Question about Hitachi 55HDX99 55 in. Plasma HDTV
Hitachi 55hdX99 shuts off and turns on by itself repeatedly
Once the TV is turned on either via remote or button on the TV, it is on for a few seconds then shuts off, then turns back on after a few seconds. It will continue this repeatedly until you shut it off again. Remote only activates volume or power. INput button works for a second then TV shuts off again, and on then off, etc... I think its the internal power supply but don't know for sure or where to start.
  • Anonymous Jul 31, 2017
    sounds like a very similar problem which has just started on my LCD. Looking forward to viewing any suggestions
SOURCE: TH ETV TURN OFF ITSELF
the cooling fan could be going out
Posted on Dec 14, 2008
ginko
  • 19396 Answers
SOURCE: HITATCHI ULTRAVISION P50S601...POWER LIGHT BLINKING...WONT COME O
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on May 22, 2009
  • 188 Answers
SOURCE: Hitachi TV volume won't work
Is the set in hotel mode?
Posted on Jul 24, 2009
SOURCE: Hitachi P42H401 turns on then shuts off seconds later
its most likely the common hitachi fault....its a little resistor that burns out, it happened mainly on the old crt tv's. any tv repair shop should be able to sort it for you.
Posted on Aug 28, 2009
  • 1456 Answers
SOURCE: Hitachi 55HDX99 55 in. HDTV
Hello
Check the settings on your external devices,check the settings on the devices you are having a problem with. For example, if your Blu-Ray player is outputting to 1080p but your television supports a resolution of only 720p, this could cause the audio and the video to slip out of sync.
Try different inputs. If problems persist with external devices, plug them into different ports. The problem may be a bad input rather than a bad TV. Replace cables to make sure that isn't the problem.
Check the settings menu. If the image on your Hitachi TV looks too dark or too washed out, adjust the picture settings in the television's main menu. Sometimes the factory settings on a Hitachi TV aren't in line with the needs of the user
If this does not solve the problem,Press Menu Button, then in sequence 4, 7, 2 and 5.You are now in the Service Menu
Goto Options and press Factory Reset, it will only take a couple of seconds
Press Escape, Standby and Unplug from Mains Leave for 5 mins and turn all on again
If the problem persists, Open your TV and find PSB. (The board that the power cord plugs into) Check for faulty caps. If you find some (bulged or leaking) bad caps replace the entire board. They can be found online.
Remove and then replace individual faulty caps. This takes some soldering skill.
Caps are inexpensive and if you can take care of it yourself it will save you hundreds.
NOTE; If your tv is still under warranty,do not open the tv as this may void warranty.Best option will be to send the tv back to the dealer for replacement.
Posted on Dec 22, 2010
I have a Samsung Plasma PN63A650 that has worked 4 8 years, until today. I turned it on, stays on for 14 seconds, then turns off for 8 seconds. Would not respond to remote commands either
Easy fix for new Samsung TV switching on and off power ...
? 4:41
https://www.youtube.com/watch?v=H0cG3lzjuw8
Sep 15, 2012 - Uploaded by alwaysafix
My tv turns on and off by itself the minute I plug in the cable. ....Samsung E6030 led tv hv blinkin red light issue ... capacitors are looking good ...
Help PLEASE! Samsung Plasma Turning On/Off Repeatedly.
michiganstate.247sports.com > Topics
247Sports.comMy Samsung Plasma HDTV (approx 3.5years old) has some issues as of late. When Iturn the tv on, invariably, it starts to turn off and back on repeatedly.
Samsung Smart TV turning off - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I have a Samsung plasma 60 inch model number PN60E6500EFXZA TV. It began to turn itself off every 5 minutes, for the past few days. I was able to factory ... Samsung TV Keeps turning off and on.
Jun 11, 2015
Samsung TV Keeps Shutting Down
Jun 11, 2015
Samsung Plasma TV turns off by itself
Jun 22, 2011
My Samsung 50 in PN50B650 turns off by itself then on again ...
Apr 30, 2010
More results from www.cnet.com
Jan 13, 2016 | Samsung Televison & Video
I lost the manual I need instructions to program it
Manual Programming:
1. Turn on the device with which you want to use the remote control.
2. Locate a 3-digit code for your device.
3. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) for approximately three seconds unitl the POWER INDICATOR illuminates.
4. Enter the 3-digit code for your device within 30 seconds. The POWER INDICATOR shuts off.
5. Press power button to verify correct code entry. If the device shuts off, the code was entered correctly. If the device does not shut off, repeat steps 3-4, using a different code.
Automatic Programming
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device.
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control(TV, VCR, SAT, DVD, CAB or AUD) until the POWER INDICATOR illuminates. The remote control is in programming mode.
3.Press and release power button. The POWER INDICATOR flashes once and stays on
indicating the unit is in Power Scan mode.
3. Press CHANNEL UP or CHANNEL DOWN repeatedly until the device turns on.
4. When the device turns on, press OK to store the code.
5. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Thank You
Sep 12, 2010 | Hitachi VT-RM294A Remote Control
I DROPPED MY REMOTE AND THE BATTERYS CAME OUT AND NOW I CANT TURN THE CHANNEL SO I NEED TO KNOW HOW TO PROGRAM MY REMOTE
Hi.
Manual Programming:
Thanx
Jul 29, 2010 | Hitachi CLU-5713TSI Remote Control
My TV remote comtrol will not work when I try. I need the code.
Hi.
Manual Programming:
Codes for orion TV are
096,10,146
Thanx
Jul 27, 2010 | Brookstone 538744 Remote Control
My hitachi plasma tv model: p55t551 every time i
turn tv on the red power light comes on then goes off again
Jun 27, 2010 | Televison & Video
Trouble Finding Code
Have you tried the code search option:
Programming a Device using Code Search:
  1. Manually turn ON your device (TV, VCR, Cable Box)
  2. Press and "HOLD" CODE SEARCH
  3. Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
  4. Release CODE SEARCH.
  5. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
  6. Once the device turns off, press and release ENTER.
  7. With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Have you also tried the other daewoo codes -
Daewoo 011,019,027
Nov 25, 2008 | Hitachi C1424T 14" TV
Hitachi 55HDX99 55 in. Plasma HDTV Logo
66 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
