Question about Bosch Washing Machines
Bosch axxis washer does not spin; stopped spinning. It worked well for about 8 years, but always had a weird noise, since the machine was brought from the store; my guess is that some piece that kept being hit/touched and made that noise finally broke; a blue print of the machine inside would be very helpfull.
  • Bosch Expert
  • 414 Answers
If you go to BSH home appliances website and follow link to spares you can put in the model number (Enr should start with a W. example WFL2065gb/01) and get the part diagram. I would imagine that it would be the brushes on the motor, there can be replaced but remeber to clean the armiture (copper below where brushes touch in position) lightly with a very fine piece of glass paper. you have said it is not spinning but do you really mean there is no motor action. ie not doing slow turns on the wash cycle? If only not spinning it could be a drainage problem. Hope this helps.
Posted on Jul 06, 2010
Brand-new Bosch Axxis washer not working (3 lights on the control panel blinking together)
It has at least a year warranty don't mess with it call the seller. Manual should have error codes.
Dec 18, 2017 | Washing Machines
Bosche axxis washer spin cycle ticking noise
Assuming everything else is working normally, I would still suspect there is an object that is getting stuck between the rotating drum and the outer housing. Maybe not coins, but something longer, like a pocket comb or the wire inserts used in some garments. It is easy to take the top off of the unit, and this might help to isolate the noise better. Early spin is usually a bit unbalanced, so it is possible it could also be something really simple like a hose clamp that has sagged enough to be contacting something else, and it only shows up when the machine is bouncing a bit.
Mar 16, 2013 | Bosch Washing Machines
Machine is not spinning
check the carbon brushes in the motor or the belt.if its not these then it may be a timer fault see if you have power to the motor
Jun 02, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Washing machine makes a noise (like rocks tumbling) when machine is draining water
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 15, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Vibration on spin
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
Washer Problems Washer noise when spinning
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
May 04, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Doesnt spin on spincylce and just makes a rattling noisewff1475 bosch
The rattling noise is probably something in the pump.
If it is not draining properly, this will stop it spinning.
Check pump filter, if clean, then I would suggest you check the brushes in the motor for wear, as badly worn brushes will also stop it spinning.
Please rate my solution.
Thanks.
Nov 18, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Bosch axxis washer fills door locks then nothing no agitate or spin it dose drain when the control is set to spin
The timer/controller is faulty.
Replacement is the only fix.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 25, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Axxis WFL 2060 Front Load Washer--Tub won't move
what a bogus website you are. you offer no free support and you should say so
Jul 12, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Axxis front loader will not drain
check filter. check no foreign objects fouling pump impellor - bra wires are the favourite
Apr 25, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Washing Machines Logo
222 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
