Question about E-Machines eMachines Desktop PC
I have Emachine El 1200-06w with windows xp installed.The computer starts but goes to a blank screen. it will not let me use the recovery disk i made .But the partitions are still there
  • 5 more comments
  • Keith Carroll
    Keith Carroll Jul 06, 2010
    ive tried to go to safe mode but it just starts loading and stops. where do i get "Ultimate boot CD for windows and how do i put it on a cd
  • Keith Carroll
    when it comes up ask if i want to boot from hard drive cd rom but no recovery
  • Keith Carroll
    Jul 06, 2010 - does not make it to windows logo
    Jul 06, 2010 - trie the vga no luck thanks
  • Keith Carroll
    I use fix it utilities 10 and tried to restore to earlier point but it did not work.so then i tried restoreing useing windows file protiction but says it can not find files.
  • Keith Carroll
    Keith Carroll Jul 07, 2010
    i used ubcd and it is working but not sure what i need to do to fix the problem
  • Keith Carroll
    ok thanks
  • Keith Carroll
    can you tell me what i need to do with UBCD 4 win to repair the computer
  • 1,472 Answers
Kc7702
So does the screen go black when Windows starts to load?
If so the problem most likely is an issue with the video drivers. With the LCD monitors they get picky with the signal that they are sent. So if there is a problem with the drivers you get the black screeen problem that you have now.
The easy fix is to hook up a CRT monitor. Doing this should let you see Windows load. Once it loads then all you need to do is reinstall the drivers for your video card.
Let me know if you have any mor question or problems. Also if you do not have access to a CRT I will give you the next part to go through.
Issken
http://www.fixya.com/users/issken
Posted on Jul 07, 2010
  • Will Hartford
    Will Hartford Jul 07, 2010
    kc7702
    I was just checking back with you to see if you were repling back to me. To clarify with you it looks like the problem is with the video card drivers. So trying to do a Windows repair most likely will not fix the problem with the driver. The best thing for you to do is get you hands on a CRT monitor to get Windows loaded so you can reinstall the drivers. As long has to have not messed up you install this should work. Note if you do not have access to a CRT monitor you may be able to try an LCD monitor of another brand.
    If you still have trouble you are going to have to do a hard back up of the hard drive on another computer and reinstall Windows.
    Let me know if you have any more questions
    Issken
  • 942 Answers
Hi! I do understand you have a problem with your pc. Before performing the system recovery, try these recommendations:
Turn off the machine, then remove the cables on your desktop pc. Then press and hold the power button on the computer. Then reinsert back the cables and turn on the pc. While turning on the pc, repeatedly press F8 if you can so that you can select safe mode with networking. If it is successful, try to back up the files on your pc using a external hard drive or maybe a USB flash drive. Then refer to your manual if you can perform a factory restore on your pc without using a CD since you mention that you cannot able to use the recovery disc to recover files. Instead, you can try to use the same disk to create a new partition. That is why it is very important to back up the files on your pc. If all else fails then try to call your emachine manufacturer for immediate repair....
    President:
  • 3,278 Answers
Hello.
First, see if your memory is the culprit. Remove all and add one at a time (if multiple modules) to test. Be certain to disconnect all connected cables and touch metal to dispel static electricity before removing the memory.
You may be able to access Recovery Mode by tapping the F10 key at bootup. Select the boot drive. select the hard drive and then as it starts to change, press together Alt and F10 keys to go into emachine recovery mode.
Hope this helps.
  • 1 more comment
  • Keith Carroll
  • NinaE Jul 07, 2010
    If UBCD is allowing you to boot your system, can you run diagnostics on it ?? If UBCD is telling you that there are no problems, it's referring to hardware.
    Therefore, Windows XP needs to be reinstalled. If you are unable to retrieve the Recovery Partition, the only other way is to reinstall Windows XP with a purchased CD. You'll need to download the drivers for your computer. At the very minimum, download the chipset and network drivers from another PC and copy to a diskette or flash drive for your Emachine.
  • NinaE Jul 08, 2010
    Hello, again.
    What is on the screen of UBCD ???
    Guru:
  • 468 Answers
You can restore the computer back to factory default,to do so, follow the below steps: Turn Off the computer, now as soon as you hit the power button back, keep on holding "Alt" key & keep on tapping "F10" key, i.e Alt+F10, it will open the recovery console, select full factory restore and follow onscreen instruction. NOTE: This will erase all the datas on the computer.
  • 3 more comments
  • Keith Carroll
  • Keith Carroll
  • Balakrishnan Computers (A Computer Repair Shop)
    Acer E-Machines uses ISO image inorder to perform recovery and reinstalling Windows. So, if you try to use UBCD it will not recognize the OS and hence will make the recovery partiion inaccessible. You can use the UBCD, if in case you are using a retail version of Windows but not OEM (Original Equipment Manufacturer). By the way, what is the excat situation right now on your computer. Is it stuck at e-Machines logo or Windows screen. Please find the below details:
    If stuck at e-Machines logo, then try the below mentioned steps:
    It may happen due to hardware failure, BIOS mismatch or due to static charge. Let us try the basic troubleshooting. Turn Off the Computer, remove all the devices attached to the computer, the power cable and battrey, now holdon the power button for 15 secs (make sure adpater and battery are uplugged) it will drain out all the static charge. Now, restart the computer and keep on tapping F2, you will enter to BIOS setup utility, press F9 (click "Yes", if you are prompted) and then press F10 (Click "Yes", if you are prompted), it will restart the computer to Normal mode. If still it is not booting to normal mode, then we have to perform a full system recovery & it is a distructive process as you will loose all the datas on the computer. To do so, Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10" key, i.e Alt+f10, it will open the recovery console, select full factory restore and follow onscreen instruction. NOTE: This will erase all the datas on the computer.
    If stuck at Windows logo, try the below mentioned steps:
    Shutdown the computer and Restart it, as soon as it restarts keep on tapping F8 key, now select, "Last Good Known Configuration" and hit "Enter" key. It should take care of the issue. If not, then boot the computer to "Safemode", to do so, restart the computer and as soon as it restarts keep on tapping F8 key, now select "Safemode" from the Advance boot menu. If it is booting to Safemode, then perfomr a system restore to previous date. If nothing happens, then you have to perfomr a full system restore.
  • Shanon Brown
    Shanon Brown Sep 28, 2013
    What is the password for the BIOS setup? It takes a password that I never set and I cannot get in.
  • Shanon Brown
    Please email me if anyone knows the answer. Thanks, mamabird@gmail.com
How do you put the Windows XP back to factory default in the start?
There's two ways, one is using system restore and using the oldest restore point, as long as the points weren't deleted to increase storage space.
The other way is to use a windows XP install disk and doing a fresh install of XP.
As for a system, you can restore a system like a pre-built, say a eMachine using the recovery partition or recovery disks.
Apr 13, 2013 | Microsoft Windows XP Home Edition
Tip
How to Recover eMachines Notebook Windows Password
eMachines, as a brand-name laptop, is attractive to many netbooks users. We also call it as Acer eMachines for its developing history. We often receive letters from eMachine notebooks users on Acer eMachines password reset for forgotten eMachine administrator password. How to remove eMachines password or change eMachine password if I forgot Windows 7, XP, Vista password? Now, begin discuss the ways to unlock eMachine password.
1. Reset eMachines administrator password with other admin account
This means that we still can login our computer by accounts with administrative rights or privileges. Please never forget the default administrator, it may help much!
eMachines XP password reset from Safe Mode
A. Switch on eMachine Windows XP laptop and keep pressing F8.
B. Opt for "Safe Mode" and press "Enter" key at the Advanced Boot Option windows.
C. At login screen, choose the Administrator account and keep "Password" column blank (or input the changed password if the default Administrator account password has been changed before).
D. Start - Control Panel - User Accounts - select the account needed to change password - Change the password.
E. Input a new password, confirm the password again and then complete
Acer eMachine password removal on XP.
eMachines password recovery on Windows 7
We can recover forgotten password with built-in admin account:
A. Power on Acer eMachine computer and press the key: F8.
B. At the Windows - Advanced Boot Options, select "Safe Mode with Command Prompt" and press Enter to confirm. Then PC starts Windows.
C. Choose the Administrator account shown on the account screen, and then login windows - Administrator: cmd.exe. Input command: net user Lily abcd and Enter to confirm (Lily is the account needed to break password; abcd is the new password for the account).
D. After command finished, we can restart eMachine Win 7 laptop and login with account - Lily, password - abcd.
2. Break eMachines password with only guest account
We know that the guest account can not do more operations on a security PC. So, we have to refer to other way to retrieve the admin account for further operations.
Bypass eMachines password with recovery disks created before lost eMachine password
When input an incorrect password at the login screen, click "Reset Windows Password" and insert the eMachine password reset disk. The Password Reset Wizard will lead us create a new password to remove forgotten eMachines Windows 7 password.
Retrieve eMachine Windows password by DIY a password reset disk after forgotten
It is considered as the most instantly and easiest way to recover lost eMachine password. A .iso file, bootable CD/DVD/USB disk and accessible PC will solve problem within minutes without special techniques for a green hand on PC.
We can get the .iso file from many Windows password recovery programs. Just take one of the most popular tool - Ainorsoft Windows Password Recovery as example.
A. Download the suitable Ainorsoft Windows Password Recovery program and burn its .iso file into a blank CD/DVD or USB Flash Drive on an accessible computer;
B. Boot the burned CD/DVD or USB Flash Drive from the PC password locked;
C. Reset the new eMachines password.
Ainorsoft Windows Password Recovery tool concludes Basic, Enhance and Corporation versions. The Basic is opted for Windows 7, XP, Vista, 2008, 2003,etc. CD/DVD disk suits for it! The Enhance version can be used with USB disk for the former OS. While, the Ainorsoft Windows Password Recovery Corporation is designed to Windows 7/Vista/XP/2000/NT/Server 2008/2003/2000 with bootable CD/DVD or USB Flash Drive.
Main methods on eMachine password reset are shared as above. Recover forgotten eMachine laptop password from Safe Mode or unlock eMachines password with password reset disk. Hope the any one help our eMachines computer users!
Article source: http://windowspasswordrecovery.net/article/emachines-password-reset.html
on Jul 08, 2011 | E-Machines eMachines Desktop PC
Tip
Guide: Windows XP Lost Password Recovery
So you <b>lost your Windows XP user password</b>? You can try your best to remember XP account password, such as:<br /> <ul> <li>* your name?</li> <li>* a loved one's birthday?</li> <li>* something from your childhood?</li> <li>* a pet's name?</li> <li>* your home or office address?</li> <li>* the name of a friend or family member?</li> <li>* a frequently dialed telephone number?</li> <li>* a favorite food?</li> <li>* a combination of any of the above?</li></ul> <a href="http://www.windows7password.net/wp-content/uploads/2011/01/forgot-windows-xp-password.jpg"><img src="forgot-windows-xp-password-500x187.jpg" /></a><br /><br /> Still Can't Find Your Windows XP Password? If you've given it your best shot but that all-important Windows XP password is still hiding somewhere in your mind, then it's time to try something a bit more technical.<br /> Don't worry - There is a easy way to recover the password. Windows password recovery tool is a software program designed to recover or reset/delete your Windows XP password. It can sometimes be difficult to use but if there's no hope of remembering the password and you can follow some simple directions, Windows password recovery tool is life saver.<br /> <b>Notes:</b> You need a <b>Windows XP Password Reset disk</b>. If you don&iexcl;&macr;t have created it before, you should use the Windows Password Recovery Tool to burn a reset CD/DVD or USB flash drive.<br /> Step 1. Download the Windows Password Recovery Tool Go to the <a href="http://www.windowspasswordsrecovery.com/index.htm">official site</a> of Windows Password Recovery Tool, and <a href="http://www.windowspasswordsrecovery.com/downloads/Windows_Password_Recovery_Tool_Trial.exe">download it for free</a>. Install it with default options.<br /> Step 2. Create a Windows XP Password Reset disk Run this soft, insert a blank cd/dvd or usb flash drive. Follow the step-by-step guide to burn a <b>Windows XP Password Reset disk</b>. You can burn it to a cd/dvd or USB, it depends on your personal condition. After burning successfully, you get a password reset disk. Now insert this password reset disk into the locked computer which you <b>lost Windows XP Password</b>.<br /> <a href="http://www.windows7password.net/wp-content/uploads/2011/01/burn-windows7-password-reset-disk.jpg"><img src="burn-windows7-password-reset-disk.jpg" /></a><br /><br /> Step 3. Set the bios config to boot from cd/dvd or usb <ul> <li><b>1.</b> Start your locked Windows XP Computer, press <b>Del</b> or <b>F2</b> button while the computer is initalizing. The initial startup screen may be similar as this image. If you do that, you may see the bios config screen.</li> <li><b>2.</b> Go to the boot menu and change bios setting to make it boot from cd/dvd or usb firstly.<br /><a href="http://www.windows7password.net/wp-content/uploads/2011/01/boot-computer-from-cd-first.png"><img src="boot-computer-from-cd-first.png" /></a><br /></li> <li><b>3.</b> Press F10 to save your changes, then restart this computer.<a href="http://www.windows7password.net/wp-content/uploads/2011/01/save-bios-change.png"><img src="save-bios-change.png" /></a><br /></li> <li><b>4 .</b> After restart, the computer will automatically load Windows password Recovery Tool and you can start to <b>reset Windows XP Password</b>.<br /><a href="http://www.windows7password.net/wp-content/uploads/2011/01/loading-password-reset-disk.png"><img src="loading-password-reset-disk.png" /></a><br /></li></ul> Step 4. Recover Windows XP Password with the password reset disk. <ul> <li><b>1. </b>Choose the Windows XP Installation if you have more than one OS in this computer.</li> <li><b>2.</b> All Windows XP users will be listed. Select the user name which you forgot its password, click reset button.<br /><a href="http://www.windows7password.net/wp-content/uploads/2011/01/recover-forgotten-windows-xp-password.png"><img src="recover-forgotten-windows-xp-password-500x375.png" /></a><br /></li> <li><b>3.</b> A dialog box will be pop-up, click Yes to confirm reset, then this <b>Windows XP user password</b> will be reset to blank.<br /><img src="confirm-reset-xp-administrator-password.png" /><br /><img src="reset-windows-xp-password-successful.jpg" /><br /><a href="http://www.windows7password.net/wp-content/uploads/2011/01/after-resetting-xp-password.png"><img src="after-resetting-xp-password-500x307.png" /></a><br /></li> <li><b>4.</b> Eject the password reset disk, and restart you computer, <b>login Windows XP</b> with a blank password.<br /><a href="http://www.windows7password.net/wp-content/uploads/2011/01/loading-windows-xp.png"><img src="loading-windows-xp-500x302.png" /></a><br /></li></ul> <a href="http://www.windows7password.net/wp-content/uploads/2011/01/login-windows-xp-without-password.jpg"><img src="login-windows-xp-without-password-500x377.jpg" /></a><br /><br /> <a href="http://www.windowspasswordsrecovery.com/downloads/Windows_Password_Recovery_Tool_Trial.exe">Windows XP Password Recovery Tool [Download]</a><br />
on Mar 04, 2011 | Microsoft Windows XP Home Edition
How do I format my laptop using the recovery disk???
hi there, here's the step by step procedure for reformatting.
1. insert the recovery disk first to your cd rom
2. restart pc and keep on tapping the F12 key
3. once you are prompted for boot options select your cd/dvd rom drive
your computer will now boot up from your cd rom and will initialize the setup.
Apr 21, 2010 | Acer Aspire 4720 Notebook
My hard drive burnt out. The hard drive test says failed and the operating system won't boot. I placed a leftover hard drive from my Playstation 3 into the laptop and now it says no operating system found....
Try the recovery console from a windows xp recovery/install disk:
To run the Recovery Console from the Windows XP startup disks or the Windows XP CD-ROM, follow these steps:
1.Insert the Windows XP startup disk into the floppy disk drive, or insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted.
2.When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
3.Select the operating system you want to repair (you may have only one option).
4.When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
5.At the command prompt, type the appropriate commands to diagnose and repair your Windows XP installation. From here I would try "chkdsk /r" and "fixboot"
For a list of commands that are available in Recovery Console, type recovery console commands or help at the command prompt, and then press ENTER.
For information about a specific command, type help commandname at the command prompt, and then press ENTER.
6.To exit the Recovery Console and restart the computer, type exit at the command prompt, and then press ENTER.
Once you've done this restart the computer and see if it boots up.
Apr 08, 2010 | HP Compaq Presario V6000T PC Notebook
Tried to do a restore with restore disc that came with the comput
There seems to be a problem with the operating system that is being installed. This often happens if you use the restore disks that came from another computer.
Are you sure that you used the disks that came with that exact computer? Does it flash a blue screen right before restarting the cycle?
Try the restore over again and if the problem persists, you may have to either order new restore disks for your computer or buy a fresh copy of Windows XP.
Apr 11, 2009 | eMachines T3604 PC Desktop
Acer 7720 will not boot
Do you want to try and see if a 'Linux LiveCD' boots? This is the way I test if the computer works. You burn this CD to a disk, and then boot off of it when you're computer starts. I will not modify anything on your computer as long as you go to 'Try Ubuntu with out installing'
http://www.ubuntu.com/getubuntu/download
Don't worry, I'm not trying to get you to install anything, just see if it boots into the 'live environment' (means you are running it off of the cd) If this works, that means that it is only your windows installation is messed up, and a reinstallation of windows should work fine with a Windows install CD NOT the recovery cd.
Jan 31, 2009 | Acer Aspire 7720 Notebook PC
AVG 7 detecdted Virus Hurri on partition table. How do I remove ?
You will need to fix the master boot record with the Windows XP Recovery Console. To do this, you will need a Windows XP install CD.
Here are the steps to use the recovery console:
  1. Insert the Windows XP startup disk into the floppy disk drive, or insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
  2. When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
  3. If you have a dual-boot or multiple-boot computer, select the installation that you must access from the Recovery Console.
  4. When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
  5. At the command prompt, type the appropriate commands to diagnose and repair your Windows XP installation.
In this instance, the correct commands are:
c:\fixmbr
c:\fixboot
The type exit after finishing then remove the Original OS CD.
The machine will reboot properly.
This will fix your boot sector
And All should be well
Dec 28, 2008 | Microsoft Windows 98 for PC
Cannot recover my emachine t3104
You should contact the support center for your problem, it sounds like the CD for the recovery is corrupt, long with a possible HDD failure, try doing a clean install of windows(if you have a Clean install disk) if you don't, try calling the eMachines support number.
Oct 07, 2008 | Computers & Internet
E-Machines eMachines Desktop PC Logo
715 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
