Question about E-Machines eMachines Desktop PC
System starts up but goes to blank screen - E-Machines eMachines Desktop PC
  • Keith Carroll
    Keith Carroll Jul 06, 2010
    i do not have the disk only made recovery disk which do not work . i went and bought fix it utilities 10 but cant get it to work.tried to order disk from emachine but a whole week went by and they havent shipped them
  • Keith Carroll
    the screen works just will no load windows . i ca press f10 and itgives me boot opitions but will notloadwindows
  • 942 Answers
Hi! I understand that you have a blank screen. If the system starts up, then most likely your keyboard and mouse lights up, right? And most likely your Desktop CPU tower lights up as well, correct? Then we will analyze why your screen is blank. If the conditions that I have stated are all true, check the monitor. Is it properly connected to the Desktop itself? Is the monitor have lights on it, meaning to say is it turned on? Because there is a separate power button for the monitor. I believe you are using a different brand of monitor, is that right? Then you must make sure that everything is connected properly. You might be able to login to windows but you just don't see the screen. I advise you to shut down everything. Re-check the connections including the monitor, then turn on the desktop. Hope this help...
Posted on Jul 06, 2010
  • 712 Answers
This may happen due to several reasons. First, check if the power supply line to the monitor is loose at any of the two ends. If yes, tighten it. As a simple measure, keep that blank screen and tighten the codes to see if it works. If that is not the case, switch off your system and UNPLUG it. Then open up your CPU and clean all those dusts present there. Sometimes this problem can occur due to moisture present there. So wipe everything with dry cloth. CAUTION: DO NOT USE COTTON. USE ONLY A DRY CLOTH. Before closing down the CPU, take out the RAM(s), wipe it's tip with CLEAN COTTON slightly dipped in spirit (After Shave Lotion will do). Then put back the RAM(s) in position. This is not only to clean it, but also to make it a bit more seated. Now start up your system to check if it is OK. If none of this works, try re-installing the OS. This is a last measure and it can fix your problem, mostly.
  • 2 more comments
  • Keith Carroll
    i do not have the disk only made recovery disk which do not work . i went and bought fix it utilities 10 but cant get it to work.tried to order disk from emachine but a whole week went by and they havent shipped them .
  • Sebin Punnacheril
    Sebin Punnacheril Jul 06, 2010
    Do you mean that you do not have a disk of Operating System?
  • Keith Carroll
    i have windows xp service pack 2 cd.but not emachine disk
  • Keith Carroll
    i have Emachine El 1200-06w with windows xp installed.The computer starts but goes to a blank screen. it will not let me use the recovery disk i made .But the partitions are still there
Blank screen
Try unplugging, remove battery, plug in reboot.
Jun 01, 2013 | MSI Wind UmNotebook
Toshiba blank screen
Sounds like a corrupted OS install. Could be caused by a number of things like: virus, failing Hard Drive, system lost power while doing an update, etc. Very hard to diagnose such a problem without being in front of it.
Sep 15, 2012 | Toshiba Computers & Internet
My nokia 5310 screen goes blank when i turn on my phone it's blank screen Someone--Help me plz.........
i guess ur operating system might have got corrupted .u need to install it again. go to nokia services center
Mar 10, 2012 | Nokia 5310 Cellular Phone
Thinkpad blank screen
Once you run safe mode. You can turn off the laptop. Then start booting normally.
Mar 02, 2012 | IBM ThinkPad T20 2647 Notebook
The monitor goes blank after a few min, it comes
Are you sure that your computer isn't just going into power saving mode? Not sure what operating system you have but go into the screen savers tab or video properties and find out how your system is set up for power saving It may be starting before your screen saver does so the monitor would just go black.
Dec 18, 2009 | ViewSonic PF775 17" CRT Monitor
Laptop screen goes blank randomly
Hi you can try this in Vista
  1. Click Start, and then type cmd in the Start Search box.
  2. In the search results list, right-click Command Prompt or Cmd, and then click Run as Administrator on the pop up contextual menu.
  3. If you are prompted by User Account Control for permission, click Continue.
  4. At the command prompt, type the following command, and then press ENTER: powercfg.exe -h off
  5. Type exit, and then press ENTER.
Windows Xp;
Click Start, click Control Panel, click Performance and Maintenance, and then click Power Options. click the Hibernate tab and unckeck the box and turnoff monitor should be never
Sep 16, 2009 | Acer TravelMate 5520 Notebook
Blank screen problem
hi,
1.Please keep pressing and releasing F8 key when ACER logo is coming.
2.start the computer in safe mode by selecting it in advanced OS choice menu.
3.If started in safe mode go to programs>accessories>system tools>system restore and restore the system to a back date by selecting a bold previous date in calender.
Idf not booting in safe mode also you may need to reinstall the OS again.
Jul 06, 2009 | Acer Aspire One PC Notebook
Laptop freezes restarts or goes to a blank screen
its not the issue with the system
u have a usb printer connected to the system
disconnect that and start the system it should work
Nov 01, 2008 | Computers & Internet
Monitor shows a image uo until sign on screen then goes blank
Does it go blank before you signon, or when you sign on? If before boot to SAFE MODE and check the video display settings.. you man have settings your monitor can't understand.
If that doesn't work and you get to input your signon and then it goes blank you most likly have a virus or malware.
Log into safe mode, and use SYSTEM RESTORE to a time before you stated having the problem.
Start - All Programs - Accessories - System Tools - System Restore
Jul 19, 2008 | Planar Computers & Internet
E-Machines eMachines Desktop PC Logo
153 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
