Question about Car Audio & Video
Subwoofer has power but will not have sound - Car Audio & Video
  • 17,130 Answers
If you meant that the subwoofer amplifier has the power in then we need to check the amplifier.If your subwoofer speaker is ok after testing with an 1.5 volt cell then you concentrate if the amplifer has packed up., After testing for fuse, speaker connection, speaker wires. you will have to check if your power amplifier output has failed. Since you have not mentioned the make/model i am not able to pin point but you may open and test for damaged output transistors, components and replace accordingly only if you are competant. Hope I could help. Good day
Posted on Jul 06, 2010
Subwoofer not working
The subwoofer is dependent on a sound amp powered by an external source whereby the speakers are powered by the line output from the sound source (like a computer speaker out jack). Powered Subwoofers controlled by a power amplifier require a power source such as an AC/DC source plugged into the house power. If the device is defective or a mismatch, the subwoofer will not function. Try a new power transformer and see if that fixes the problem. Other than that, if the power transformer is good, then the woofer could be defective.
Jan 13, 2014 | MA Audio MA5137 700 Watt 5.1 Home Theater...
Paradigm pdr80 no sound
If it is a powered sub, the sub power supply may have failed. There might be an open fuse.
Dec 25, 2013 | Paradigm PDR 12 Speaker
Subwoofer and amplifier wattage problem
No it will sound good if you can put an amplifier with 500 watts rms it will sound better
Jan 27, 2010 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
No Soound on Subwoofer from Yamaha RX-V363
I have the same setup. Are you going out of the subwoofer output of the reciever? (it's purple.) then into the LFE jack of the subwoofer (also purple.) That's the only connection you need besides power. If you have those right, try using your cable for something else to make sure the cable is good. Is the indicator of the subwoofer green? Mine comes on with the reciever. Good luck!
Mar 31, 2009 | Yamaha RX-V363 Receiver
No sound out of subwoofer
Connection from receiver subwoofer output jack RCA plug male go into your powered subwoofer low level input with other end of cable, then you need to select Subwoofer YES/NO on the JVC receiver speaker setup menu option, select YES if this is a powered subwoofer you are using, should power up the subwoofer, may have to adjust a test tone balance for multi speaker output also, try trimming up on the subwoofer channel to initiate the signal on if the sub has an auto-on feature.
Feb 07, 2009 | JVC RX-5020VBK Receiver
Subwoofer not powering enough (Sounds like under powered 8inch)
get a nice monster subwoofer cable and a Subwoofer PowerCenter™ SW 200 with Clean Power™ Stage 1 get it from like amazon and you'll definately see a difference and also put the sub in like a corner
Jun 08, 2008 | JBL S120PII Subwoofer
Subwoofer has power but not getting sound
Some ideas.
Blown fuse in the amplifier section.
Dead amplifier
Dead speaker.
Amp is not that expensive, call Velodyne
Apr 29, 2008 | Velodyne CHT-10 Subwoofer
Subwoofer power but no sound
sony suks.is it a powered sud?if not take any battery and touch the leads on the speaker if u get a sound speaker is workig.
Dec 06, 2007 | Sony Xplode P5 Turbo Subwoofers Car...
No sound coming from subwoofer
sometimes these subwoofers are for builtin amplified subwoofers..so if this is the case it will not work
Oct 25, 2007 | Sony STR-DG510 Receiver
Subwoofer - no sound
Had the same problem when mine first arrived. Unplug and replug the power cord at the back of the woofer. Worked for me!
May 16, 2007 | Harman Kardon HARMAN/KARDON SOUNDSTICKSII...
Car Audio & Video Logo
63 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
