Question about iRiver X20 MP3 Player
Headphone jack failure
How can I get a few headphone jacks for the X20? I can install them and I know the original has it's days numbered.
  • PVC101 Jun 01, 2008
    My headphone Jack on the X20 has already failed. I re soldered the contacts. But it was no use. I figured it is very tarnished, and the contacts have lost their springiness. I too, need a replacement jack. The problem is, there are four contact leads on it, since the jack also serves as a switch for the speakers. I have yet to try Allied Elec. for a jack, but no luck yet.
  • 8,596 Answers
Normal repair shop can't fix it
iRiver will not send you the headphone jacks, although you can purchase a broken iRiver on Ebay and obtain jacks for this purpose - be careful - you are risking other damage to player
You must get the entire player replaced
Sorry, but this is true of nearly all Mp3 manufacturers.
This is the only answer I can give you, because it is the only truthful answer.
Posted on Jun 09, 2008
My 80GB IPOD has stopped making audio output. i can still view photos
The chances are your headphone socket is either dirty or broken. A few places still replace the headphone jacks on iPod Classics. A number of them advertise on eBay. Search for "iPod repair" in eBay or in Google
All the best
Jan 31, 2015 | Apple iPod Audio Players & Recorders
I have a 2008 Mini Cooper (Non-S) with a built in USB and 3.5 mm headphone jack. I can use this to plug in my iPod using the Y adapter cable that came from the factory. The problem is, the headphone
why do you need to replace tthe 3.5 jack ? contact BMW for the correct part if new one required , don't try to do on the cheap as will be asking for trouble
Nov 11, 2014 | 2008 Mini Cooper Hardtop
Hp input cycles on and off and there's no volume on my denon aver 1610 receiver
Headphone jack is bad. Two ways to fix: Either replace the headphone jack, or if you don't plan on using the headphones, unplug the cable going to the headphone jack pcb. There may be two cable on that board, unplug the one that is closest to the front panel. This will affect nothing else except disabling the headphone jack.
Mar 05, 2013 | Denon Audio Players & Recorders
Denon 1908 no sound
Try inserting a headphone plug into the headphone jack and remove it. Sometimes these units have a problem in the headphone jack where the unit thinks there are headphones plugged in even when there isn't. This cuts all the audio output to the speaker jacks. If you never plan on using the headphone jack, you can also go inside of unit and unplug the cable that goes to the headphone jack board. Just make sure you unplug the unit before you do this, the plug is close to the main power switch.
Feb 22, 2013 | Denon AVR-1908
Dell laptop headphone sound on out headphone no sound
Sound Loss in Dell Computer Headphones b> Most Dell computers have special hardware and software that are set up to automatically adjust the configuration of the headphone ports when headphones are connected, muting the primary speakers in the process. If no sound is coming out of your headphones, this is most likely caused by a configuration issue that can be resolved with a few simple steps.
Basic Headphone Troubleshooting
If no sound is coming from your headphones, confirm that the headphones work properly by using them with a different device. After this, confirm that the headphones are plugged into the proper jack. If your CD/DVD drive has a headphone jack in front, audio will only be played through this jack when you are playing a disc. On a desktop computer, the correct jack to use for headphones is usually color-coded green, while notebook computers will have headphone icons next to the correct jacks. Finally, check the speaker icon in the system tray to make sure that your sound output is not muted. b> Troubleshooting Notebooks b> Most Dell notebooks use a special type of audio jack. The jack, along with the sound drivers that are installed, automatically detect whether headphones or speakers are plugged in and adjust the sound output accordingly. If this does not happen when headphones are plugged in, the sound drivers may be at fault. Visit the Dell support website and download the most recent sound drivers for your notebook. If this does not help, some users have reported success with removing the sound drivers completely and letting Windows install generic drivers automatically. Last Resort b> If all other options have been exhausted, the last resort in troubleshooting a headphone jack is running a complete system recovery operation. This will completely erase all of the information on your primary hard drive partition and reinstall Windows along with the drivers for all of your hardware. This is an extreme measure, as you will lose all of the information that you have stored on the hard drive. However, it will resolve the issue if it is caused by a software problem. If the issue remains, the headphone jack must be replaced. Hope this helps.
b>
Dec 29, 2012 | Hitachi VisionDesk 1330 (1330-001) PC...
Sony stereo mhc-gx9900 audio doesnt come out of speaker thou all lights show its playing
There is a intermittent problem on the main board, or the headphone jack is dirty or worn contacts, buy electronic cleaner, spray into headphone jack or earphone jack, slide headphone jack in and out as you spray the contact cleaner, do this several times in a attempt to restore audio.
Apr 06, 2012 | Sony MHC-GX9900 Shelf System
Headphone jack not working
I find that there is a problem with your headphone speaker.
Try with some other headphone, even if it is not working, then you need to take it to the service center.
Cheers,
Mr.Maduraikaran.
Jan 10, 2012 | Acer Computers & Internet
Jbl roxy over ear headphones ref 430 need to install new cord. how do i open cans?
Hello.
Headphone speakers stop functioning properly when the wireconnections to the speaker are broken. This problem often develops when theheadphone cord gets jerked while being worn. The solder connection might alsodetach over time if it was not properly manufactured. The wire can bereconnected to the speaker with a soldering iron to repair the headphone. Beaware, though, that headphones are not designed to be user maintained in thisfashion. In some cases, it is difficult to get to the speaker due to the casingdesign.
Instructions and tools needed
Screwdriver or butter knife (depending on headphone design),Soldering iron, Electrical solder
1 Plug in the solderingiron. It takes a few minutes for it to get warm enough to be used.
2 Unscrew the screws holdingthe headphone casing over the speakers. This step applies only to models thatuse screws in the casing.
3 Insert the end of the butterknife into the seam on the headphone ear pieces. Pry the two halves of thecasing apart. This step is performed only on headphone models that do not usescrews in the casing.
4 Touch the tip of thesoldering iron to the electrical solder. A small drop should melt onto the tipof the iron.
5 Touch the tip of the soldering iron to the end of thedetached speaker wire inside the headphone speaker cavity. Try to get an evencoating of solder around the exposed metal end of the wire. The soldersolidifies on the wire once the soldering iron is removed.
6 Touch the end of the wire tothe solder on the metal tab attached to the speaker.
7 Touch the tip of the solderingiron to where the wire and tab connect. The heat of the soldering iron meltsthe solder on the wire and tab together. This repairs the broken connectionbetween the wire and speaker.
8 Replace the speaker casingonto the headphone. It should snap back into place for models without screws Thanks.
Sep 22, 2011 | JBL Reference 420 On-and Over-Ear...
Rear headphone jack is not working!
Go into the case and unplug the frount headphone jack to enable the rear, some motherboards are particular on this issue.
Apr 22, 2009 | E-Machines T2898 (764296109563) PC Desktop
2 sets of headphones will play only on left earphone.
Dirt inside of the headphone jack can be the culprit. If you have canned air, you can blow it out, or twist the headphone connector inside the jack to clean the contacts.
Dec 20, 2008 | MyMusix PD-6070 MP3 Player
iRiver X20 MP3 Player Logo
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
