Question about E-Machines (308714) Motherboard
Computer wont boot up, power light comes on but wont recognize monitor. just before it started doing this , the computer would come on and start to boot up, when the windows status bar came up the computer would completely shut down.
There are many reasons for this problem i want u to tell me that did u install any program before this happened or power failure leading to immediate shutdown.
problems can be
1.there might be problem with due virus
2.it might be a problem of hardware failure of harddisk
3.it can also be that there might be bad sectors created on hard disk
right now what solution i can provoide is if boot from cd and try install fresh copy of operating system.u will have option of formatting only the c drive keeping rest of the drives with your data
Posted on Jul 06, 2010
Flashing green light and monitor wont start
There are one or two capacitors that open in the power supply, sometimes it will have a bulge at the top, making it easy to spot.
Apr 05, 2012 | Acer Computers & Internet
Moved my computer and now my monitor won't wake up. unplugging the cord to the computer comes up with a no connection signal but the blue light stops flashing. Plugging the cord to the computer back in...
Be sure computer is actually starting. Power off then on computer you should see the boot sequence and then windows screen on monitor. If you do not see startup sequence monitor is not sleeping either the monitor has failed or the video card has failed. Try another monitor first.
Oct 16, 2017 | Samsung SyncMaster 940N 19 inch LCD...
Computer shuts down
Please visit the below link to solve your problem.Due to some problems I was unable to send you the whole solution so please visit the site.
http://www.ehow.com/how_113600_troubleshoot-computer-wont.html
Thanks And sorry for the inconvenience.
Please rate me for this solution if it works for you.
  • Step 2 If you're starting from a button on the keyboard, make sure the keyboard is connected to the computer.
  • Read more: How to Troubleshoot a Computer That Won't Start | eHow.com http://www.ehow.com/how_113600_troubleshoot-computer-wont.html#ixzz0szt64gb5
  • Step 4 If you can hear the computer's fan or hard-disk drive, or if you can see indicator lights on the main unit but the monitor stays dark, make sure that the monitor is connected to a working power source, that it's turned on and that it's securely connected to the computer via the video cable.
  • Step 5 If the monitor and computer have power but the computer displays a "Non-system disk or disk error" message, check to make sure you didn't leave a disk in the A: drive. If you did, eject it and restart the computer.
  • Read more: How to Troubleshoot a Computer That Won't Start | eHow.com http://www.ehow.com/how_113600_troubleshoot-computer-wont.html#ixzz0szsjH6o9
    Jul 06, 2010 | Dell Inspiron 530 Desktop Computer
    Monitor won't come on
    do you hear a single beep when the computer boots? That's a sign of a good system... try your monitor with another computer...the problem might be your monitor.
    Aug 16, 2009 | ASUS SiS Chipset TUSI-M Motherboard
    Cannot get new Motherboard to boot up in Normal Mode
    what u may have done is wwhen u were installing the new board, gave a static shock to the system...that will cause only the fans to come on and nothing more...this is a bad problem bc u cannot fix it...if u figure out something else is wrong, and it gets fixed, let me know
    Jun 20, 2009 | Gateway Computers & Internet
    Wont boot/start
    Turn off power, unplug, hold power button for 30 seconds, take out memory, or if you have more than one stick only take all but 1, plug the power back in and start the computer. If a screen pops up that bios has changed press F2 to continue once computer is completly loaded click start, shut sown, unplug power cord again, hold power button 30 seconds, insert other memory and restart
    May 13, 2009 | E-Machines eMachines Desktop PC
    Emachine destop not recognising acer lcd monitor
    It sounds more like the computer isn't starting up. The "no signal" message is coming from the monitor itself to tell you it's on but there's nothing coming in to display. Normally no special drivers are required for the monitor, and you'd see at least the computer maker's splash screen and BIOS messages if the computer was starting up properly.
    You'll need to determine what is keeping the computer from starting up. Make sure it's getting AC power and that the power light comes on when you press the front panel power button. You may need a power supply. If the computer comes on but doesn't boot you may have memory problems or trouble with the motherboard. But your monitor is working properly.
    May 10, 2009 | Microtek C593 15" Flat Panel LCD Monitor
    Compaq Presario SR1920NX will not enter boot process
    From your description, the BIOS is not recognizing any drives or does not hand off from BIOS to a bootable drive.
    Start off by simplifying the system down to keyboard monitor and power cable. Remove *everything* else.
    If no boot, unplug power cable, monitor and keyboard. Hold power button in with no power for 15 seconds. This may clear a corrupt BIOS. Reconnect and see if it boots.
    If no boot, unplug power again and on the power supply somewhere near where you plug in the power cord look for a small recessed voltage selector. Flip it to 250 then flip back to 115 (these are approximate numbers and may be slightly different on your system). Your system may not even have a voltage selector switch.
    If still not booting or no drives are being recognized, we can open the case if you feel comfortable with that.
    I have talked a grandmother through replacing a mother board over the phone so we can do this if you want to give it a shot.
    Honest1abe
    Dec 30, 2008 | HP Compaq Presario SR1920NX PC Desktop
    Acer Monitor boots up w/computer then "no signal"
    you must have disconnected it while the pc was running.damage can occur while doing this as can a keyboard (they are not like USB devices that can be plugged and unplugged while "hot".)
    Jul 20, 2008 | Acer AL1916W 19" LCD Monitor
    E-Machines (308714) Motherboard Logo
    139 people viewed this question
    Top E-Machines Computers & Internet Experts
    Matthew Spark
    Matthew Spark
    Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
