Question about Canon PIXMA iP4300 InkJet Photo Printer
I have a Canon ip 4300. Recently I had a paper jamb (81/2 X 11)
. The jamb was caused by a misaligned sheet of paper being dragged into the machine. I slowly pulled the paper out in reverse. It did not tear or appear to have left any residual in the printer. After removing the paper I cannot get the printer to print. The orange light on the front flashes and I get an onscreen error message telling me that there is paper jammed into the printer and to remove it before continuing. I have opened front, top, back and bottom and cannot find any jammed paper. Occasionally the paper will simply feed straight through the printer without the print cartridge carriage activating.
Suggestions??
Thanks.
  • 518 Answers
It maybe the sensers which tell the faults has moved out of position or wires loose
Posted on Jul 06, 2010
New cartridges, letters in misalignment and double struck words
What Causes a Printer to Be Misaligned? ' Chron.com
smallbusiness.chron.com > ... > Setting Up a New Business Basics
A printer that has alignment problems will not print documents accurately. images and text ... Install new manufacturer's cartridges in the printer. If the cartridges ...
How to Replace & Align Canon Ink Cartridges ' Chron.com
smallbusiness.chron.com > ... > Computers
Misaligned cartridges cause poor overall print quality by producing print lines slightly... Remove the new cartridge from its packaging and remove the colored ...
PDF]Stylus Photo R300 / R300M - Product Information ... - Epsonhttps://files.support.epson.com/pdf/r300__/r300__pg.pdfEpsonEPSON Stylus Photo R300 Series - 1. Printer Parts ... asterisk (*). The printer also works with plain paper. Cartridge. Part number. Black. T048120 ... Letter. SCR1001. PremierArt Matte. Scrapbook Photo Paper for Epson. Letter ..... Unwrap the new inkcartridge. .... misaligned, align the print head (see page 11). Related ...[PDF]Epson Stylus NX430 - Quick Guidehttps://files.support.epson.com/pdf/nx430_/nx430_qr.pdfEpsonAfter you set up your Epson Stylus® NX430 (see the Start Here sheet), turn to this Quick. Guide and ..... Load letter- or A4-size paper in the sheet feeder. 2. Press ... Use the following list when you order or purchase new ink cartridges: Note: We ..
Jan 05, 2016 | Office Equipment & Supplies
Printer jams when duplexing
Most printer jambs are caused by a couple of things. Have you tried different paper? Sometimes paper that is curled, or if the humidity is too low, the paper will hold a static charge and cause paper feed problems. The other is worn or dirty feed rollers, try cleaning the feed rollers with isopropyl (rubbing) alcohol.
Nov 02, 2014 | Canon Imageclass D420 All-in-one Laser...
A paper jam on my canon ip4800 caused the print to be misaligned. now the edges are not straight. help!
When the paper does not feed straight, dirty or stickyrollers can cause it to jamb or crinkle, also failure to remove all traces ofpaper from a previous paper jamb will cause further paper jambs.
Check for tiny pieces of at the edges of the rollers, and remove these piecesof paper. The rollers may be dirty or sticky and causes the paper tonot feed straight.
Try cleaning the rollers with methylated spirits.
Sep 06, 2011 | Computers & Internet
The paper does not feed correctly so that the paper goes into the machine crooked causing a paper jam.
Aug 27, 2011 | Canon Office Equipment & Supplies
Canon MX310 not complete printing, last sheet may have jambed, took out whole. alarm on; printer display says: Check Print, press OK get 5100 message. On/off reset, open close, checked for paper jamb,...
Before your printer is on press the paper feeder tightly and than press power printer. Don't release your paper feeder until your printer is completing task...... thanks
Aug 11, 2011 | Canon PIXMA MX310 All-In-One Printer
My canon pixma mx320 won't feed paper properly it seems to grab one side of paper and feeds it crooked then stops
Jul 26, 2011 | Canon PIXMA MX320 Color USB InkJet Printer
Hello i have a canon mp250 printer and when i put paper in it i takes it at an angle and says paper jam what could the problem be and how can i fix it
Jul 15, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
Hi there have got a cannon pixma 492 had problem really since i brought then recently cant use had for 12mths only use a few times a month paper gets jammed then error 5200 please help i dont know what to...
When you removed the jammed paper, did the paper come out inone piece, if not did all the pieces that were removed make up the entire sheetof paper?
Otherwise there may be still a small piece/s of paper still in the printer,which is causing this error message. When the paper does not feed straight, dirty or stickyrollers can cause it to jamb or crinkle, also failure to remove all traces ofpaper from a previous paper jamb will cause further paper jambs.
Jun 09, 2011 | Canon MP490 InkJet Printer
Hp deskjet 5550 is always had a paper jam. what do you think is the problem of my printer? what is the possible solutions?
When removing a sheet of paper from a jambed printer, you need to be careful to slowly remove the paper without tearing the paper. This could lead to a tiny piece of paper being left behind and this will cause other paper jambs.
When this happens, the printer may need to be dismantled to remove the paper.
The other cause could be that there is uneven pressure across the rollers or dirty rollers which causes the paper to feed through unevenly and results in a paper jambs.
Check the printer for pieces of paper near the rollers and gears.
Clean the rollers, make sure there are no deposits on the rollers.
May 26, 2010 | HP DeskJet 5550 InkJet Printer
Canon PIXMA  iP4300 InkJet Photo Printer Logo
193 people viewed this question
old marine
old marine
