Question about AEG Lavamat Lavalogic 1600 Front Load Washer
My question concerns Lavalogic1800 - didn't see this option in the list. the machine stopped the washing cycle giving a fault code pnc 110007933 and requests to call a technician. would you be able to help?
3 Suggested Answers
  • 3230 Answers
SOURCE: AEG OKO Lavamat Update washing machine LAVALOGIC 1600
This error code (C3) means your water sensor has detected a leak. it will stop when the sensor is dry.
Try getting the water out of the trap door and letting the machine dry.
I would also unplug it for secirity reasons.
Basically your water pump is getting tired or the sensor is dirty. Try cleaning the sensor or else you may have to change the pump.
Good Luck!!
Posted on May 06, 2009
  • 19 Answers
SOURCE: service manual for AEG 84740 washing machine
Call the company, they just might send you one
Posted on Dec 11, 2011
Whirlpool duette washer stops during cycle beeps and displays error code F
The f should be followed by a digit or two that indicate a particular fault code. A mid cycle stop with a fault code might be because of a long drain time due to a
Faulty drain pump or clogged drain filter but without the entire fault code it’s difficult to give an exact answer.
Feb 11, 2018 | Whirlpool Washing Machines
I am having whirlpool washing machine model-whitemagic FSAN652 during washing machine suddenly stopped working and an error PE is displayed pl give me suggestion to rectify
whirlpool have a good fault code list on the net
go google and type in whirlpool top loader model------ and look for pdf version of manual or fault codes.
Jun 28, 2015 | Whirlpool Washing Machines
Washing machine does not work on any program though stop light and spin speed light are flashing t
The stop light and the spin light flashing are acting as an error code. Have you tried to google what this means? here is a link to candy error codes for that machine...
http://www.ukwhitegoods.co.uk/help/fix-it-yourself/fault-codes/laundry-fault-codes/3319-candy-grando-washing-machine-series-fault-codes.html
hope that helps
Jan 15, 2014 | Candy Washing Machines
Could someone email me the fault codes for a hotpoint aquarius wmf740 washing machine please
Hi I see you need the Fault Codes for your Hotpoint Washing Machine
See this link for the info since I do not have your E-mail to send the details I have created this link for your viewing regarding your concern.
Hope this helps.
Oct 02, 2012 | Hotpoint Washing Machines
Machine stopped mid cycle and green light flashing under green start button
Many modern washing machines display error codes if they detect a fault, but not all washing machines display a readable error code, some indicate an error by flashing, or lighting some of the lights.
Hotpoint, Indesit, Zanussi error codes
Hotpoint, Indesit washing machines and Zanussi washing machines are some common appliances that display coded error codes. On their more expensive models, they display readable error codes but basic models (without digital displays) use flashing lights to convey the error fault code.
If your washing machine malfunctions and you can see some of the lights flashing, or one or more option lights have lit up, then make a note of which lights are flashing and which option lights are lit. NOTE: the error code list engineers have only shows the option lights by number and not by name. Therefore you need to report the lights as LED 1 and 3, or 2 and 4 etc. and NOT "delay timer" and "extra rinse". Count the lights from the left (or from the top if in a column) and report as "led 1 and 3" etc.
No Option lights?
With basic washing machines that have no option indicator lights, count the number of flashes. For example, the door locked indicator may flash 7 times, pause, and flash another 7 times in a constant cycle which would indicate error code 7.
This information is vital, and needs mentioning when reporting a fault.
Jan 18, 2011 | Zanussi FJS1225W Front Load Washer
My whirlpool cabrio washing machine keeps giving me an F1 ERROR when it goes to the rinse cycle. It will complete the wash after i hit cancel reset and wash. Any ideas?
F1(F68)-Pressure Signal Out-of-Range
I telephoned Whirlpool at 1-800-253-1301. Whirlpool acknowledged the F1 fault and will send a serviceman, free parts and labor, to correct the problem concerning the "famous" F1 fault. This is even for washers out of warranty! This concerns model WTW6600SW2 washers. Be sure to get the authorization code from them so the service person cannot argue about costs.
Jan 05, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
OE fault displayed on spin cycle LG 1019BD 10KG WASHING MACHINE
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 29, 2009 | Washing Machines
Good Luck!!
Dec 10, 2007 | AEG L86800 Front Load Washer
AEG Lavamat Lavalogic 1600 Front Load Washer Logo
56 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
