Question about KitchenAid (KSRD22FKST) Side by Side Refrigerator
My frigerator is making a very loud noise coming from the ice maker area. It sound like a airplaine engine getting ready to take off. Sometimes it gets louder and louder. If I turn the switch to off then back on the noise goes away for a min and then comes back not quite as loud. After a bit it gets really loud again. Do I need to call a repair person? The fridge is 5 years old.
    President:
  • 1,891 Answers
The noise is the evap fan hitting . now either its comming off the motor shaft or its hitting ice build up caused by incomplete defrost . It's time to call the repair man . as the noise will quit and the cold will too . mm
Posted on Jul 06, 2010
GE side by side refrigerator-freezer daily makes loud grrrrrnng noise. Sporadic. Comes from area just above ice maker. Makes no difference if I turn ice maker off. Any ideas what is causing this?
Many ice maker sporadically turn to keep ice from freezing together and becoming a solid block of ice. This would occur even if the ice maker is turned off in order to keep the ice already made from freezing. It is generally short and not that loud. I'm surprised you find it disturbing.
Jun 27, 2016 | GE Refrigerators
Replace motorized damper
It may be possible that water is splashing from the icemaker fill tub and running down into the fan area and freezing. When the refrigerator goes into defrost the ice thaws and the noise stops.
Aug 30, 2014 | Frigidaire FRS6HR45KS (26 cu ft) Side by...
My2005 pontiac grand prix makes a loud airplain noise in right front. if i turn it pops and sounds like the trans is coming out ans shift hard untill i turn off engine and then goes back to org noise
It sounds like you have a bad CV axle and if it has been like that for a while then you could also have a bad wheel bearing. Due to the fact that servicing these components requires disassembling the steering and suspension system on that side of the vehicle, this procedure should be performed by a qualified technician.
May 14, 2011 | 2005 Pontiac Grand Prix
Motor making loud noise in area of ice maker
Here is a tip that I wrote about refrigerators and the fan noisethat they develop sometimes...
RefrigeratorFan Noise
heatman101
Mar 14, 2011 | Roper Refrigerators
My Hotpoint makes a high pitched humming noise all the time.
This noise is most likely coming from the evaporator fan motor that is located behind the panel just below the ice maker. There is an air duct that the fan blows through to cool the ice maker that is why the sound is heard in the ice maker area more.
The noise does not hurt anything but the motor can be replaced if it gets too annoying, it is a fairly common complaint. The part number for the motor is WR60X10185 and runs about $60.00. It is a bit challenging to get to but can be done with a bit of patience by removing everything in the freezer and taking the back panel off the inside of the freezer.
Apr 18, 2010 | Hotpoint HSS25GFP Side by Side...
GE Profile making knocking noises at different times
I have the GE profile Refrigerator with ice maker in the refrigerator compartment. Mine was knocking loudly for long periods of time, so I finally removed the icemaker by removing the side panel in the icemaker compartment held with 1 phillips head screw, disconnecting the electrical plug (unclip), pulling the tab of the icemaker down (on top) and sliding it toward the door, thus removing it. There was ice frozen in the motor compartment that was the problem. I let it thaw out and re-installed. All was OK after that..
Jun 04, 2009 | GE Profile PSW26P Stainless Steel Side by...
Brand new french door maytag refrigerator makes a loud knocking sound off and on all day. Is that normal ?
im sorry to tell you, but the sound is probobly normal.
fridges these days make some weird noises.
they started making noises when they changed the gas to R34a.
you may be able to get a noise ruduction kit for your model. they are not too fun to install
May 31, 2009 | Maytag MFD2560HES Bottom Freezer French...
Periodically throughout the day there is a loud motor noise.
you may have a fan problem or ice maker open freezer switch on the frame freezer side press it you will know were the noise comming from
Apr 06, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Loud noise, makes ice but seems to have air in it...not solid
send me your email address and i can send the tech manual to you on your unit.
Feb 03, 2009 | Refrigerators
Loud Buzzing noise
Sounds like the fan is hitting some ice build-up. If you can access the area of the fan motor you can try a hair dryer to defrost the ice out of it.
Apr 15, 2008 | Frigidaire FRS23R4A Side by Side...
KitchenAid (KSRD22FKST) Side by Side Refrigerator Logo
471 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
