Question about Tunturi T60 Folding Treadmill
T60 treadmill came up with lift motor error so switched off. Now when I switch on it displays autocalibrating but never gets any further. Can you help?
Power off, put in the key, press and hold down the stop button and incline up buttons, power on holding down the buttons for a few seconds - message clears
Posted on May 15, 2011
E6 error message
It appears that your elevation system is where the fault lies. This could be as simple as recalibrating the lift mechanism, or possibly correcting faulty wiring from the lower controller to the lift motor. Be sure to check the condition of the lift motor as well as the wires entering the lift motor. Sometimes the wires will pull away from the plastic connector causing a lift motor error
Mar 11, 2014 | Dmm Vision Fitness T9500 Treadmill
E2 error lift error
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
You have posted this question in the Stair Climber section, but the error you are listing is a treadmill error code. The following information should help.
Probable Cause A) Incline control error.
B) Insufficient power source.
C) User exceeds weight limit.
D) Unit will not lift.
E) Unit thinks it is always at 0% incline and only lifts up.
F) 3 amp circuit breaker has tripped.
G) CPU board has stuck relay.
H) Lift motor is faulty.
Corrective Action A) Access the incline manual mode in diagnostics by pressing 9, 1, 9, ENTER and then pressing HILL program key. Incline the unit with two people on the unit. B) Ensure treadmill is connected to a dedicated 120V, 20 Amp circuit.
C) Advise user of unit's weight limit of 300lbs (137kg).
D) Perform the lift test procedure by pressing 9, 1, 9, ENTER and then pressing HILL program key.
E) Inspect the home switch for smooth operation and inspect the wiring of the home switch for damage or poor connections. Inspect the lift motor cable connections and for the presence of the suppressor board (should only be 1).
F) Test the circuit breakers and replace if necessary.
G) Replace the CPU board.
H) Replace the lift motor.
LifeFitness 9500 Treadmill Lift Control Error
Jul 31, 2013 | Life Fitness Exercise & Fitness
Precor usa treadmill c962i error 41
Precor Error 41, Lift has not Responded in Acceptable Time Probable Cause Error 41 was present in early software versions and is no longer being used.
Corrective Action If you encounter a unit that has software with an error 41, diagnose the same way you would if getting an error 40.
Precor Error 41
Precor Error 40, No Lift Motion Detected Probable Cause 1. Blown lift fuse in lower PCA.
2. Lift motor is physically jammed and not able to move.
3. Bad lower PCA.
4. Bad lift capacitor.
5. Bad lift motor winding.
6. Bad interconnect cable between upper and lower PCA.
7. Bad upper PCA.
Corrective Action
  1. Check the lift fuse from the lower PCA. Using an ohmmeter, the fuse should measure 1 ohm or less. If the reading is significantly high, replace the fuse. If the fuse is open, refer to steps 3 and 4 before continuing.
  2. Disconnect the lift motor from the ramp (elliptical) or lift platform (treadmill). If the lift nut or lift tube is jammed against the motor housing, turn the lift tube or lift nut away from the motor housing. If the lift was jammed, refer to step 3 before continuing. Calibrate the lift motor per the proper procedure for the unit being serviced and reattach the lift motor to the ramp (elliptical) or lift platform (treadmill). NOTICE: You must find and repair the cause for the jammed lift. Only re-calibrating the lift motor will not solve the problem.
  3. One of two modes can cause the lower PCA to fail. The lift switch could fail in an operated condition. If this happens the lift will move (either up or down) as soon as the unit powers up. The usual result is that the lift will be physically jammed as explained above, and probably also being cause for the lift fuse to blow. The lift switch could also fail in an open condition. If this happened, the lift would not operate in one direction. If either of these conditions occur the lower PCA needs replaced.
  4. Most units have the lift capacitor mounted inside the lift motor, and others use external lift capacitors. This information applies to units with the external lift capacitors. If the lift capacitor is shorted the lift fuse blows. Check the capacitor for a short using an ohm meter. Disconnect the capacitor from the lift motor and test. A good capacitor reads in the millions of ohms. Replace the capacitor if the reading is significantly low. Capacitor can also fail in the open condition which would result with the lift motor trying to run but not having normal power. Test the capacitor by measuring AC voltage across it. A good capacitor will read AC peak voltage while an open capacitor reads AC RMS voltage.
  5. When a lift motor winding is bad the lift will not operate in one or both directions depending upon the exact fault in the motor. Check the lift motor winding with an ohm meter. AC lift motors have a split winding (3 wires) and DC lift motors will have a single winding. Both windings must be checked on an AC lift motor. Normal winding readings could vary anywhere between 1 and 60 ohms, depending on the lift motor being tested. See the proper service manual for the motor being tested.
  6. Test unit with a known good interconnect cable. Replace the interconnect cable if necessary.
  7. Test unit with a known good upper PCA. Replace the lower PCA if necessary.
Precor Error Code 40
Jan 23, 2013 | Precor C962i Treadmill 220V
I have a tunturi t60 and it as stopped working and says data transfer error on display
Dear Sir:
LUBE inmediately the machine, the problem is lack of maintenance, maybe you have deck belt worn, that produce enough friction and by consequence shut down the machine.
2) Lube the rollers bearing in according with the instr.manual schedule.
3) Measure the voltage motor, if there are voltage the motor need repair or replace.
4) Test the output voltage board, for input voltage motor, if there are NOT voltage the board is faulty.
5) Run the software calibration for diagnose, and troubleshooting.
See my personal tips for help.
sincerely. God bless you.
May 07, 2012 | Tunturi T60 Folding Treadmill
I have a fitnex t60 treadmill it says prg bad what does that mean and how can i fix it
You have probably mechanical-electronic problem.
1) Adjust the sensor Reed switch. see the diagram 1/8"-3mms
2) Tight the flexible cable or connector between the keypanel and PDisplay board, and clean for dust.
3) Finally you must test the power supply for +5Vdc for I.Circuit(Including EPROM, ROM, etc).
4) The power supply is coming from Lower Board calle PController Motor, the supply the +5vdc, from the power supply coming from the Transformer controller.
Finally you must concluded if the problem is the Display Board or Main Motor Board. Sincerely.
Nov 21, 2011 | Fitnex T60 Light Commercial Treadmill
Prg bad on fitnex t60 treadmill
You must have some mechanical and electronic problem:
1) Adjust the Sensor switch by 1/8" or 3mms see the diagram. after you did Test again.
2) Check the flexible cable between Keypanyel and PDisplay Board and clean and reconnect it for loosen and dust.
3) Finally you must Test the power supply +5vdc for I.Circuit coming from the Main Controller Motor that supply the Vdc, of course you must Test the Transformer Controller. If the problem persist, you must concluded that PDisplay board is fault, after you see first if the power supply is present in the Display Board.
My Tunturi Treadmill ramp is stuck in the top elevation position and will not run. I get a "Auto Syncing" message, but the machine will not run. Have tried unplugging etc, but it will not exit the mode...
Enter the testing mode after switching the treadmill POWER ON by pushing first ‘SELECT’ and then ‘SPEED DOWN’ and hold buttons pressed simultaneously.
LED scanning mode for verifying display functionality Press ‘ENTER’ to scan DATA LINES to verify display functionality Press ‘ENTER’ to scan SACN LINES to verify display functionality Press ‘ENTER’ to scan LED’s to verify display functionality After pressing ‘ENTER’ the TIME window shows “test” and the keypad functionality can be tested (the value displayed changes when a button is being pressed) Press ‘ENTER’ to enter IO mode (TIME display shows lift motor potentiometer value, SPEED reads speed from speed sensor and DISTANCE shows heart rate pulse) Press ‘START’ to test lower board relay (a “click” sound) and then press ‘ELEVATION UP’ for 2 seconds to increase the elevation to 8%. Press ‘ELEVATION DOWN’ to decrease the elevation to minimum percentage 0% Press ‘SPEED UP’ to increase speed value and ‘SPEED DOWN’ toto decrease speed value. Press ‘ENTER’ to repeat above test or ‘SELECT’ and ‘ SPEED DOWN’ buttons simultaneously to return to the normal mode
The lift motor calibration is done manually by following the following steps: 1. Drive the lift motor to 0% from user interface (inclination display must be 0%) 2. Switch off the treadmill and unplug the power cable 3. Remove motor cover 4. Fold up the running deck 5. Loosen two screws (A) attaching the lift motor nut (B) to the incline frame 6. Adjust the lift motor nut (B) so that there is 9 mm (.358 in ) gap between the upper end of the nut and the lift motor frame Tighten the screws (A) and verify correct elevation by measuring Adjusting lift motor to 0% position 2.76in 12% position 9.646 in measurement taken from floor to bottom of motor compartment frame.
Jun 11, 2010 | Tunturi T30 Programmable Treadmill
Lift motor overload
" Turn the power switch off, wait 1 minute and turn the power switch on again. If treadmill recovers to normal operation, you may continue to use the treadmill.
The lower board software contains a protective current measurement, should the limit exceed, it will give the ’lift motor overload’ -error. Try calibrating the lift motor and if not successful. Unplug unit remove motor shroud locate the lift motor. The lift motor driven nut is never supposed to reach either of the ends of the lift motor screw. Should this happen, the nut is likely to get jammed. Check that the nut is not against the motor frame nor against the stopper in the end of the motor screw. In a case like this the lift motor needs to be removed and the nut released by hand.
May 15, 2010 | Tunturi T60F T60F Series Treadmill
Lifefitness TR 9000 treadmill - 1997 model
Because you are hearing the lift motor making a noise, it sounds like the gears in the motor are bad. The fix is to replace the lift motor.
Apr 28, 2010 | Life Fitness 9000 Next Generation...
Err 22 keeps displaying on control panel on one treadmill and on another err45 ..... Any answers? Plus some treadmills same to just trip, have to keep switch them back on!
Error 22 indicates that the drive motor (running belt) has been instructed to start, by either manual or program control, and the monitoring system has not received any response from the speed sensing system indicating that the drive motor has started
Possible Causes 1. The treadmill utilizes an optical (infrared) speed sensor and the line of sight between the speed sensor and the speed sensor target is obstructed. 2. Drive motor brushes are bad. 3. The speed sensor position relative to the speed sensor target is incorrect. 4. The speed sensor potentiometer adjustment is incorrect (when equipped). 5. The speed sensor is inoperative. 6. The lower PCA is bad. 7. The lower PCA to upper PCA interconnect cable is bad. 8. The upper PCA is bad
Error 45 :The lift control system has detected that the lift is moving in the opposite direction of the issued
Possible Causes 1. Lift Motor hysteresis. 2. Bad lower PCA
Possible Remedies 1. This error would typically happen when the lift was already in motion (typically downward) when a lift command in the opposite direction (lift up) was issued. Some motors exhibited a very long turn around time and the lift motor would still be moving in the original direction (downward) while the control system was attempting to move the lift in the opposite direction. If the error 45 condition is persistent, replace the lift motor. 2. This is a very rare condition, if the lift moves in the opposite direction of the issued lift command, replace the lower PCA lift command.
Feb 02, 2010 | Precor C954i Commercial Treadmill
Tunturi T60 Folding Treadmill Logo
532 people viewed this question
Top Tunturi Exercise & Fitness Experts
Electro Med Services...
Shehu Pro
Shehu Pro
Are you a Tunturi Exercise and Fitnes Expert? Answer questions, earn points and help others
