Question about Akai PT46DL10 46" HDTV-Ready Television
No picture Akai PTDLP46
Green power light keeps flashing at warm up, no picture. Replaced light bulb with no results. Hate to trash tv , do not want to put alot into it unless it is something minor. Thanks
for any help.
  • 1 more comment
  • January15 Apr 19, 2008
    got the same exact problem, i turn on the tv and it shows the green light flashing constantly. I tried unplugging it and plugging it back up before when i couldnt get any picture, and it seemed to work fine before, but not this time. Picture just wont come on!
  • Anonymous May 22, 2008
    Same problem, green light flashing but picture will not come on (on rare occasion will come on) Took to good tech who looked at it and said probably "driver" (ballast or starter) but cannot find manual or schematic to get parts. Tech says he thinks it is made by Samsung and may be easy fix if had manual or parts. Anybody have any more information?
  • vingee57 Jul 28, 2008
    Green blinking light after replacing the lamp. Need service manual and possible solution.
It may be the ballast , I've the same problem in here in quebec, and i don't know where i can buy it. the part number is P306-0022. Normal Cost is $199.99
Posted on Jun 10, 2008
When turning on the tv by either remote or switch on side screen will flash blue then turn off. Have unplugged tv still won't turn on.
Search Results
    Samsung TV Keeps Shutting Down - Forums - CNET > Forums > Samsung
    CNETWhen I turn the TV on for the first time each day it shuts itself off within 30 ... There is ablue kill switch there, but you don't want to fool with that. .... The tv will not turn offwith the remote or the side buttons on the tv. .... I replaced the lamp but the tv screen will have a momentary flash of light on the screen then it will turn on and ...
    Philips/Magnavox Tv Problems ? - Home Forums > Home Forums > Electronics
    Mar 26, 2005 - I turned the tv on then off a few tims then eventually the piture would come on. .... time, the LED will flash continuously along with the volume going up to max. ...... You can use the remote to turn the tv off and on but nothing else. ... If you press the power button over and over it stays on a blue screen but as ...
    Top 208 Complaints and Reviews about Akai ' Page 3 > Electronics > Televisions
    Rating: 1.9 - ‎37 votes
    The screen will not turn on with the remote, side switch or rocker arm. .... It will flash for a second and the blue Akai screen will display very briefly, but then .... Akai LCT3201AD TV does not turn on using either remote or power button. ... I turned itoff one night and the next time I turned it on, the green light came on, but it did ...
    Get help with audio, video, or power on Apple TV - Apple ...
Jan 28, 2016 | Televison & Video
The power light keeps flashing red and green the tv wont show picture or sound
Usually this is a case of bad bulb. While having this replaced have all fans cleaned of dust including projector assembly.
Jul 02, 2010 | Hitachi 43FDX20B 43" Rear Projection...
Nov 02, 2009 | Akai PT50DL24 Television
Akai, PT46DL10 Has sound, no picture
make sure all componet cables are in the right color coded spots on the back or side of the tv and you are on the right componet if using a cable box make sure using componet / monster cables not all cable companies support hdmi if that is how you are trying to hook up make sure to check with them
May 14, 2009 | Akai PT46DL10 46" HDTV-Ready Television
Akai pdp 4294 wont turn on
The power supply board needs to be replaced or repair. No other quick fix is available. Thanks
Nov 26, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Akai PT50DL24 50 in DLP Rear Projection TV-NO PIC OR SOUND
check for popped or raised tops on caps in power supply. also try unplugging set for 5 minutes and resetting it. How about does your color wheel spin up? if your color wheel don't startup then your tv will also shut down. also check all fans they all should be running at turn on. if all fails i would say its your light engine.
Apr 10, 2008 | Akai PT5598HD 55" Rear Projection...
Akai dlp
i have a similar tv, with 5 blinking red lights on the power off. is that a power board issue? (I see the small green light ionside the tv, flashing green.,,) the outer light stays red or flashed red when i power off. i replaced the fuses, still same issue.
Mar 18, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Green flashing light - no picture
If the green power light is blinking and you have no picture, then your light bulb has burned out and needs to be replaced. It is not a cheap bulb to replace. If the TV is less than 1 year old it should be covered by the warranty
Nov 03, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Akai TV troubleshooting
I have the same problem. My Akai 27" flat screen shuts off inconsistantly. Sometimes it will stay on for hours and then we have to turn in on every 2 minutes. It seems to be getting worse. Is there anyone who has found a way to fix this?
Oct 19, 2007 | Akai LCT2715 27 in. LCD Television
Same problem as this poster
i had a similar problem and it ended up being the bulb. The indicator light never lit up but after i replaced th bulb I checked to see how many hours where on the bulb and it was over 8100. they state the bulbs are only good for 6000. when i replaced it ($140 on ebay) everything was fine.
Sep 09, 2007 | Sony Grand WEGA KDF-55XS955 55" Rear...
Akai PT46DL10 46" HDTV-Ready Television Logo
202 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
