Question about Sony BRAVIA KDL-40V3000 Television
Tv bracket i would like to secure my tv to a tv stand, and i got a greyish/blue strap a black wood screw and a machine screw, and i cannot find the directions for it, can you send me directions or walk me through it?
  • 84 Answers
Sorry, but i'm an electronic technician. I don't know enough information about strapping a tv to any type of stand. I wouldn't trust it.
c-dog
Posted on Apr 20, 2008
How do secure this DW to the inside top of cabinet... there are no holes to skrew through!
This is sort of strange, you give no info on what kind, model brand anything.
I will try to help anyway though. most dishwashers come with TWO REMOVABLE BRACKETS that clip to the top.
A single short wood screw goes through the bracket into the underside of the counter top.
IF YOU HAVE A SOLID SURFACE OR GRANITE COUNTER TOP, you might have to side mount the dishwasher. You might have to order the side mount brackets from the manufacturer or a parts house. Some stainless models have a little removable plug on each side that will accept a wood screw that goes into the cabinets on each side.
If you need more information please give us the brand and model number of the dishwasher.
Sep 26, 2017 | Washing Machines
Can you tell me what size screws I need to mount my Toshiba Model 46G310U on a wall?
M6 or M8
http://support.toshiba.com/support/search?s_query=mounting+bolts
User Manual
Page 6
... stand. 3) Once you have removed all four screws holding the pedestal stand in place, remove the pedestal stand ..., level, stable surface that can support the weight of the surface. Four screws Hook Sturdy strap (as short as possible) 46 / 55" TV VESA Mounting Pattern 32" TV VESA Mounting Pattern Four screws Hook Sturdy strap (as short as possible) Four screws Hook Sturdy strap (as short as a quilt or blanket. Make ...) 200x200 mm 200x200 mm 400x200 mm 400x200 mm Screw Size M6 M6 M8 M8 (unit in mm) 40" TV VESA Mounting Pattern Removing the Pedestal Stand 1) Carefully lay the front ...
Toshiba 46G310U Mounting Screws
Sep 24, 2017 | Televison & Video
This dishwasher,was installed without being secured,so it slides in and out,with little or no effort. The instructions say to install screws in the top and bottom, or buy side mounts. My question is : How...
Need more info ! hard to answer w/o a photo or even knowing you cabnet or countertop material . If you have a bit of a recess,or can create one, you may be able to go to most any home improvement store and buy common corner or "L" shaped small metal brackets. Very common and in many sizes,Pre-drilled/holes or holes already in them, very inexpensive.
The gasket around the machine door that keeps the water in cannot be compromised by having anything across any part of it`s surface when door is open or closed. The door will hide the brackets when closed if placed properly. The trick is determining how much surface area you have to work with around the gasket/door seal , to the cabinet sides or countertop bottom .This distance determines what size "L" brackets to use.
Slide the machine to where you want it , if it goes to deep into /under the counter or towards the back wall, put pressure treated scrap lumber behind the machine legs on the floor till it`s out to where you like it and the door opens and closes easily. (proper recess) If the cabnets on each side are wood , measure from the gasket to the side of the cabnet.
Is it a tight fit or a little space between the cabnet sides and machine face behind door area? Buy "L" brackets that will screw to the cabnets , cover the gap, but wont touch the door gasket .while resting tightly on the machine face behind door area. The brakets can alway`s be trimmed with a hacksaw or cut off wheel . Get flat head self tapping screws to mount the brackets to the wood cabnet sides. If possible, you may be able to mount to the outside front of the machine, behind the machine door, but outside the door gasket area/ diameter as well . It would give you extra strength but not 100% needed.
You may need to drill small "starter" holes smaller than the self tap thread diameter that are on the screws you puchased , to start the screws in the wood , metal , plastic , ect. Before you drill or mount , do a bracket placement trial run by using tape to hold them where you think they fit/work best . Again make sure the door opens, closes and hides the brackets . The higher up from the floor (closest to the countertop) the brackets are used , the more secure the machine will be ! It won`t flop on it`s face when you open the door to load it or put weight on the opened door.
You can also bring a printed copy of this to your choice of local home improvement store. Matching brackets to the right screws , ect , ect, is easier for them If they understand what you are doing and you find the right employee.
Hope it helped you ! Good Luck !
Jul 06, 2011 | Frigidaire FDB520RH Builtin Dishwasher
I mounted my tv on the wall by screwing it to a piece of wood than to wall, now i have moved and no longer have a stand for it. i am trying to figure out how to build a stand because i cant afford a new...
You can always buy a wall bracket for fixing TV from your Brand retailer OR any other electronic shop. OR Contact Brand service center in your town.
Jan 27, 2011 | Televison & Video
How do i mount it on a wall bracket ... like what screws do i take out the back of the tv to attach it to the bracket
first buy the right bracket for weight of tv there is 4 big black screws near center of tv ( IF FITTED )take them out place bracket over 4 screw holes then use the 4 screws you took out make sure they are tight ( DONT FORGET TO TAKE STAND OFF )
Oct 12, 2009 | LG 37LG30 37 in. LCD HDTV
Try to mount TV to the wall and need to release the TV stand
To Display your LCD TV using a Wall Bracket:
If you decide to wall mount your LCD TV, always use a ULlisted wall bracket appropriate for the size and weight of the LCD TV: 32HL37/32HL37U/32HL17/32HL17U: 38.6 lbs (17.5 kg)
37HL17: 46.3 lbs (21.0 kg)
42HL17: 59.5 lbs (27.0 kg)
1) CAUTION: Two people are required for installation.
2) Unplug and remove any cables and/or other component connectors from the rear of the TV.
3) Follow the instructions provided with your wall bracket. Before proceeding, make sure the appropriate bracket(s) are attached to the wall and the back of the TV as described in the instructions provided with the wall bracket.
4) After attaching the appropriate bracket(s) to the wall and the back of the TV, remove the pedestal stand from the TV as described below.
1) Carefully lay the front of the unit face down on a flat, cushioned surface such as a quilt or blanket. Leave the stand protruding over the edge of the surface. Note: Extreme care should always be used when removing the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose the pedestal stand screws. The jack pack cover can be removed without tools.
3) Remove the five screws. This will allow removal of the pedestal stand.
4) Once you have removed all five screws holding the pedestal stand in place, remove the pedestal stand from the TV by sliding the pedestal stand away from the TV.
Sep 28, 2009 | Toshiba REGZA 32WLG66 32 in. Television
Wrong type cooktop securing bracket for tiled cabinet
If it were me, I would go to Home Depot or Lowe's and get a small roll of metal strap with holes every 1/2". Should be an easy find and easy installation
Dec 19, 2008 | Electrolux Cooktops
I am trying to remove the stand on a LG Model : 52LB5D. I have removed the 4 screws on the back but can't remove stand. It feels like there is another screw or something holding it in.
If you are looking at the back of your tv there is the stand bracket with a screw on each side. remove those screws and nothing will happen. that is the problem i was having but if you look right above the ones you just took out and there is going to be a black screw. take those off from each side and it will fall off.
Dec 09, 2008 | Televison & Video
Childproofing tv
At Sam's club you can buy what is called a "Plasma" floater for about $77 that lets you mount your LCD or Plasma on the back of the unit, raise it up and keep it much more out of the way of kids:
http://graphics.samsclub.com/images/products/0076405342828_L4.jpg
(search under "Urban Loft 60" Entertainment Console" at Sam's club to find it)
The floater can be purchased seperate from the console table. AND it will work with the Whalen console I bought at Costco (I called Whalen and they confirmed it will work, it has all the right mounting brackets installed already).
http://graphics.samsclub.com/images/products/0076405342957_LG.jpg
(search under "Whalen Furniture Plasma Floating Mounting Bracket" at Sam's club).
Could drill some holes into the base of the stand and secure it to what ever you have it sitting on.
tie down strap that prevents tipping. You have to secure the strap someplace with a self tapping wood screw and the other end of the strap connects to the base of the TV.
Dec 15, 2007 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony BRAVIA KDL-40V3000 Television Logo
81 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
