FRIGIDAIRE WASHER is the sensor switch the same as a reed switch
Is the reed switch the same as a sensor switch on a frigidaire waher
  • Starvinmarvi Apr 19, 2008
    Hello Julianfix, Thanks for your help.I replaced the control board,so would the reed switch be on the new board,,Thanks Marvin
  • 975 Answers
Yes !!
Posted on Apr 18, 2008
DDO have the problem that is the part that I have to change
Thank you for your inquiry, edwin chiu!
Based off the information you have provided your Frigidaire washer is displaying the error code "DDO". "DDO" stands for dispenser door open which could be a problem within your door or reed switch. I would recommend opening and closing you do to secure the connection is proper.
If that does not correct the issue I would perform a reset on your washer which you can do by disconnecting the power from it by either unplugging the power cord or flipping the household circuit breaker for ten minutes. Hopefully this information has been helpful. -Matt
Sep 26, 2014 | Frigidaire Affinity Glacier Blue 3.5 Cu....
Where does the reed switch go on my front loader
Hello friend, thank you for your post!
I see that your question is labeled under Frigidaire washer, GLTF2940ES. I have located the parts manual for your appliance and it will provide you the location of your reed switch. I hope this helps. -Matt
Frigidaire Manual Search Results
Sep 07, 2014 | Frigidaire GLTF2940ES Front Load Washer
Loc error code Frigidaire frontloader
From the frigidaire site.
Error code - Fault condition
E11 Fill time too long.
E13 Water leak in tub or air leak in air bell.
E14 Reed switch.
E21 Water not pumping out fast enough.
E23 Drain pump relay on control board failed.
E24 Drain pump relay on control board failed.
E31 Better models. Pressure sensor not communicating with control board.
E35 Better models. Pressure sensor indicates water overfill.
E41 Control board thinks the door switch is open.
E42 Door remains locked after cycle is completed.
E43 Control board problem.
E44 Control board problem.
E45 Control board problem.
E46 Control board problem.
E47 Board thinks the door PTC circuit is open in spin.
E48 Board thinks the door PTC circuit is closed.
E52 Bad signal from tacho generator.
E55 Motor overheating.
E56 High motor current.
E57 High current on inverter.
E58 High current on motor phase.
E59 No tacho signal for 3 seconds.
E5A High temperature on heat sink.
E5B High temperature on heat sink.
E5C High temperature on heat sink.
E5D Communication problem.
E5E Communication problem.
E5F Communication problem.
E67 Input voltage on microprocessor incorrect.
E75 Better models only. Water temperature sensor circuit.
E76 Better model only. NTC temperature for the cold water valve over the limits.
E95 Communication error.
EB1 Incoming power frequency out of limits.
EB2 Incoming line voltage above 130 VAC.
EB3 Incoming line voltage below 90 VAC.
EF1 Clogged drain pump.
EF2 Too much soap.
Jul 24, 2014 | Frigidaire GLTF2940ES Front Load Washer
Hello geraldinerid - Typically DDO indicates that the washer has detected a problem with the dispenser drawer. Either the drawer is open and will not close properly or a further diagnosis is recommended to have a professional check the reed switch.
Apr 12, 2013 | Frigidaire Affinity ATF7000E Front Load...
Pulled out detergent compartment and magnet fell out. where does it go machine wont run.
Welcome to FixYa.
The dispenser drawer on many Electrolux/Frigidaire built machines do require a magnet on the right hand side of it to activate the reed switch inside the console located there. It should fit in the bottom of the drawer, if you flip it upside down you should see it's intended location.
Let me know how you make out and I'll help further in any manner I can. Good luck.
Macmarkus :)
Mar 04, 2011 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire GLTF2940ES0 front load washer. turn it on and the water fills for 1-2 sec then turns off. replaced pressure switch and control panel. still does the same thing. someone mentioned the door...
does it ever agitate ... if it does than the door is locked ...there is a magnet that falls off these machines the detergent dispensor that tell the washer control board that the detergent dispensor is closed so water wont spray out if left open ,,,,magnet rectangle and size of a pencil rectangle shape .... you can try putting a large size magnet on the opening of dispesor shroud ,,,, usually when you replace the control board they have removed the magnetic dispensor reed switch and just jumped across the board eleminating this connection.
Jan 31, 2011 | Frigidaire Washing Machines
Frigidaire Front load washer with ''ddo'' code
The DDO trouble code means that the detergent(D) dispenser(D) door is not closed properly((O)open).
The door uses a reed switch and a magnet to send the door closed signal to the control card.If the
magnet becomes dislodged you will get this code.You will need to have the magnet replaced in
its proper position to clear this code.
Apr 05, 2010 | Frigidaire GLTF2940ES Front Load Washer
Front load washer won't wash and cycle
we had the same problem, have u checked the filter? because as i was on the net looking for a new one, my flatmate just checked the filter and it spewed out five screws and twelve bobby pins!! then voila! problem solved.. works like new now!
Feb 03, 2010 | Frigidaire Gallery Supreme GSTR1670DS 3.1...
Same problem!
There is a motor speed control board that may have failed. It is common on frigidaire wahers. You will need a servicer to verify that.
Sep 22, 2009 | Frigidaire ATF6000ES Front Load Washer
Ddo error code on frigidaire front washer
Thanks for using FixYa. Error DDo means dispenser drawer open. There is a little magnet attached to the right hand side of the detergent drawer which activates a reed switch to "tell" the machine that the drawer is closed. That magnet might have moved from it's place and that's why you are getting error ddo. magnet is part key number 51. Pull the drawer out and check on the handle part for a magnet. When the drawer is closed the magnet activates a switch in the console that tells the control the detergent drawer is closed. Please check this link for details(part #51)--
Frigidaire exploded parts catalog
Please do rate the solution and revert for further assistance.
Aug 14, 2009 | Frigidaire GLTF2940ES Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
