Question about Samsung Televison & Video
No green in picture
Looking for an online schematic for a samsung HDTV, TXN2668WH.
I'm an electronics hobbyist but don't own any TV tech troubleshooting equipment. Came across a Samsung television with no green in the video. If anyone knows which part to check, I have solder experience and know how to use a volt meter. Nothing loose on chassis, tap around with a pencil, no change in picture. Everything else works fine.
  • 525 Answers
Replace the crt board
Posted on Oct 28, 2010
When I turn the tv on, it blinks green then a steady green but no picture. When (if) it does come on, the picture is perfect. The tv is only four years old.
You have capacitors in the power supply that need replaced. If your not electronically inclined then I would have a tech take care of it for you. It's not an expensive procedure.
Nov 28, 2010 | LG 37LG30 37 in. LCD HDTV
Halfof the picture is green
Time for a new HDTV. I don't think that would be a setup configuration setting. It's broken. Chances are, like my Sony Bravia which had the lower right hand corner of the front of the LCD panel fall and hit a sharp object, it cannot be easily fixed. The LCD panels or electronics typically cost more than buying a new one.
You could check for a Factory Authorized Service for Samsung, online, and find a local shop. Here it's Lakes Electronics near Fort Lauderdale - I know because I used to work for them. I also looked up Sony and found a few more. They wanted over $900 for the LCD Panel for a 32" Bravia TV. The TV only cost like $700.00 new.
Nov 22, 2009 | Samsung LE40R73BD 40 in. HD-Ready LCD...
There is green and pink on color on half of my lcd
I did some research and I found this link that will should you the schematic of the LCD technology,It sounds like one of you LCD color ships is not working properly,your TV has 3 ships (BLUE,GREEN,RED)
you can see how it work; http://www.oerlikon.com/ecomaXL/index.php?site=OPTICS_EN_lcd_projector .Whay happening is that due to the high density the lamp this ships tent to wear out and the three major color don't mix properly causing the color discoloration on your picture.You can find the parts you need at DM http://www.discount-merchant.com/?click=52978 (The correct diagnostic can only be made be a tech) I hope this info helps you please keep us posted .
Sep 25, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung LN32A550 32-Inch 1080p LCD HDTV
Best Buy Samsung LN32A550 32 in. 1080p LCD HDTV Free shipping Order Today! [Click Here!]
Samsung LE32B650T2 32-inch Widescreen Full HD 1080p
Save On "Best Buy Samsung LN32A550 32 in. 1080p LCD HDTV" You can Buy Samsung LN32A550 32 in. 1080p LCD HDTV In Stock. Low Prices Samsung LN32A550 32 in. 1080p LCD HDTV Shops & Purchase Online - Quick & Easy.
Discount "Best Buy Samsung LN32A550 32 in. 1080p LCD HDTV" Free Shipping & Pay No Sales Tax! You can Buy Samsung LN32A550 32 in. 1080p LCD HDTV In Stock Low Prices Samsung LN32A550 32 in. 1080p LCD HDTV Shops & Purchase Online - Quick & Easy.
Dec 10, 2008 | Samsung TXJ2879 28" TV
Samsung big screen tv model pcl542r has a green or red tint to picture
do you have a service manual for this tv because it may be your red drive circuit and you need to trouble shoot it if you don't have a service manual for your tv I will post a link where you can get one plus free online tech support to help you troubleshoot this problem
http://servicemanuals.vstore.ca/
Apr 23, 2008 | Samsung PCL545R 54" Rear Projection...
Plasma HD tv CMP5500
I think it's time to search the net for a schematic and a service
manual.
The flashing light combination probably represents a special
diagnostic code referenced in the manuals, which will save
you a great deal of time and frustration.
You can probably also get the meaning of the codes from
tech support.
Finally, electronic knowledge without manuals will not
help you that much (I am an ex-electronic tech, now
computer engineer too), because the entire TV is controlled
by software.
There are tons of secret codes and key sequences
(from the remote) which factory repair technicians can
use to diagnose or tweak the machine, including
color balance, video and format parameters, reseting
usage timers, clearing error codes ... etc.
There may also be an USB port for diagnosing the TV
via a computer with custom software.
I am afraid that without a service manual, basic voltage
and continuity checks are the limits of your investigation.
Martin.
Mar 20, 2008 | Toshiba TheaterWide 52HM84 52" Rear...
Samsung TXN2668WH HDTV Power problem
HI
did you ever get this fixed? if so what did you do to repair it and how much did it cost?
i'm having the same problem.
Thanks
drew
Mar 15, 2008 | Samsung Televison & Video
Sony KDF-55WF655 55" LCD Projection TV
I have the same TV and the same problem, I take out the block of colours red, green and blue (the blue colour is broken) and I went to the electronic supplies for ask the price  and they don't sell just the little blue mirror (blue pixel), they sell all block for $2,050.00 dollars. It's the price for a new one
Oct 09, 2007 | Sony Grand WEGA KDF-55WF655 36" Rear...
Philips hdtv color distortion
your tv has a prolem in the color circuit there is a ic that controls this circuit changing it will restore your tv to normal.since you are not a tech have a tech look at it for repairs.good luck.
Aug 03, 2007 | Samsung TXM3296HF 32" TV
Televison & Video Logo
54 people viewed this question
Henry  Thomas
Henry Thomas
