logo
1,664 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
