Question about Bosch Axxis WFL 2060 Front Load Washer
Has a new motor, add detergent, close door. Indicator says laundr
Has a new motor, add detergent, close door. It dispenses the laundry detergent and sounds like everything is o.k. but then it doesnt' spin and the alarms sounds to indicate wash is done and to remove clothing, but it hasn't done anything. It just wet
  • Bosch Master
  • 2,605 Answers
Hello, welcome to Fixya.
Based on your description I'd suspect something is in the pump or you're either...
a) using too much detergent, even too much "HE" will cause problems with the rinse & spin cycles.
b) the wrong type of detergent
These machines must have "HE" type detergent's added to them only. Non -"HE" will not allow them to spin to there potential, cause damage and sometimes not spin at all.
Here's how to check the pump...
If your washer is indeed a WFL2060, this is how to reach the filter and clean it.
( If it is not a WFL2060 as the post indicates, please let me know and I can provide assistance on another model as it pertains to you ).
**Unplug the washer from the dryer or wall, or turn off the 30amp breaker at the home service panel...safety first**
1) Open the small square plastic door at the right bottom of the washer.
2) Via the small hose drain any access water from the pump...this is where a wet/dry shop-vac comes in handy, or a shallow pan with a few towels works as well.
3) Then turn the pump insert/button trap counter clock-wise and pull out. Clean the trap out thoroughly running it under hot water and mild soap or your washer detergent and inspect inside the pump for any other foreign objects/obstructions.
4) Re-install the lint trap insuring it is good and snug/tight. Before closing up the small access door, run a short rinse spin cycle to check for leaks.
Let me know how you make out, or if you require further assistance.
Thank you for visiting "fixya", please take a moment to rate the info provided for you here.
Good luck.
macmarkus :)
Posted on Jul 07, 2010
Motor won't turn on Samsung VRT Plus WF433B*GJ**
When washing heavily soiled loads, do not overload your washer in order to assure good cleaning results.
To add a forgotten item:
1. Press the Power button.
2. Press the Start/Pause
3. Wait for the door lock light to go out (Immediately).
4. Add the item, close the door, and press the Start/Pause
The door safety state continues for 15 seconds and the cycle is restarted.
ensure thorough cleaning,
To
Try washing bedding, towels, undergarments,
contact using the ActivFresh
GETTING STARTED
1. Load your washer.
2. Close the door.
Z_
Push the laundry into the drum completely to prevent the laundry from being caught in the door or
....... from falling out of the drum.
3. Press the Power button.
4. Add detergent and additives to the dispenser (page 20-21).
5. Select the appropriate cycle and options for the load (page 14-16).
6. Press the Start/Pause
7. The Wash Indicator light will illuminate.
8. The estimated cycle time will appear in the display.
The time may fluctuate to better indicate the time remaining in the cycle.
The actual time required for a cycle may differ from the estimated time in the display depending on the
water pressure, water temperature, detergent, and laundry.
9. Before your washer starts to fill, it will make a series of clicking noises to check the door lock and do a
quick drain.
When the cycle is complete, the door lock light will go out and "End" will appear in the display.
DO NOT attempt to open the door until the door lock light is off. To add a forgotten item, see
"Loading your washer" section (page 13).
When your washer is restarted after a pause, expect a delay of up to 15 seconds before the cycle
continues.
Pressing Power button cancels the cycle and stops your washer.
The pre wash, wash, rinse and spin indicator lights will illuminate during those portions of the cycle
Nov 28, 2013 | Samsung 4.3 cu. ft. VRT Plus , Steam and...
Top draw is stuck on rinse / can't move push button to go on anything else
make this tests and fix it. God bless you
Dispenser Lever
If the dispenser is broken and doesn't open or close properly the dispenser lever might need to be replaced.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Detergent Dispenser Cover
If the detergent dispenser cover is broken and the detergent dispenser doesn't work, the dispenser assembly should be replaced.
Wax Motor Actuator
If the dispenser will not release the detergent the actuator connected between the wax motor and the dispenser might be broken. Check the wax motor actuator and replace it if necessary.
Detergent Container
If the dishwasher dispenser doesn't work the detergent container may need to be replaced.
Dispenser Lid
If the dispenser is broken and doesn't open or close properly the dispenser lid may have to be replaced.
Detergent Dispenser
If the dishwasher dispenser doesn't work the problem is often related to the release mechanism. If the problem is with the dispenser itself, it may be easier to replace the entire dispenser.
Dispenser Door Spring
If the dispenser is broken and doesn't open during the wash cycle the dispenser door spring may have to be replaced.
Dispenser Latch
If the dispenser is broken and doesn't open or close properly the dispenser door latch may have to be replaced.
Dispenser Door Pin
If the dispenser is broken and doesn't open or close properly the dispenser door pin may have to be replaced.
Dispenser Actuator
If the dispenser is broken and doesn't open or close properly the dispenser actuator may have to be replaced.
Dispenser
If the dispenser is broken and doesn't open or close properly the entire dispenser assembly may have to be replaced.
Wax Motor
There is an electrically powered device called a wax motor which opens the detergent dispenser. If the dispenser is broken and will not open to release the detergent, the wax motor might need to be replaced.
Bi-Metal
If the dishwasher dispenser doesn't work the bi-metal actuator might be burned out or defective. The bi-metal is a simple metal loop which acts as a latch for the dispenser door. As electricity is applied to the metal loop, the loop deforms and bends away from the latch, releasing it. If the bi-metal is burned out it won't deform or release the detergent door.
Dispenser Slide
If the dispenser is broken and doesn't open or close properly the dispenser slide may need to be replaced.
Dispenser Repair Kit
If the dispenser is broken this dispenser kit may need to be replaced.
Main Control Board
The main control board provides power to nearly every component of the dishwasher including the detergent dispenser. If the dispenser will not actuate the main control board might be defective. You should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Jul 24, 2013 | Fisher and Paykel DD605FD Stainless Steel...
How much salt do I put in ,,, and why won't it
follow this steps and fix it. God bless you
Dispenser Lever
Wax Motor Actuator
Detergent Container
Dispenser Lid
Detergent Dispenser
Dispenser Latch
Dispenser Door Pin
Dispenser Actuator
Dispenser
Wax Motor
Bi-Metal
Dispenser Slide
Main Control Board
Jul 08, 2013 | Dishwashers
Dtergent dispencer does not open
Dispenser Lever
Wax Motor Actuator
Detergent Container
Dispenser Lid
Detergent Dispenser
Dispenser Latch
Dispenser Door Pin
Dispenser Actuator
Dispenser
Wax Motor
Bi-Metal
Dispenser Slide
Main Control Board
God bless you . see the photo attached.401f2962-5d22-48f3-89be-c1db11d8eabe.jpg
May 23, 2013 | Hotpoint-Ariston FDD914 24 in. Built-in...
Troubleshooting
Dispenser Lever
Wax Motor Actuator
Dispenser Lid
Detergent Dispenser
Dispenser Latch
Dispenser Door Pin
Dispenser Actuator
Dispenser
Wax Motor
Bi-Metal
Dispenser Slide
Main Control Board
Gd bless you
Hi, I have an Electrolux E600 dishwasher and the detergent dispenser door has stopped opening. There's definitely nothing blocking it (the solution given in the manual). Any ideas appreciated. Tha
If the dispenser is broken and doesn't open or close properly the dispenser lever might need to be replacedIf the detergent dispenser cover is broken and the detergent dispenser doesn't work, the dispenser assembly should be replaced.
Apr 05, 2013 | Electrolux Dishwashers
I have a front loading washing machine that smells inside. Any suggestions ???
IMPORTANT: Read thoroughly. DO NOT add detergent or other laundry products to this cycle.
1. Remove all items from the washer.
2. Open the dispenser drawer and 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment. DO NOT use more than 2/3 cup (160mL) of bleach per cycle as this will lead to product damage.
3. Close the washer door and dispenser drawer.
4. Select the Clean Washer cycle or a full wash cotton 104 F wash (40 C). DO NOT use any higher temperature as this will cause unnecessary fumes
5. Press Start and allow cycle to complete.
6. If the bad odour persists, repeat the procedure 1 or 2 more times. This may be necessary if this is the first time you have run this cycle.
7. After the cycle is complete, leave the door open slightly to allow ventilation and drying of the washer interior.
8. Repeat the cleaning procedure monthly.
To maintain the washer freshness:
1. Use only HE High Efficiency detergent.
2. Leave the door open after each cycle to for better ventilation and drying of the washer interior.
3. Use warm / hot water in your machine unless the fabric you are washing requires cold.
4. Use the correct amount of fabric softener.
5. If your laundry room is damp, use a dehumidifier.
6. Clean the door seal of visible residue.
Jun 22, 2009 | Daewoo DW500M Top Load Washer
A mold smell from my washing machine
Dec 28, 2008 | Bosch Classixx WFO 2466 Front Load Washer
The detergent dispenser sliding door will not stay closed
it is a very tiny plastic "tooth" that let open automatically the door when the washing program selected reach the opening point, the only good solution I suggest is to add the detergent after the first hot wash (just open the main door and drop it in!)...of course the best is to change this door locker with a new one...good luck!
Nov 17, 2008 | Neff 18 in. S5943 Slim-Line Built-in...
Washing machine has a musty smell
Jul 29, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Bosch Axxis WFL 2060 Front Load Washer Logo
157 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
