Question about Homelite Mighty Lite Lawn Trimmer
What is the air gap for my magneto on my 25cc homelite weeater?
    Sniper:
  • 56 Answers
Should be around .013 to .014. turn flywheel until magnets face magneto insert your feeler gauge and loosen magneto screws...let the magneto stick to the feeler gauge and the magnets... re-tighten the screws, remove feeler gauge, and you should be set...hope this helps. ;-D
Posted on Jul 06, 2010
2 Suggested Answers
moretons
  • 155 Answers
SOURCE: Homelite Mighty Lite Lawn Trimmer Magneto Air Gap setting 25cc
Normall setting is 10 thou but if there is no play in the crank bearings you can set at 8 thou
Posted on Jul 26, 2009
What is the gap between magneto and flywheel,homelite,super ez chainsaw
0.3mm is a pretty standar air gap for most machines
Dec 11, 2012 | Homelite Garden
Need to know the spark plug gap for Homelite 25cc Model UT-20779
The spark plug gap should be set at .025 to .030 inches for trimmers. Try to set gap closer to .025.
Aug 04, 2011 | Homelite Curved Shaft Trimmer Bump Feed...
Have a 16" Homelite super
Air gap 0.3mm and plug gap 0.5mm
Apr 21, 2011 | Garden
What is magneto air gap on 25cc gas homelite blower?
It should be set at about the thickness of a standard business card. That is .010"-.012" I usually just double over the card and let the magnets on the flywheel pull in the coil legs and lock the screws down at that point. Non-metal feeler gauges are helpful here because of the magnets if you choose to go that route.
Nov 23, 2010 | Troy-Bilt 31cc 2-Cycle Gas Powered...
Homelite U2T608 edger/trimmer will not start. New plug gaped properly. Dropped carb, dissembled and cleaned out all ports. Fuel is flowing and is new. Motor wont even "cough." Suggestions?
Check the magneto for spark. Remove the plug and reinsert the wire and hold it against the engine as you pull the starter. You should get a nice, blue spark. If you don't see one, the magneto to flywheel air gap may need adjusting or the coil module is bad (rare). You basically need good compression, fresh fuel, good clean air intake, and a strong spark to get it to "pop." I realize you may know these things, but, most people are unaware of the .010"-014" air gap required between the magnets on the flywheel and the legs on the coil module. Disassembly is required to get to it and you take the same steps you would if you wanted to fix the pull rope. A standard business card has about the proper clearance needed between the aformementioned parts. Post back if needed. I am here to help.
Oct 12, 2010 | Homelite Garden
Homelite trimmer UT20832
The gap on my 18 year old Homelite ST-185 is 0.025. Since they are still using simple and reliable magnetos, yours should be the same.
Jun 27, 2010 | Homelite Mighty Lite Lawn Trimmer
I need the gap setting for the coil on my homelite weedeater 25CC 'Easy Reach'
As small as you can without fouling the flywheel. It should work with anything up to a 20 thou gap, so if you set it to 10 thou and no spark, then you need to replace the coil..
Sep 08, 2009 | Homelite Garden
Jun 23, 2009 | Homelite Mighty Lite Lawn Trimmer
Set gap on magneto
use an index card or piece of manilla envelope
Sep 12, 2008 | Craftsman Convertible 25cc. Gas Line...
Homelite Mighty Lite Lawn Trimmer  Logo
347 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
