Question about Maytag Dryers
Dryer just stopped working. the light doesn't even come on when door is open. this is a maytag dryer model hye3460ayw.
  • Maytag Master
  • 43,501 Answers
There can be many reasons why your dryerdryer just stopped working - 2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on Jul 12, 2010
Dryer continues to run when I open the dryer door.
The door lock is more than just a latch; it is an electrical interlock. From your description it is likely that the interlock has failed
Jun 02, 2013 | Maytag Neptune MCE8000AY Electric Dryer
Maytag dryer model number PYE3200AYW stopped working and no light comes on when door is open
check the door switch:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Oct 30, 2010 | Maytag PYE2300AY Electric Dryer
Maytag dryer stopped working (model LDE9334ACE - electric). Dryer light DOES NOT work when door is open. Checked circuit breakers and that's fine.
Check your timer switch, that would cause you light not to work.
Also check the bulb, it may be burned out.
I hope this helps
Oct 01, 2009 | Maytag Dryers
My maytag performa dryer stopped working. The
If a dryer is not working at all that's not good! But it doesn't mean you need to go appliance shopping just yet. It may be something very simple like a bad door switch or even a broken door switch actuator, in a kenmore dryer there is a tab thats sticks out of a hole in the wall that allows the dryer to run only if the door is shut, other models may have button that protrudes out of the dryer and when the door is shut, this allows the dryer to run. These switches go out from time to time, also if a dryer is full of lint build-up over time this will cause the dryer high limit or fuse to blow. The fuse is located near where the blower is in most cases. When the air in the dryer gets way too hot the fuse/hi-limit will blow and the house wont burn down.
Sep 12, 2009 | Maytag Dryers
Dryer stops in the middle of cycle
The door latch has failed, that's why your dryer stops. When the door opens it stops the drum and turns off. Fix the latch.
Jul 01, 2009 | Maytag PYE2300AY Electric Dryer
Dryer Stopped In Middle of Cycle and light does not come on.
spinner is not spinning when there is in the washer, when empty it is okay i changed the coupler
Mar 29, 2009 | Maytag Dryers
Maytag Neptune Gas Dryer "do" code
sonds as if you have abad door switch assy, uint not reconozing the door closed
Oct 29, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Electric Dryer Stopped Working
Check spring tab behind door switch-if it's bent/out of adjustment, circuit will act like door is always open.
To confirm this, open door, set dryer to active setting, and hold in door switch; if it comes on, then it's either the spring tab, or the switch is malfunctioning
Mar 30, 2008 | Dryers
Dryers Logo
170 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
