Question about Canon imageRUNNER C6800 Copier
Error code E000006-0001
I have an intermitent E000006-0001 Code primarily when the printer boots up. Sometimes it will get to print its boot-up page but quickly errors out and stops working. Once in a blue moon I can get about 50 prints from it before error strikes. Canon manual seems awfully vague about this issue, need help bad! Home business relies on this machine and can't afford another right now. Good level of tech ability if guided on corrective solution. Please help.
    Genius:
  • 1,142 Answers
Please give the model and the make
Posted on Apr 18, 2008
  • 1 more comment
  • Maanita Chadha
    Maanita Chadha Apr 18, 2008
    Try resetting the printer to the factory settings and after that do a flea power, to do flea power is to unplug the power cable from the printer and then push the power button on the printer for 40 seconds and make sure the power cable should not be connected i mean no power to the printer, this will release the static power of the printer and then you can turn the printe to the normal mode and connect the printer communication cable too. This should resolve the issue.
    Please let me know the status
    Regards
  • Tiago Oliveira
    Tiago Oliveira Oct 29, 2017
    oi Boa Noite!estou com esse mesmo problema, erro: E000006-0001. me ajuda a resolver. Por favor!
  • Tiago Oliveira
    "me ajuda"
    Genius:
  • 3,422 Answers
Did you try to reset the boot rom? Try reinstalling the software too.You can also try to reset the HD connections.
  • Priya darshan Apr 18, 2008
    The error 006 means that for any number of reasons when the copier went
    to boot" (begin to start up and read its directions as to what it is,
    who it is, and what it is capable of, it failed to get the instruction
    set (or failed to recognize the instructions) and therefore said
    "what"?!) as the copier sought to retrieve this info from the hard
    drive.That can mean that the partition of the hard drive that is was
    looking at contained corrupt information, or there was a communication
    interruption, or that the hard drive is going or gone bad.
    If the solutions which i told you doesnot help then you will have to call a tech to get it fixed
    Goodluck,
    Please don't forget to rate the solution
Service error 4cf0 hp 4700
Try removing the JetDirect card, then see if the machine will boot and print a test page. If it works without JetDirect, then try replacing the JetDirect card.
Oct 15, 2014 | HP LaserJet 4700 Printer
I am getting error 94,7000.00:114.36 on my Xerox 8570 Printer. It sounds like a lot of spinning on the maintenance kit when I boot it. Any suggestions?
You need to reset the inital alignment of the printer.
This process its perform at the start of the machine.
If u need the service manual
mail me at; impressaodigital.poa@hotmail.com
Sep 12, 2014 | Xerox Corporation Xerox ColorQube 8570DT...
I'm getting error 94,7000.00:114.36 on my Xerox 8570 Printer. It sounds like a lot of spinning on the maintenance kit when I boot it. Any suggestions?
The error is a Process Drive Fault. This may be a problem with the Process Drive's Gears.
You probably need to go through the replacement procedure again.
Xerox says to check if they are in their home positions. NOTE: Usually, manually tilting the head back and forth using Drum Maintenance Shaft should leave the Process Drive aligned.
HP laserjet m3027 error code 49.4c02
if this error shows up with no network card installed, you have a bad `fomatter' board.
Apr 03, 2014 | Office Equipment & Supplies
Error code c-4501
replace the print head which houses the LASERS. located under the drums as one large assy.
Mar 16, 2014 | Konica Minolta Bizhub C550
Printing check error code 7224
Using Quicken Premier 2009 on Windows 7 x64 with HP OfficeJet 7310.
My check wouldn't print and was booted out of Quicken. Validated data (was OK), reinstalled Quicken Premier 2009 (per instructions above), checked printer and driver (was-OK), I still could not print checks (error code 7215 and quicken closed).
SOLUTION: I deleted the transaction I was trying to print, the re-entered it. It printed fine.
Feb 13, 2010 | Intuit Quicken Premier 2009 for PC
PDF documents do not print completely on my Xerox Phaser 8500
I am having the same problem. Sometimes my Xerox Phaser 8500 prints a PDF or web page fine, and other times I get pages and pages of what looks like PostScript code. I thought I had installed the most recent printer drivers, We are using primarily Macs with OS 10.4 or 10.5. One recent change is that we connected the printer to an Airport Express using a USB cable, which is sweet when it works correctly....any ideas???
Jul 14, 2009 | Xerox Phaser 8500/DN Printer
Dell 1700n error light after print job.
double pressing the continue button twice , the printer will give a secondary error code: then check here (link below) : toner is low, with blinking lights = Replacing the Imaging Drum
http://support.dell.com/support/edocs/systems/1700n/en/index.htm
download the manual above and look under Troubleshooting->Maintenance for your printer-> replace imaging drum...
good fortune, please leave rating...
May 11, 2009 | Dell 1700n Laser Printer
Error code 59.40 on laser jet 4250
Do you mean an HP 4250. If memory serves me right that error number refers to the main drive or cartridge drive. You may have broken the gear on the cartridge while installing it. Especially if your the type to slam it in there. It can happen with genuine and remans so don't go bemoaning reman cartridges...lol. Turn it off...put another cartridge in there...and see if if boots up. I work on printers for a living and had( I'm 95% sure ) that same error code a couple of weeks ago and fixed it for the customer over the phone this same way.
Mar 24, 2009 | Office Equipment & Supplies
Canon imageRUNNER C6800 Copier Logo
914 people viewed this question
old marine
old marine
