Is there a "chip" that could go out making the remote unusable?
  • 11,800 Answers
There's only one single chip on a remote, its processor - if it goes out (usually under 2 years) then the remote is dead.
Posted on Jul 06, 2010
How do i refill my hp cartriges in my hp 8610 printer step by step.
All refill sets, come with a good description. But before you buy ink, make sure your cartridges can be filled and the chip can be reset. So you won't end with filled and unusable cartridges and dirty hands.
Look here to see how things go:
Ink Refill Kit For HP Officejet Pro 8610 8620 8630 8625 8615
Mar 29, 2015 | HP Officejet Pro 8610 Wireless All-in-One...
How do I re-program my Remote Control with automatic starter on my 2009 Town and Country Van
My experience with frequently-used vehicle remotes (any make) is this:
1. When relatively new or in good condition, if remote stops working, the button battery inside is dead or too low.
2. If battery is new, & remote still doesn't work, a solder joint on the circuit board inside may have come loose or broken.(You can try re-soldering using a low-heat pencil iron & thin RESIN-core solder -- even if you're not great at it, what do you have to lose?)
3. It's rather unusual for even an older, well-used remote to simply lose its programming.If this is the problem, it may be cheaper to buy a new after-market remote (or pair of remotes) that you can program yourself (only works with some brands & years of vehicles, so READ THE INSTRUCTIONS ON THEIR WEBSITE BEFORE BUYING AN AFTER-MARKET REMOTE), instead of going to the dealer for a normally HIGH-priced programming job.
4. Used OEM remotes that match yours exactly (check the part # of your remote & the used one you're considering) can often be purchased from a local auto wrecker (now called "auto recycler") for cheap ($5 to $10 is common), but will need programming.I always go thru the many they have, looking for one that appears new or like-new.
5. IF YOU MUST GET PROGRAMMING FROM A DEALER, usually it's the SAME PRICE whether you have 1 remote or several remotes/keys programmed at the same time.Since dealer programming is pricey, I always have 3-4 remotes and/or chip-keys programmed at the same time.(My dear wife loses chip-keys & remotes from time-to-time, so I keep a few spares on-hand.I've found inexpensive after-market chip-key blanks at some key cutters and/or auto parts stores, altho they still require programming after the copy is cut from yours.)
CAUTION
:Some OEM anti-theft systems require that ALL remotes & chip-keys be programmed/re-programmed at the same time, whether they're original, used or new.Determine this IN ADVANCE, so you know what you're faced with.The good news is that for those vehicle manufacturers, dealers normally don't charge more to program/re-program multiple remotes and/or chip-keys, if all are being done AT THE SAME TIME.
6. If all else fails & you MUST buy a new OEM remote (which will require programming), try 2 things -- First, see if the dealer will make you a package deal on buying the remote (or 2 remotes, or a remote & a chip-key) AND doing the programming for a lower combined price.Second, it may be cheaper to buy a new OEM remote from a dealer who's had one in stock for a long time & wants to blow it out (or buy from online OEM seller) & then pay the normal programming price.See the CAUTION above.
There are lots of options here, so hopefully something is useful to you.
Feb 23, 2015 | 2009 Chrysler Town and Country
Tv says unusable signal
cable , satellite connections or you have the remote set to the wrong input , make sure you are selecting the proper input on the remote for your tv .
Jul 13, 2014 | GE Televison & Video
Where is firmware
Firmware is on a chip on a circut board inside the TV. If your TV has upgradable firmware then there will be a USB port for using a flashdrive to download the new firmware. Check the the maufacturer's website for instructions and download. Caution: Make sure you are using the correct model number. Downloading the wrong firmware can make your TV unusable.
Jan 13, 2014 | Televison & Video
The red is wavy and doesn't line up
Sounds like you are trying to adjust convergence through the menu setting on your TV. Make sure you are using that TV's original remote to make these adjustments. If you are unable to make these adjustments then typically it is because one or both of your TV's convergence chips are burnt and need to be replaced. You can find these chips fairly easily but make sure you are purchasing OEM chips made by Sanyo. Sanyo made the majority of the convergence chips for most major brand rear projection TV's. You can find good quality chips at convergencechips.com. Hope this helps,James
Feb 15, 2012 | Hitachi 57F500 57" Rear Projection...
My magnavox tv was purchased in 2007, and now all of the sudden the remote won't even put the volume up or down and also can't change the tv settings with it,, it was working fine with the cable...
Most like the remote inner rubbers black dots tips of on those functions rubbers buttons are worn out and no more rubbers black dot tips left there any more to be connected make contact between the black dots tips to the remote PCB board.Or the remote CPU chip is shorted and dying,the CPU chip control everythings and remote devices are very dependent on it.Try website like Remotes.com to buy an original remote for the replacement.
May 10, 2011 | Philips Televison & Video
Remote will lock doors , no flashing lights , no chirps , led never comes on. remote will not unlock doors.l
take apart the remote and make sure the chip board is clean and no dirt between button and chip board, re assemble and test
Jan 20, 2011 | 2004 Honda Element
We just? replaced the cyan toner with a OEM cyan and two days later it says it needs to be replaced again
A lot of printer cartridges have microchips which make them unusable once the machine believes it to be finished, mainly to discourage refilling. maybe the chip has malfunctioned or the cartridges were used already and refilled or something. there are chip resetters , perhaps you should speak to the supplier, they may refund or replace or reset the chip for you.
Dec 20, 2010 | Konica Minolta magicolor 4650DN Laser...
Hi it appears the IR sensor for my Toshiba has gone, it started intermittent then became unusable. To make matters worse I have locked the front keys as I have a baby who loves to press them. TV now...
i think that your remote control is faulty , change it because you cant unlocked your tv menu without remote control, check the battery and clean it properly
Nov 06, 2010 | Televison & Video
Piva ptv1502 screen keeps cutting off while playing can you fix problem?
If it's a V-Chip, Parental Control issue, here's the solution. Make sure RF coaxial cable is connected to TV. Press "V-Chip Menu" on the remote. On Password, press "Enter" on the remote. In Password, enter 666666, then press "Enter". Scroll down to "Modify-PW" by using CH+ or CH- key, then press "Enter". Enter 000000, then press "Enter". Select" V-Chip Menu" to exit V-Chip. Select V-Chip Menu again. On "Password", press "Enter" key on remote control. Enter 000000 in "Password", then press "Enter". Scroll down to "V-Chip", press "Enter". TV should display a list of all TV ratings. Use CH+ or CH-, scroll to TV-Y. Then press "Enter" key on remote. Be sure that all ratings are set to "On". Repeat the steps above and set all ratings to "On". Then select "Exit", press "Enter". Press V-Chip Menu" to close on-screen menu.
Oct 30, 2008 | Televison & Video
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
Electro Med Services...
