Question about ViewSonic VX2235WM Monitor
Monitor flickers on and off
My monitor flickers on and off, just started today havnt had it for that long maybe less then 2 years. it does it while its off or when i logg onto the computer and im using it.
  • ViewSonic Master
  • 17,130 Answers
You will need to open the set by removing the screws fromthe back side, before this reduce the contrast and brighness to a lower level and see of this flickering has reduced. If not open carefully, you will see the power and the drive boards. Check on the power smps unit for any loose connection in the Switch mode section, solder if there is any suspected joints.some connectorrs in this section also must be checked and fixed. next check on the drive board, check the connections of the high voltage to the panel, fix the connectors, clean any dirt on the tracks and tighten the connectors. If this do not resolves the issue you will need to power on and test the voltages, find the flickering leading to the circuit in question.replace. Helpful. Good day
Posted on Jul 06, 2010
    Master:
  • 742 Answers
Power supply is more than likely going to need some new capictors. if you can solder its not a hard fix. just look at the power supply and look for swollen caps.
We have had this monitor for about a year and it just started flickering with dark colours. How can we fix it?
If it is less than one year, then contact ACER, and exercise the "warranty" to get it repaired/replaced at _minimal_ cost to you.
Mar 06, 2011 | Acer AL1916W 19" LCD Monitor
Acer Laptop Screen Flickers & Jumps
Please connect the laptop to an external monitor. If no flickering on monitor screen, from my previous experience, this is more likely loose connection of video cable connected to the LCD. So talk to Acer support again and require the replacement of LCD.
CompQ
May 11, 2010 | Acer Aspire 6930-6082 Notebook PC
The monitor is only 2 years old. less then 50
If you left it plugged into the outlet, the power supply is still running 24/7 even you never trun it on! Look inside for bad caps first, see example of failed SAMSUNG monitors: http://s807.photobucket.com/home/budm/allalbums
Jan 24, 2010 | Samsung SyncMaster 932GW LCD Monitor
Screen flickering on and off.
I have the same problem with mine. I've kinda narrowed it down to it being the power supply in the monitor. was told it is about a $20 fix but we'll see
Nov 16, 2009 | Samsung SyncMaster 731B 17" LCD Monitor
My HP w1907 monitor less than a year old is turning pink!
A flickering screen with pink colour is a sign of a CCFL lamp problem.
The CCFL lamp is a mini fluro tube and it provides the back-lighting, it is definitely faulty and about to fail completely.
You need to get it repaired while it is still under warranty.
Oct 05, 2009 | HP w1907 LCD Monitor
I have noticed recently that the screen words flicker.
If the monitor is less than a year only, then your best bet is contact the manufacturer for warranty support.
http://www.acerpanam.com/synapse/forms/webpage.cfm?siteid=7117&areaid=2&website=AcerPanAm.com
Jun 14, 2008 | Acer AL2017 20" LCD Monitor
Blueish flickering
Try to put speaker distance from monitor.
Try to remove the display card and fixed it again.
Then boot up your and see .
Apr 21, 2008 | Acer AL1913 19" LCD Monitor
HD19A / 19-Inch light flickers but no display
One of 2 possibilities come to mind.
1,  The vga chord is loose on the back of the monitor.
2, Your resolution is set too high or low to be displayed.
The blinking light means that the monitor is either not getting or understanding a signal.
Hope this helps.
Oct 12, 2007 | Microsoft Likom HD19A 19" LCD Monitor
Flickering crispy screen
maybe ur screen was put into a lot of magnetic interference. so check for any magnetic rays emitting devices like speaker adapters etc. a simple check would be to degauss( its in the screen properties). raja
Feb 28, 2007 | LaCie Electron IV 19" CRT Monitor
ViewSonic VX2235WM Monitor Logo
180 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
