Right cartridge incorrect lexmark x4530 - Office Equipment & Supplies
  • Anonymous Jun 04, 2008
    left cartridge incorrect lexmark x7170
  • jevta Aug 29, 2008
    I have 6 month multifunction 7350 all in one. After third exchange with new color cartridge I decided that only use black cartridge. Now, it happen again. What do. I sure it any mistake in software. Black is filled three times and worked. When go message multifuncion blocked all function even and fax for send. Have any advance? Seriously I think THROW in garbage.
2 Suggested Answers
  • 3 Answers
SOURCE: Lexmark X4530 Incorrect Cartridges.
By any chance did you get these cartridges refilled? If so then you may be out of luck as I read that Lexmark chip their cartridges/printers to reject refilled cartridges. I have the same problem at the moment just with the right (colur) cartridge. The cartridge is an original refillable Lexmark (i.e. grey box) I got the cartridge refilled twice and it worked fine, but the third time no joy. Research indicate that Lexmark program their printers to reject cartridges refilled 3 times!!
Posted on Jul 13, 2009
  • 684 Answers
SOURCE: I have a lexmark X4530
Please remove the cartridges from the printer. Take a dry lint free paper towel and gently wipe the contacts on the back of the cartridge (not the bottom from where ink is present). Wipe the contacts inside the printer (on cartridge carrier). Please snap the cartridges back into the cartridge carrier and please try to print a printer self test.
Make Sure you Insert the Cartridges in the Right Slot!
Good Luck!!!!
Posted on Sep 18, 2011
I have a lexmark X4530 and just recently it tells me that the right ink cartridge is incorrect
Good Luck!!!!
Aug 02, 2011 | Lexmark X7170 All-In-One InkJet Printer
I purchased new color ink cartridges (24) and my printer says "right cartridge is incorrect". The shape of the cartridge is different from the 24 cartridge I have replaced. How can I fix this? I have now...
Here's an article in the Lexmark website on Cartridge Numbers 23 and 24 Are Not Recognized on X3500-4500 Series Printers. Just click on this link: http://bit.ly/bOJwOc. A firmware update may be needed. Follow the instructions carefully. Hope this helps.
Jun 15, 2010 | Lexmark X4530 InkJet Printer
Cartridge incorrect
Try cleaning the place where you put it, do that with a contacts cleaner. Do the same thing with the in the cartridge.
Aug 20, 2009 | Lexmark X4530 InkJet Printer
After installing my new lexmark 23 black print cartridge into my X4530, the message 'left cartridge incorrect' keeps showing in the screen. I've tried printing a few things and it works, but the message...
There is not on lexmark's site about a firmware update to fix this
http://support.lexmark.com/index?page=content&id=SO4923&actp=search&viewlocale=en_US&userlocale=EN_US&segment=SUPPORT&productCode=LEXMARK_X4530&searchid=1254795924155
Aug 11, 2009 | Lexmark X4530 InkJet Printer
Jul 07, 2009 | Lexmark X4530 InkJet Printer
Lexmark X4530 left cartridge incorrect
You must upgrade your firmware on your printer.
Lexmark has a technical support bulletin :
Jun 06, 2009 | Lexmark X5470 All-In-One InkJet Printer
Lexmark x5490 Right /left cartridge incorrect
If you brought new cartridges and printer detecting it empty ,then you get it
replaced as the Lexmark cartridges comes with a 6 months warranty ..
Good luck....
Feb 13, 2009 | Lexmark X4530 InkJet Printer
My Lexmax X4530 gives ink cartridge error message
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 03, 2009 | Lexmark X9350 All-In-One InkJet Printer
Lexmark 4530 right cartridge incorrect message. unplugged unit, cleaned cartridge nothing works.
The compatible cartridges for the X4530 Lexmark printer are the # 23,23A,24,24A,31,34,35. If you have the correct cartridge number and still says cartridge incorrect, try this steps.
1. Get a damp and a dry paper towel.
2. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds. ( try this for around 5 times )
3. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean. ( try this around 5 times )
4. Next dab the cartridge on the towel to make sure that the ink is flowing.
5. Remove the power adaprtor behind the printer.
6. Using the dry paper towel, clean the metal contacts on the cartridge carrier inside the printer. ( try this 5 times )
7. Place the Cartridge back to the printer, connect the power adaptor.
8. Check if there is any error message. If same problem persist, try to contact Lexmark Technical Support.
Dec 30, 2008 | Lexmark X5470 All-In-One InkJet Printer
599 people viewed this question
k24674
