Question about Saeco Magic De Luxe Espresso Machine
The dregs drawer seems to have water in it. Whereas the used coffee beans were discarded in lumps, the contents are now very wet and sloppy. We're in Bundaberg Queensland, could you advise the nearest service centre please. Thank you Lorelle O'Brien 0741 523 529
  • 1,089 Answers
Hi
That is a stripped thumbscrew. You need a new one. When it starts to brew, the stripped thumbscrew pushes up and allows the coffee to fill the head and dredge drawer.
The plastic rod that has 2 small hooks on the end and has ribs around the opposite end is your thumbscrew. It holds the filter screen in place. There is suppose to be a small round nut that is molded into the position between the legs with the hooks. If you use the key to tighten the thumbscrew you will pull the nut out and then the thumbscrew will pop out of the brew head. Check the stem of the filter screen. If you have an item that is about 3/8 of an inch long and has a grove in the middle and small bumps on it, that’s the nut. You need a new thumbscrew. Remove the old nut on the stem before putting it in the new thumbscrew. Remember it’s a thumbscrew, so it only needs to be finger tight. The key is for removing only.
Posted on Jul 06, 2010
Testimonial: "Thank you so much for your help, now will contact Saeco to find where I can buy a thumbscrew."
Question for Solis Master 5000 Digital. After being professionally repaired, it has worked fine for about 2 months, and then suddenly stopped brewing coffee. I cleaned it.Then I decalcified it using it's...
I am not familiar with the digital model. But it sounds like something didn't get put back together properly. The top mesh is very tricky and easy to strip if you took it apart to clean. I had a problem with mine and now just leave it on and wipe it off in place. If its not tight water will just bypass the coffee grounds. Sorry, I couldn't be more help
Jul 09, 2014 | Solis Master 5000 Espresso Machine
Syntia swims in water in dreger drawer
Syntia is not set to "3 beans" amount or beans used are too large to create enough grounds to make a full 9 grams for a good puck .
The finger guard does not allow enough beans to grind in the timing of the software , common problem.... until the finger guard openings are made bigger or ... the software is re-programmed
Mar 05, 2014 | Saeco Syntia Espresso Machine & Coffee...
I have a Saeo Incanto Tondo S Class coffee maker. It grinds coffe bean but coffe is not coming out. There is no water in dregs but only grined coffe powder. I can get steam and hot water and I do not find...
Hello Saaddition,
I understand that your coffee maker is not producing coffee. However, it is operating normal in all other respects. This is usually a common problem when the machine needs to be descaled. You may also need to clean the brew unit. Here is the link to the manual for you Saeco Incanto Rondo C class coffee machine it give you all of the directions to clean and descale.
One other question did you remove the dregs drawer with the machine off. If you did you will need to do cleaning to reset the machine as removing the dregs drawer with the machine off will not allow it to brew coffee.
Thank you for choosing FixYa.com
Justin
May 08, 2011 | Saeco Incanto Rondo Fully Automatic Coffee...
I just received my brand new talea giro plus in the mail today. went thru the instruction manual and set everything up step by step. when i turned it on the very first time the red exclamation point is...
I had a similar problem. I opened and closed the water tank, the top coffee bean coffee and the dreg door several times. I even 'stirred' the coffee beans a bit. Finally, after simply taking the coffee bean cover off and putting it back on, the light went to green. Even now, several months later, I sometimes have to open and close everything to make the green light come on, although it seems to be getting better with age. (like me :-))
Apr 27, 2011 | Saeco Talea Giro Espresso Machine
Flashing beans/dregs light -- can't start machine.
Hi
Either you dredge drawer is missing.
The tab in the back of the dredge drawer is broken.
The microswitch is bad for the dredge drawer.
The grinder motor is bad.
Apr 23, 2011 | Saeco Incanto Classic Espresso Machine
I have a Saeco Odea Go and my puck in the dreg drawer are really wet and I have water leaking (brown so with coffee) under the dreg drawer. how I can fix it ?
I recently had this problem. I throughly cleaned and lubricated the brew group as directed by the manual. Apparently if the brew group doesn't move smoothly enough it won't grind the correct amount of beans. Try lubricating and then brewing 2-3 cups to have the machine recalibrate the grind amount.
Jan 12, 2011 | Saeco Odea Go
Pucks in dregs drawer very wet
Hi
3 things can cause wet grounds.
1. You don't have enough coffee going into the brew unit. There is a lever on the right side behind the door at the top. Push it back towards the rear but not all the way. This will put more coffee in the brew unit and take up the air space so you will have less water.
2. Your grind is too coarse. Pull the lever below the bean hopper towards the front when it is grinding, to make the grinds smaller. Again less air space. Do this 1 number at a time so you dont make it too fine. Let each adjustment for 3 coffees before you make the next adjustment.
3. Your grinder has come apart and is grinding very coarse (French press). New grinder.
Dec 28, 2010 | Saeco Magic Comfort Plus Espresso Machine
Hello. I have had my Incanto Sirius S-Series for
check your brew valve,maybe is plugged or leaking in tray.
Sep 03, 2009 | Saeco Incanto Sirius Fully Automatic...
Dregs Drawer filling up with water
If this comes into the dregs drawer then you have to look at your brewing unit, if it comes to the drip tray, then it´s normal
Jul 05, 2008 | Saeco Magic Comfort Plus Espresso Machine
Saeco italia
ok turn the machine on and wait till warmed up. Open door while machine is on and remove the dreg drawer. This you always need to do when the machine is on otherwise it will not reset.
flashing means dreg drawer steady means coffee beans
Apr 05, 2008 | Saeco Incanto Classic Espresso Machine
Saeco Magic De Luxe Espresso Machine Logo
536 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
