Question about Panasonic Microwave Ovens
Panasonic nne225mb Microwave oven does not heat up
Microwave oven does everything as normal but does not heat up
SOURCE: Panasonic Dimension 4 Turbo Bake
Your Magnatron is most likely to have failed, its an expensive part and on a turbo 4 could be 2M236-M42. Unfortunatly this appears to fail due to reduced air flow. So if you do replace it I would clean the rear grills completely to increase the airflow within the oven.
Posted on Aug 23, 2008
SOURCE: Microwave won't heat food.
My Whirlpool microwave, over the stove, stopped working when my son used it to heat his food and a heavy sound came out, like something exploded in it. When I check it, there was nothing broke. Everything works fine except that it does not heat. I will appreciate any help
Nate
Posted on Nov 09, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: My Maytag MMV4205 Microwave Oven runs but does not heat
With the symptoms you have, I would most strongly suspect a shorted high voltage rectifier diode or a bad magnetron, or a loose and possibly corroded connection on the magnetron's terminal.
The diode is a fairly cheap fix, and the mag will cost more.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html (if it's not shorted, it's probably okay)
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Dec 15, 2008
Sailorm0on
  • 61 Answers
SOURCE: Rust inside the microwave oven
This is just okay but if you're quite doubtful you may bring this to any appliance service center for repaint
Posted on May 15, 2009
localwonder
  • 6784 Answers
SOURCE: MICROWAVE IS NOT HEATING
HI, the actual device that produces the heat is damaged or faulty. this device is called the Magnetron. you will need to replace this part in order to restore the heating ability of this microwave oven.
Please rate and have a great day:)
Posted on May 29, 2009
Panasonic microwave convection oven model NN-CD997S works normal but stop heating
Judging from the model and without looking it up I expect that unit has an inverter. If it is not the Switches and you have replaced the mag, the inverter is the power supply for the mag to work so either mag not getting power from inverter or inverter not getting signals from main PCB Timer board.
Jul 03, 2017 | Panasonic Microwave Ovens
Panasonic NN-H965WF Microwave oven
We recommend the microwave is evaluated by an authorized service center by using www.panasonic.com/repair Welcome to Panasonic Online Repair
Apr 13, 2014 | Panasonic Microwave Ovens
My Panasonic Model NN-S252WF is not heating properly, it takes about 2x as long as normal to heat something
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
Dec 15, 2010 | Panasonic NN-S252WF Microwave Oven
I have a panasonic inverter microwave model 1250w and does not heat up, everything else works fine
its likley to be the magntron burnt out,,(thats the bit that heats the food up) its a pricy part to buy and have fitted,,it may be a lot cheeper to buy a new unit
Jun 20, 2010 | Panasonic NN-S254WF Microwave Oven
Everything works but won't heat
What you got was an oven with a bad MAGNATRON (this is whats the food!) I would return for replacment oven!...This is a common problem with these ovens!
I hope I was of big help to you!
Please rate this FREE solution!
Thank You!
Jan 17, 2009 | Microwave Ovens
Oven won't heat and shuts down after approx. 20 seconds
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
Dec 18, 2008 | Panasonic NN-S763BF Microwave Oven
Appears normal
ya this is the same problem i too had...everything will seem to right but the part required for heating might be damaged internally...try changing tat...here i did the same...
Sep 19, 2008 | Frigidaire GLMV168K Microwave Oven
Microwave does'nt heat up everything else works,just don't heat up
WHAT IS WRONG WITH YOUR MICROWAVE?
small_6_37.jpg For a detailed Microwave illustration, click below.
redarrow.gif Counter top
redarrow.gif Built in
Danger! You can receive a serious electrical shock from the components inside your microwave oven--even when it's unplugged. Only a qualified appliance repair technician should perform any repair.
It doesn't work at all
It sounds normal, but there's no heat
I can't adjust the power level
The carousel won't turn
I have intermittent cooking problems
The display flickers
There's no heat, but it buzzes loudly
It quit after I slammed the door
It looks like there's lightning (arcing) inside my microwave
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Aug 10, 2008 | Panasonic NN-S541 Microwave Oven
Panasonic Microwave NN-A770S getting hot on right side externally
If you described this to Panasonic very carefully, and they said it's normal, then I would say keep using it until such time that you get other symptoms. The inverter has some parts mounted on a large chunk of aluminum called a heat sink. It draws the heat out of the parts and the heat radiates and/or convects away. This keeps the circuit parts from overheating. As long as you have good air flow through the vents, it sounds okay.
Sep 13, 2007 | Microwave Ovens
Microwave Ovens Logo
60 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
