Every 5 minutes my comtrend CT-5071T keeps loosing
Every 5 minutes my comtrend CT-5071T router, keeps loosing internet connection. what shall i do to fix this problem?
  • 17,130 Answers
I think the router has to be reprogrammed but first we chall check for other related errors.First of all assuming that your PC is in perfect state and had been checked to be trouble free you can open up the router. Look out for any dry soldering or dirt within. clean and solder them using a low wattage iron very carefully not to jump any solder joints. Clean the terminals of the router and reconnect. Check also on the poweer connection for any loose connections of the DC or main.When the set cuts off check if there is any power disruption of the source. If you have not checked your PC please check for virus ,using a good antivirus scan,erase all temperory files, cookies, history, or restore to an earlier set point. please give me a feedback if this helps you out. Good day
Posted on Jul 06, 2010
Internet will not go through my comtrend CT-5072T modem
Need a bit more background on this.
Did you just go out and buy this device and hook it up to the phone line ?
Are you using ADSL line Filters ?
Did you ring your internet service provider to guide you through setting up the account settings in the modem ?
How are you connecting to the device to your P.C ?
Jan 25, 2015 | Comtrend Adsl2 Ethernet Router Model:...
How do I ix my adsl2 comtrend modem when the internet light will not come on
If internet light is off, its not connected to the net. Check all connections. If OK try pressing and holding the rest button for 30 seconds.
No ip on comtrend ar-5381u, will not connect to internet
DO NOT INSERT A PAPER CLIP TO RESET THE MODEM! unless you know how to reprogram the router, this includes having complete knowledge of ALL the settings required by the ISP AND having your username and modem password (modem authentication passwords are not usually provided to the customer) Doing a "hard boot" will only return your modem to factory settings
Dec 21, 2012 | Comtrend CT-507 Router
I need to download the driver, where can I download the driver for COMTREND/CT-5071T for a Mac for free?
If you need to configure something on the router, hook to it via ethernet wire to configure it. the default ip address for the router is 192.168.1.1 You will need to assign a static IP address to your wired network card in the range of 192.168.1.x, I would static it to 192.168.1.10 Then after you have staticed your IP address, use a browser to navigate to 192.168.1.1 the default user/password for the router is: username:root
password:12345
You should be able to change any settings then that you need to. Also, any firmware updates you would need should be provided by your ISP.
Apr 29, 2010 | Comtrend CT-507 Router
I cant find my wep key for my ct-5071t
look under it failing that go to the adresss at the bottom of it and put a new one in
Mar 12, 2010 | Comtrend CT-507 Router
Router no longer working since new modem was installed. Modem works and can access internet when connected directly to pc. comtrend ct-5071t connected to a linksys router
Reboot the router so that it can get a new dhcp lease.
If you can't login to the router to reboot it, just unplug the power for about a minute, then plug it back in.
If that doesn't work you will need to be able to login to the router to fix it. Depending on your internet supplier, you may have to set the router to login to the router.
Good Luck!
Jan 24, 2010 | Linksys BEFSX41 Router (DHBEFSX41)
Ethernet link is acting up, have to re-book it a lot to keep it going. Comtrend 5071T Using the software to fix it doesn't seem to help, have to turn it off, unplug it and remove the ethernet cable a few...
hello , i would suggest changing your ethernet cord and as well performing a firmware update and any factory resets available whether it be software or a physical push button on the back of the device.
Sep 30, 2009 | Comtrend CT-507 Router
DSL connection
This could even be the Dsl modem loosing internet sync, They will tell you its you're end and thats fine check the modem, it also could be the ethernet cards going into standby Thus turning off the wake on lan feature in bios or other software would provent the card from going to sleep.
Jun 26, 2009 | Dell Ethernet Card Network Adapter
Computers & Internet Logo
316 people viewed this question
David Payne
David Payne
