I installed the latest Flash player and then installed Channel 4`s 4On Demand television service to watch their archive of programmes.
But the 4oD player clashes with the Flash player - giving me a 1904 error message.
They tried to help (see image) but nothing has worked.
Can you help?
Your time much appreciated.
Art.
Their instructions:
"Windows Vista
1. Download and Run the file from the link below:
http://download.macromedia.com/pub/flashplayer/current/uninstall_flash_player.exe then follow the instructions, including any User Account Control prompts which appear
2. Download and Run the file from the link below:
http://fpdownload.macromedia.com/get/flashplayer/current/licensing/win/install_flash_player_active_x.msi
3. Open your Start Menu.
4. Under “Start Search”, type cmd.
5. cmd.exe should appear in the results box.
6. Right-click on cmd.exe and select “Run as Administrator”.
7. Follow any User Account Control prompts which appear.
8. In the cmd window, type in:
regsvr32 c:windowssystem32macromed lash lash9e.ocx
9. Press Enter
You will then receive a configuration message.
(If you get an error code 0x80070005 then you need to ensure that you used ‘Run as Administrator’ to launch the cmd window)."
**When I tried this the flash9e.ocx file could not be found. Sure enough, when I dug into the system files it wasn`t there. I`ve tried reinstalling Flash but still no 9e.ocx file. There is a file flash9f.ocx
I am using vista premium and whe i play a game that requires flash, even though i have flash 9 installed it still shows that flsh.ocx is missing , help!!
same 4od is B$ it worked perfectly and then all of a sudden boom its fucked
same problem, it loads the adverts fine but no actual programme
Same problem here. Had it a week ago, re-installed flash on my laptop and that made it work but a week on and both laptop and pc won't work
