Question about Pyle PLTTB1 Turntable
I have a pyle plttb1 and i have connected with the equlilazer and did not make any sound and after connected directly with the amplifier and make some sound but very low
    Brigadier General:
  • 8,546 Answers
Just a guess - traditional turntables require a specific PHONO preamplifier to boost and frequency-shape the phono catrdige's tiny signal prior to sending it to conventional Line Level inputs. Get one.
Posted on Jul 06, 2010
How to daisy-chain my Pyle amplifier with my KLH amplifier
as u do not state models here goes:
one or both amplifiers could have a stereo rca output, connect the output of the amplifier that gets signal from the head unit to the input of the other amplifier.
DO NOT share ground cables or power from one to the other (these cables should both run separate from a distribution block AND not from one amp to the other,
........do not connect both amplifiers to only one driver.........
hope this helps, let me know if you need more assistance.
....andy...
Jan 06, 2014 | Pyle Car Audio & Video
Does the blue wire need to be connected to 12 V + . if I have no accesories, can I just leave this wire disconnected? thanks!
The subject shows this referring to a Pyle car amplifier. Is that the case? Either way this will hopefully answer your question.
If you're talking about the blue wire from an after market car stereo and:
  • There's no accessories (as you've already stated)
  • You don't have a power antenna
  • and you're not running an amplifier
You can leave the blue wire disconnected.
If you have a power antenna it'll need to be connected to the corresponding wire in the dash (I would need to know year make an model of the care to help you identify that wire). If you have an amplifier the blue wire would be run directly to that.
Hope this helps. Let me know if you have any questions.
Thanks,
Ray
Jun 16, 2011 | Pyle Car Audio & Video
When i hook up both speakers it quit maken sound bt if one is hooked up it works why
are the earth connections round the right way?
try connecting the speaker wires the other way round, usually if the earth and possitives are wrong way round, it will cut the sound
Apr 06, 2010 | Pyle PLA2200 Car Audio Amplifier
What size amplifier to I need to operate a Pyle Driver Pro 15 inch subwoofer? It is hooked to a 200 Watt amp and there is no sound coming from the speaker?
You may want to check ALL the connections and make sure you are connected properly. You SHOULD surely hear a lot of sound even with such a small wattage amp. Blown speaker? Blown amp? Have them tested. Also the REM or remote line on the amp is a overlooked wire.
Feb 22, 2010 | Pyle Car Audio & Video
Trouble connecting marine amp to stereo
Hello lizskates814,
You can use either the high level (speaker) or the low-level (RCA's) inputs to the amp, but not both. Choose whichever one sounds the best or is more convenient to install and leave the other disconnected.
Hope this helps.
May 23, 2009 | Pyle PLMRA400 Car Amp
Can not get power to my pyle amplifier
Usually On Car Amplifiers, there is a Connector/Wire called "Remote On".
This is where Headunit supplies 12V to trigger the Power on the Amplifier.
(Of course, head unit usually has Remote Wire also in order to turn the Amplifier on).
If this wire is properly connected and still does not turn on, then try to supply 12V directly from the battery. If it turns on then your head unit has problem, If it does not turn on then your Amplifier has problem.
Jan 27, 2009 | Pyle Audio Players & Recorders
Wiring troubleshoot
Make sure that your car is not amplified!! Some Celicas have an amplifier under the passenger seat. If this is the case, you will need to either bypass that amplifier and go directly to speakers, or you'll need the proper interface plug. The extra rapid heat build-up indicates that your radio is incorrectly wired (channels are mixed up)
Your Pyle radio may have an extra wire for "amplifier turn-on" or for "mute". A standard wiring harness for Toyota (Scosche part TA-02B) should work in dash behind the radio in non-amplified vehicles. If you are still having difficulty, please seek advice from a local stereo installation shop.
Aug 10, 2008 | Car Audio & Video
What is wrong with my system
wiring may not be the problem but try connecting each coil to separate channel and make sure polarities are correct.
Aug 08, 2007 | Pyle PLA2200 Car Audio Amplifier
Pyle PLTTB1 Turntable Logo
96 people viewed this question
Top Pyle Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Are you a Pyle Audio Player and Recorder Expert? Answer questions, earn points and help others
