All the swiches got damaged. The TV is not clear. what should I do ?
  • 901 Answers
Remove the PCB & replace all the button switches one by one with new one. If switches have contact resistance it will mis- behave. It will go random selection. Switches have two way contacts.
Posted on Jul 06, 2010
STOP TV FROM TURNING OFF AND ON
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Dec 24, 2014 | JVC AV-20220 TV
No power to my TV when I switch on
It sounds that the main power supply regulator board inside the TV has damaged. You surely must contact any service technician.
Jul 24, 2013 | Televison & Video
Sony 14 inch tv have no power when its swich on
Check and replace damaged component/s in its main power supply regulator section circuit. Contact any experienced service technician.
Oct 10, 2012 | Jensen TS2750J TV
Video 1 illumination wont shut off.
There is trouble in the video swithing Ic inside your Tv. Either it may got damaged or video swiching voltage may not come to it from system ic. If the video swiching Ic is damaged, it is easy to replace and get the set repaired. If the System Control Ic is damaged it will cost more and may need retune it after replacement and giving its remote service code for further adjustments. You just call a technician and consult him about the matter.
Oct 16, 2010 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sound on tv went out. model jvc hd-56g886. Checked mute buttons etc
Hello
You just hold your ears very near to the speaker side, and swich on the tv. If you hear a "thumb"; sound, the output circutary of your tv has some trouble; provided picture is Ok. If there is no "thumb sound", the speaker of your tv must be suspected.
Normally output Ic may get damaged. This will happen to most of the telivisions.
Oct 15, 2010 | JVC Televison & Video
Sony KV-32FS12. Buttons on the TV don't work, the remote don't work. Now stuck in one channel. Can access Menu with TV button but can't go anywhere. Unplugged from main power source still no go. Tried...
Hello
Your TVs front control buttons are inoperative except menu button. There are microswiches fitted inside the main board of your tv from which shafts ar extented towars the front of the cabin where you press to access the functions. Replace all the micro swiches inside at onetime. It won't cost more. Micro swiches as they have said is mini swiches, which can get damaged easly with high pressure thumb or impact put on it.
Oct 15, 2010 | Sony KV-32FS12 32" TV
Standby light is flashing and i acnnot turn the telly on. Whats the problem?
Issue with Power Innitial Logic Board Relay wont Clik On Due To Damage inside TV... Exemple.. Lamp Projection Burnt Out.. Overheat Component ... All TV Got a Automatic Security Power Off Swich It prevent serious damage insite TV..... Please Refer to a Certified TV Repair Your TV need to be fix ..good luck
Oct 07, 2010 | Televison & Video
32" xenius tv: No power after switching on and off by the wall, can you help?
Check Power On Outlet Wall Unit Plug Lamp into Wall Outlet See if you have Power.. If Yes... Check on the back of you tv set look for Fuse Panel Check Fuse if it burt out.. If No . Issue with Main Board Pannel Inside Fail To Innitiate To Pre Start Logic Relay Security Swich To Avoid serious damage inside TV...Please Refer To Certified TV Repair... Good Luck
N73 camera switch problem
n 73 camera swich not working problem plz help me
Aug 24, 2009 | Nokia N73 Cellular Phone
How to swich to TV I don't know how to swich from home theaater DVD to normal TV !!
Should be an "input" or "source" selection on either the HTS or the TV. Need to change it to the one that you have the cable/satellite connected to.
Jul 05, 2009 | Sony BRAVIA® DAV-HDX576WF Theater System...
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
