Question about HP Color LaserJet 2600n Printer
I get a black line on my paper when I print. How do I get rid of it?
    Champion:
  • HP Expert
  • 202 Answers
Check the scratches on black tooner if it persists then replace the tooner & calibrate the printer ur problem will be resolved
Posted on Jul 14, 2010
  • hannah_ba467 Aug 31, 2011
    Very very Helpful. Thanks. I work in a busy Hospital with a shortage of technicians available all the time.
There is a horizontal line grey in color
If this a P2035 printer using a toner cart with a drum in it. The drum has been exposed to light or has a smudge on it. take the cart out and look at the drum. This is a round light blue tube located at the bottom of the cart. It is the drum because it is the only thing in the printer that will print a defect three times on the paper. You could also print about 0 black sheets of paper through the printer and it will go away. This is because the drum coating is in layers like an onion. You must get rid of the exposed layer to get to on that has not been exposed to light.
Apr 02, 2014 | HP P2035N LaserJet Monochrome Printer
How to get rid of the vertical black line on the paper?
Usually replacing the toner cartridge fixes that problem. Sometimes it's the fuser.
Jan 20, 2014 | HP LaserJet 1018 Printer
I have tried everthing in "Lexmark X5495 Help"
Sounds like you just need a new printer. Some times the encoder wheel can get dirty with aerosolized ink and it will start to skip lines. The encoder wheel is a small plastic wheel on the paper feed of your printer. Around the edge of the wheel are hundreds of small thin black lines. As paper goes through the printer it counts these lines as the wheel turns to know how far to push the paper. If ink or debris gets between the lines over time it can start counting two lines as one and thus advance the paper too far, causing blank space between prints. See the below picture of a printer encoder wheel for reference. My professional opinion is to not purchase Lexmark. New Canon printers are very reliable with a high quality output, look for one that uses CLI-221 cartridges. Or most any HP.
Oct 29, 2010 | Lexmark X5495 All-in-One &USB...
Re: Canon Pima MP500 Printer.Despite running cleaning settings for print head and rollers ectc,I am still getting a 1cm wide line of black ink through the length of the reverse side of printed pages....
On back side of printed paper?
It means that you have an ink in paper path, i would ques on registration roller (long black roller which you can see when you open the printer cover).
Try to print 20-30 white sheets or similar to get rid of stripes
Jan 18, 2010 | Canon Pixma MP500 All-In-One InkJet...
Light lines down middle when printing black
try to clean the class of the machine, if its still there, this means the black drum is scratched since its fine with other colors, to test it very good open the document feeder(put it up) and hit start buttom(without putting anypaper on class), black paper will come out, check if the line there, if yeah, change the black drum.
let me know wat happen Regards
Apr 24, 2009 | Samsung CLX 3160fn All-In-One Printer
HP 2600n has black lines that run on right side of page
open the front door and wipe it off with a paper towel
slighty close the door until it opens the toner cartridges verify each cartridge is clean. If this is not the issue remove paper feeder from under the printer and verify it is clean also.
Jan 22, 2009 | HP Color LaserJet 2600n Printer
PAPER PRINTING OUT WITH BLACK LINES AND MARKS
When coping I have a black line down the left side of the page. This only happens when I'm copying NOT when I'm printing off a document from Word or the Internet on my computer. How can I get rid of this black line?
Aug 14, 2008 | Office Equipment & Supplies
Printer/Scanner Problems
Does the line show up on PRINTS FROM YOUR COMPUTER also, or only when SCANNING A DOCUMENT? If the line is only from scanned documents, the SCAN GLASS has something stuck on it. The SCAN GLASS is a GLASS **** located under the ORIGINAL FEEDER. It is NOT the plate of glass you place the original on . Look UNDER the original feeder for a scrap of paper stuck in the optical path of the GLASS ****, and remove the scrap, or CLEAN THE SCAN GLASS IF CORRECTION FLUID, INK, ETC ARE STUCK ON IT. If the line shows up on ALL prints, your CHARGE CLEANING SLIDER located in the IMAGING (DRUM) UNIT must be slid all the way to one end of the charger, OR IT WILL CAUSE A BLACK LINE ON ALL PRINTS. Otherwise, the IMAGING UNIT may need to be cleaned or replaced. Toner smudges on the drum would indicate need for cleaning or replacement.
Aug 12, 2008 | HP OfficeJet 9120 All-In-One InkJet...
Black ink
I called the local Canon printer repair facility, and a serviceman said that the black line is caused by too much ink in the ink absorber device below the paper path. He said to fix it requires disassembling part of the printer, replacing the absorber foam, installing a longer tip for the excess ink, and reassembling and testing the printer. I asked if this would be a permanent fix. He said no, that the problem could reoccur as the absorber foam would eventually fill up again.
Aug 06, 2008 | Canon Pixma MP500 All-In-One InkJet...
Black line vertically on scanned/printed documents
This problem can be caused by a number of different issues. If it occurs when you copy, check the scanning glass to see if there is any dust/gunk on the scanner glass. Also if you machine has a document feeder than you need to check the **** glass that the paper feeds past.
If it occurs when you print than you probably need to clean your printer. Check your manual for exact details on how to clean your printer but in general it could be on a paper feed roller or it maybe something on the drum. If you let me know what printer this is happening on I can direct you to a manual if needed.
Henry
Apr 22, 2008 | Office Equipment & Supplies
HP Color LaserJet 2600n Printer Logo
203 people viewed this question
Seeker5211
Seeker5211
