Question about IBM Computers & Internet
I have an ibm thinkpad with a brand new battery, first time i put battery in it charged up good as, did not use computer for a month, now battery dead and will not charge?????? please help. it has a new li-lon battery.
    Master:
  • 742 Answers
Try a diffrent battery. if second battery charges then your battery you got is defective.
Posted on Jul 06, 2010
My new compatible battery 02K6626 is not charging in my T20.
You can buy a completely compatible IBM ThinkPad T20 battery. Search in Google for the model of you wanted battery,then you always can find some best online laptop battery shop which have a high fame and have running for some years ,they provide both good batteries and service.
Apr 29, 2010 | IBM ThinkPad T20 2647 Notebook
Dead thinkpad by ibm
The CMOS battery supplies energy to the Real Time Clock when the computer is not connected to the electrical socket, and does not have the battery inserted. It should not prevent the computer from starting up. You will however be asked to reset the time and date of the computer.
Hope it helps.
Oct 03, 2009 | IBM ThinkPad R50e Notebook
IBM ThinkPad R40
The battery indicator showing a yellow or orange indicates that the battery life is over. You may have to purchase a new battery.
Regarding the place where you can find information about these is that it is universal that the orange indicator means the battery is faulty.
Sep 13, 2009 | IBM ThinkPad T40 2373 Notebook
My IBM Thinkpad T22's battery doesnt last. can i fix that?
Basically you need a new battery. Recharageable batteries have a finite number of charge and discharge cycles and they lose their full charge capacity as the get older. The batteries will have less capacity over time ie less available battery time, and when it is worn out, it won't charge at all.
May 15, 2009 | IBM ThinkPad T22 2647 Notebook
Starting ibm 600e
Hi there.
Errors 161, 192, 163.
All three of these errors are connected to the back up battery.
To resolve this problem:
1. open memory flap on base of laptop (small philips screwdriver required)
2. find the small connector with 1 black & 1 red wire coming from it.
3. disconnect above connector and gently pull the Red&black wires. The backup battery should just pull out from under the casing.
4. get replacement battery. Either
a. call IBM spares (07900 247 490 in UK) and ask for FRU:
02K6502. UK price is about £8 + £15 delivery + VAT.
b. if comfortable with soldering iron: Carefully open the packaging on the backup battery using a sharp knife.
Remove the solder tags from the battery (these are spot welded so need to be cut/broken off). Buy a new CR2025 battery from any computer shop, jeweler, or camera shop.
Using electrical tape, insulate all round edge of battery
Solder the leads onto the new battery - note polarity. Red wire to +, black wire to -.
Using more insulating tape, wrap battery so that all exposed metal is covered.
5. put new battery into laptop (reverse steps 1-3)
6. start up computer, error 192 has gone, but still shows 161, 163. Select OK.
7. reset date & time, and OK
8. when screen shows 'O / I' restart laptop using on/off switch at side.
Good luck and thanks for using FixYa!!
Mar 05, 2009 | IBM ThinkPad T21 Notebook
Charging new battery
usually 8 hours.
for first charge.
on a brand new battery
Jan 29, 2009 | IBM ThinkPad T41 Notebook
IBM Thinkpad T22 Battery
pls first check your adapter may be problem with your adapter.
thank you
Sep 28, 2008 | IBM ThinkPad T22 2647 Notebook
X41 Tablet PC the battery shows good but computer will not work
Some times a battery can pickup a dead short, and even though it shows a charge it will not work. The other possibilty is the power management chip on the mother board. This chip allows the computer to charge the battery and switch from battery to AC. (Right now I have a Thinkpad that will only run on battery, bad PM chip) Try replacing the battery first, if that doesn't work, then unfortunately the motherboard will have to be replaced.
May 24, 2008 | IBM ThinkPad T40 2373 Notebook
IBM Thinkpad A22e Shutdown early on full battery
First, you should clean the battery terminals. You can scratch the terminals with a metal and then charge. Secondly, you should change your battery, that is, buy a new battery.
Aug 15, 2007 | IBM ThinkPad A22e 2655 Notebook
Computers & Internet Logo
47 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
