Question about JVC THD-50 System
I have jvc-th50.the power is burn.possible to fix it? how to make it working again?
  • JVC Master
  • 17,130 Answers
This depends on the extend of the damage.If the board is carefully analysed and if you can sort out the damaged parts take a reading. Check the ouputs that have failed, check into the next stage below till you come to see that all the componets that were burned were identified. If you are able to idetify the value of the burned components, there is no issue but if not we have a real issue.in this case you must seek help with a servicea manual .If only thepoweer transistors/ resistors have blown you can go for the replacement provided you feel confident to go along after the components are replaced.In the first place I never asked how this had happened. was it overloading or otherwise? hope I could Help. Good day.
Posted on Jul 06, 2010
No power on my JVC Kaboom
I would rule out the power supply simply because the batteries won't run it either. The internal plug that takes the cord should be checked for cracked solder joints, because the plug goes to battery mode when cord is removed and AC fuction when cord is plugged in. It is possible it may be an audio output problem given the age of the item.
Feb 12, 2012 | JVC KABOOM RV-NB10 Boombox
Hi i have a jvc lt-23x475 tv and all i get is sound no picture the on off button doesnt work neither do the volume or channel buttons what can i do to fix it and would it be worth it to fix it and how much...
HI,
Normally when there is sound and no picture there will be problem with the back light inverter board. But in your case not only the picture also you can't be able to adjust the volume, Power or the channel. So fist of all you have to check the power supply board for any budged capacitor. Watch the first picture you can see the budged capcitor. If there is such capcitor replace them and check again. Remember one thing unplug the power cord and leave it for half an hour then only remove the power supply.
If there is no such capacitors then the problem is with the main logic board of your tv. There is no repair possible with the main board. You have to replace the board. You can buy the main board from the authorise servicing centre for jvc. The authorised servicing center will be relable source.
Oct 26, 2011 | JVC LT-23X475 23 in. EDTV-Ready LCD...
JVC LT-40X776 will not turn on, electrical outlet is good, remote is good. If you unplug it and reconnect it, the TV will turn on for 1-5 seconds and then turn off by itself and then it will not turn on...
Probably an issue with the power supply. The TV circuitry is set to protect the components when something is broken. Sometimes, it can be the fuse on the power supply board, and sometimes the capacitors burn up. If the TV is under warranty, take it in for service. If it is not, you may try to fix it yourself by first checking the fuse and then checking the capacitors. If you aren't familiar with electronics, I suggest you let someone who is a professional look at it. Good luck!
Oct 09, 2010 | JVC LT-40X776 40 in. LCD HDTV
Jvc 70' lcd tv. power indicator light flashes fast upon power up. no picture
The lamp is burned out, this is an easy fix. Contrary to what the "repairmen" on this site say, you can do it at home with ease. Just type your model into a search engine and order your lamp, they come with great instuctions on how to install.
Dec 21, 2009 | JVC HD-70FH96 70" Rear Projection HDTV
Firmware crashed, unable to get repair in UK
I also have a faulty unit with discs that hadn't yet been finalised. You can access the discs via your PC. I used a program called IsoBuster by Smart Projects. There is a free demo which you can download. Just google it.
As for the faulty power supply, just scrap the unit and DON'T buy JVC again. Eventually, they will have to listen to the economies of scale.........
Sep 18, 2009 | JVC DR-MX1S DVD Recorder/VCR
Loading is flashing and can not do anything
my machine just has loading displaying in a flashing mode
Jan 29, 2009 | JVC DRMH20 DVD Recorder
After a power surge My Jvc Av-56wp74 big screen Tv won't come on.
 Try this: Works with most crazed computer based devices.Remove power (unplug) unit for 1 minute then plug in
Dec 14, 2008 | JVC AV-56WP74 56" Rear Projection...
Communicating error when using battery
yes am just using my cam and suddenly that error occurs. yes am using original JVC data battery. anyways i already brought it to a jvc service center and it's already fix. they're not so clear what really happens but they got it running again after 5 weeks in their hand.
Sep 29, 2008 | JVC Everio GZ-HD7 Camcorder
Jvc dv mini camcorder
Possible simple fix: disconnect; turn camera off; connect; turn camera on. Also possible that the main USB/FW interface chip has died, in which case service is required.
Jun 20, 2007 | JVC GR-D250 Mini DV Digital Camcorder
JVC KD -S680 needs help
all radios like your has two power inlets one is battery and the other is Acc or Ing. The battery line keeps power in the radio after you turn off your car both lines must work for the radio to turn on it sounds like a resister burn out thats why your face plate was warm.
Sep 25, 2006 | JVC KD-S680 CD Player
JVC THD-50 System Logo
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
