Question about Meade 70AZ-TR Telescope
Viewfinder views things backwards
Why does my small viewfinder views everything backwards? Is it how it is supposed to be?
  • 3,186 Answers
Yes, most finder scopes show upside down images, it's completely normal.
This is an astronomical telescope. Even the main tube shows upside down images unless you use what is called an "erecting prism" for terrestrial viewing.
Posted on Jul 06, 2010
The viewfinder on my Panasonic PV-DV200 needs to be cleaned. I have the instruction manual but I cannot get it to turn the 1/8 turn recommended to remove
Hi, My PV-DV200's viewfinder needed cleaned too. Try, try and try again. The entire viewfinder assembly will turn, but if it's never been removed before, it will be on extremely tight. My viewfinder has a small notch at about 1 'o' clock on top. That notch needs to be turned to about 11 'o' clock. Once there, the viewfinder slips off easily. It will come off much easier from then on.
However, simply cleaning the removed viewfinder may not be enough. You may also need to remove the two small screws on the underside of the piece that's still attached to the camera in order to get inside there and clean that too. I removed the small rectangular glass and cleaned that and behind there as well. I used a Rayban cloth (needs to be lint-free) and some Plexus, along with a dull pencil in order to get everything cleaned all along the sides of each lens.
Just double check and make sure all parts of the viewfinder are clean by slipping everything back into place prior to screwing it all back on. This will save you some time because you will probably not get everything cleaned on your first attempt.
Hope this helps!
Nov 16, 2011 | Panasonic PV-DV200 Mini DV Digital...
When I look through the eye hole of the Canon Rebel t1i, the view and numbers of the eye hole are blurry even though everything is auto focused, and when I take the picture, it's clear. Why is the eye hole...
There's a diopter adjustment knob just to the right of the viewfinder. Turn it while looking through the viewfinder at a blank wall until the numbers in the viewfinder appear sharp. This knob allows the camera to adjust for individual eyesight.
Dec 23, 2010 | Canon PowerShot A70 Digital Camera
When I look through the view finder window. Everything that I see is out of focus...even the little numbers at the bottom. The pictures come out fine in Auto focus, but in any other mode, I can not tell...
Okay looking at the back of the camera where the viewfinder eye piece is right side upper corner you will see a small wheel partially covered by the rubber rim of the viewfinder by the side of it you will see a small line with a + and - that is a diopter that actually tunes the camera viewfinder to your shooting eye. Pretty fancy eh? Anyway what I do is set the camera in auto focus and focus on an object in a brightly lit room and when the little green light come on in the lower right corner of the viewfinder which is the auto focus confirmation light start turning this wheel one way and another until the image you see come into sharp focus. I don't know about you but I need about three clicks to the + side before everything looks sharp.
Dec 20, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
Why wont the image come up on my LCD on the D40 when i turn on the camera
Because it's not supposed to. The LCD on the D40 is for menus, shooting info, and image review. It takes pictures the same way SLRs have done for half a century, allowing you to view and frame through the viewfinder. Only more recent dSLRs (and not all of them) have the Live View feature allowing you to use the LCD instead of the viewfinder.
May 05, 2010 | Nikon D40x Digital Camera
The viewfinder is not acculimented with the telescope. what i see in the viewfinder is not visble in the eyepeice of the telescope what i see in the viewfinder isnt in view in the scope . how do i...
Point the scope to a distant object like the top of a telephone pole.
Without moving the telescope adjust the small screws on the finder scope to LINE-UP on the same object.
Nov 21, 2009 | Meade TeleStar 60AZ-A Telescope
Blury view finder
On the left of your viewfinder you will find a small knurled wheel. By turning this wheel you adjust the diopter settings of the viewfinder. You probably accidentally moved it and didn't know it.
Aug 11, 2009 | Olympus SP-550 UZ Digital Camera
Fuji s9100 Blurred view in the viewfinder but reads okl on lcd?
Look on the left side of the viewfinder - there's a small dial which you can rotate to adjust the viewfinder. I hope that's the problem. If not, please let me know, it's just that the problem description is quite poor.
Tom
Aug 01, 2009 | Fuji FinePix S9100 Digital Camera
I look through viewfinder and view is out of focus
Yes, common problem, small plastic tab(s) connecting viewfinder to the zoom are broken.
Apr 17, 2009 | Olympus Stylus Zoom 140 35mm Point and...
Optics Logo
241 people viewed this question
Top Meade Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Greg Cann
Greg Cann
Jerry Greenberg
Jerry Greenberg
Are you a Meade Optic Expert? Answer questions, earn points and help others
