Question about Smeg SE399X/5 Stainless Steel Electric Single Oven
When i try and switch oven on, the light to say the oven is heating, does not come on and it does not get hot. Grill and fan work just fine. On your website i found someone who had the same problem and It was the hi limit switch, to reset it. How do i access it? I have a SMEG SA410. Thank you
  • fraa2111 Jul 06, 2010
    Yeah I already saw this solution and thats what I'm trying to do but I can't find "the six screws on the black panel above the oven opening". Is it because it's a different model?
  • 1,284 Answers
Hi, to access it, open the oven door and remove the six screws on the black panel above the oven opening. Pull out the black metal shield in the center. Toward the back of the exposed parts in the center is a black round component with a red button in the center. This is the hi limit switch. The red button is the manual reset button. Press this in to reset. Note that it does not press in easily - you really have to press hard until you feel it click. That does the trick.
Take care
Posted on Jul 06, 2010
  • Shehu Pro
    Shehu Pro Jul 06, 2010
    Yes, maybe because it's a different model, try looking for screws, they may be up to or more than six screws.
    Take care
My cooker won't heat up
remove the rear panel covering the fan (4 screws) from inside oven. The element is round the fan. you may see where the element has burnt through or split or distorted the element.
Jul 23, 2010 | Electrolux Ovens
Hotpoint sy36x grill element works fine but when switched on to oven it doesnt heat up, fan working.
it seems to me that it is a fan oven and the top element won't heat up you need a new fan oven element. it is a round element that sits behind the back grill surrounding the fan...
regards
richard saupe
appliance repairman
Mar 14, 2010 | Hotpoint SY36 Style Line Stainless Steel...
My bottom oven isn't working at all but top oven/grill and hob is working fine
If nothing is working in the bottom oven (no fan, no light, no heat) then it is most likely the oven selector switch is faulty.
If you have a light and or fan and they are working, it is a failed oven element.
Jan 15, 2010 | Ovens
Fan forced heat not working
If it is an electrically heated fan oven, then it sounds like the oven element is not working.
This is usually located at the rear rof the oven behind a removeable cover.
Hope this helps.
Dec 05, 2009 | Ovens
My astro x oven will not heat up, the grill still
Sounds like the heating element has gone. if you can see thee element sometimes you can see damage like a hole or melted metal with white residue
Aug 02, 2009 | Fisher and Paykel Ovens
Top oven (and Grill) have stopped workingMy 3 Year old AEG Competence D2100-4 Double oven has malfunctioned.  Bottom (main oven) works fine but top oven and grill have ceased to function.  The fan will run...
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Nov 12, 2008 | AEG D2100-4 Electric Double Oven
Temp display shows 444
If everything on your B1691N0GB oven seems to be working, i.e. all the lights are on and fan comes on in fan oven setting, but there is no heat from fan oven, conventional oven or grill, try turning your oven off at the mains, then turn on again. If the temperature display then shows 444, your oven is locked. To unlock, make sure the central control knob is in the "out" position, then press the fan oven and light buttons simultaneously for 10 seconds or so, until 333 appears on the display. Your oven is now unlocked.
Apr 08, 2008 | Neff B1641 Single circotherm super...
Smeg SE399X/5 Stainless Steel Electric Single Oven Logo
61 people viewed this question
Top Smeg Ovens Experts
ashburton
Hjalmer Lamminen
Hjalmer Lamminen
Jason Harris
Jason Harris
Are you a Smeg Oven Expert? Answer questions, earn points and help others
