Question about Denon AVR-1603 Receiver
Two front channels don't work, speakers and wires
AVR 1603 Denon - two front channels don't work, speakers and wires are for sure OK
  • Denon Master
  • 17,130 Answers
First of all please check the mode in which you are operating. Use the tester to see if there is tone on the speakers. Use a good DTS source and swtich over to 5.1 to check for requrired levels. If there is no sound yet, please open the cover and check for the connections to the front channels, check if the relay is clicking. You will have to look into the output mosfets for damage. for this the main board has to be accessed. If you think that you are not able to go deeper into find out the nearest Denon service centre. many such centres do not accept a set if tampered and so you need to be careful not to make it more costly. Hope my advice helps. Good day
Posted on Jul 06, 2010
Denon AVR1603 RESET
Starzy, to reset on a Denon AVR-1603
  • power off the unit using the front panel Pwr switch
  • press and hold SPEAKER A and B buttons;
  • keep pressing on the speaker buttons, switch on the AVR
  • when the display is blinking release buttons Check the attached links,instruction and guides, Good luck
    "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.avsforum.com/forum/90-receivers-amps-processors/1386123-help-denon-avr-1603-shuts-down.html
Denon AVR 1603 Operating Instructions Manual Last Function Memory...
Jul 24, 2016 | Denon Audio Players & Recorders
Denon avr-1603 switches itself off
HI,
Fist of all you have to disconnect all the speakers From AVR. Then switch ON the AVR . If its working normally then any of the speaker or any of the wire to the speaker is faulty. If so connect the speaker back one by one and check on which speaker connection does the AVR shuts off. That speaker or the wire to the speaker is faulty.
If the AVR is not functioning properly even after removing the speakers(shuts off) then there is internal fault with the amplifiers stage. Normally Dry soldering on the amplifier circuit board or any of the output stage is faulty. To rectify the same need professional support.
Ajin
Apr 27, 2012 | Denon Audio Players & Recorders
Hooked up the subwoofer and it doesnt work at all is the a subwoofer on and off button for this receiver
No, you have to follow the procedures in the manual to inform the unit that there is a subwoofer, then select some parameters on how it is used depending on the functional sizes of your other speakers.
http://www.retrevo.com/s/Denon-AVR-1603-Receivers-review-manual/id/363bh846/t/1-2/
Page 10
Aug 16, 2010 | Denon AVR-1603 Receiver
5ch/7ch stereo in 5 channel mode
Front panel button engaged for 5 or 7 channel operation? Also check front panel rear surround speakers button is engaged. Should get you back to 7.1 unless you have changed the rear surround speaker setup for a 2nd zone, also be sure you have a 7.1 DSP setting enabled.
Feb 22, 2009 | Denon AVR-2105 Receiver
Vinyl on Turntable sounds thin and trebley through Denon AVR-1603
You will need an adapter amp which converts the tiny tiny signal from a magnetic phono cartridge up to the line level that you need to feed into your AUX input jacks. They cost about $20 to $30 dollars and can be found at Radio Shack. Unless of course you have a phono input jack on the back of your Denon unit. Good luck.
Nov 26, 2008 | Denon AVR-1603 Receiver
Denon avr-1403/483
Denon AVR-1403/483One of the speakers when connected trips the units power off.
Disconnected it and it works OK without that channel. Connected a different speaker and wire to that channel and it does the same, trips power off. It's acting like a when two wires are shorted. This is not the case as I have tried different wires and speaker. Not sure whats going on. Presently running system without that channel. Hope someone has an idea.
Oct 19, 2008 | Denon AVR-1403 Receiver
Denon AVR 1603 goes to stand by mode
It has a blown channel, unless you are good at repairing them I suggest an authorized Denon service center. This Denon not only needs the shorted output transistors replaced, but a few resistors, a couple of driver transistors and a capacitor on the preamp board as well. alot of parts to be replaced. I have repaired about a hundred of these over the last few years and my shop charges about $200 for this repair, other shops should be about the same.
May 24, 2008 | Denon AVR-1603 Receiver
Denon AVR-1804 6.1 Channels Audio Problem
Make sure the input setting is set to 'Auto' while on those channels and not Analog.
Jan 18, 2008 | Denon AVR-1804 Receiver
AVR-1603 - no Sound exept over Headphones is a weak signal
First check the outputs at the output fets/transistors for any DC voltage. Reference your voltmeter to the speaker - terminal. If there is ANY DC offset, the amp is shutting down the outputs to protect your speakers from DC. Is the power supply + and - 47 volts? If only one supply is there That is your problem because the supplies should be symmetrical. Also look for any wiring problems from the amp to your speakers... any shorts? Try disconnecting all your speakers to totally eliminate any speaker problem and see if the relays still click. You should hear only ONE click when you first turn the amp on (delay of about 2-5 seconds). If they keep clicking the amp outputs are next. Also, is there any indication on the front panel of what is failing?
Jul 29, 2007 | Denon AVR-1603 Receiver
Denon AVR-1603 Receiver Logo
152 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
