Question about General Electric GTS18ICSR Top Freezer Commercial Refrigerator
GE refrigerator compressor "klunks" when the compressor cycles off. Otherwise it seems to run normal. What could be the problem?
    Guru:
  • 1,524 Answers
Broken internal motor mounts.
Posted on Jul 06, 2010
My ge profile refrigerator makes popping sound for about 3 minutes before the compressor starts. This happens almost every 8 hrs.
You may be hearing ice or water dripping on the defrost heater, which would be normal operation if the refrigerator is operating okay, otherwise.
Sep 16, 2014 | GE Profile 26.6 cu. ft. Side-by-Side...
Have a GE TFX25JR/TFT25JR refrigeratorfreezer fan runs forever
Look inside the fresh food compartment and behind the control panel and there should be a defrost timer. Part number WR9X489 and that is the only reason that I can think of that would keep the fan running all the time. What I think is the contacts that normally open to let the freezer defrost are fused or welded themselves together. If compressor cycles and temperatures are OK (safe) that leads me to that needing replaced. I will look for the wiring diagram for your model but have found it hard to really get those answers from GE. But most timers are universal as long as the time of defrost and hours between are correct, Let me know, Thanks Sea Breeze
Apr 22, 2010 | GE 25.2 cu. ft. Side-by-Side Refrigerator...
GE Profile Refrigerator defrost cycle last hours
it;s probably not going through the defrost cycle or its getting stuck in defrost .. on the back of frig the is a metal cover plate . in side you will find the main board . replace it . it runs the compressor and defrost and controls tempt . this is a very common problem . the new boards are better . and they cost a litle more . mm hope this helped / feed back pls .
Feb 03, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Long run time between defrost cycles
You have a broken defrost part. Either the heater, t-stat or timer. The longer you let it go without repairing it, the more parts is take out.
Aug 13, 2009 | Kenmore 56176
Kenmore Coldspot 69182990 - knocking noise
check te rubber mounts at the bottom of the compressor
the rubber rots after some time and the compressor moves on shutting down as the knocking could be that noise
May 20, 2017 | Kenmore Refrigerators
Small frig stopped
are you sure the compressor is running or is it just humming trying to start then clicking out on the overload, if so you have a 50\50 shot of the relay being bad, otherwise the compressor is shot
Jul 07, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE refridge temp control makes clicking noise
probably a few loose ends causing the rattle sounds it does it for most fridges.
May 11, 2009 | GE GTS22KBP Top Freezer Refrigerator
TFX24PRXBWW GE Profile Refrigerator - energy use?
I dont know how to locate these specs for you, modern refrigerators are much more efficient for a couple of reasons. Most new units have a Computer that controls the defrost cycle whereas older units have timers that defrost every 8 hours of on comp run time regardless of whether it needs defrosting. The new ADC (adaptive defrost control) can better monitor the frost on the coils to defrost less (in the defrost cycle it consumes 5x as many watts as when its cooling. Also most new refrigs, especially new GE units have much more efficient fan motors now also, however they too are computer controlled and when they fail they are expensive. Also the very high end new Counter depth models (in the $2500+ range) have a new variable speed compressor. This gives the compressor the ability to run at a low, med, and high speed, reducing even more the watts that will be drawn in normal operation when the fan motors are on low and the compressor too. If you have any other questions let me know ill be glad to advise.
P.S. Buy an extended warranty with any new appliance you purchase! Trust me!
Dec 05, 2007 | GE Profile PSW26P Stainless Steel Side by...
GE refrigerator
this may be water from the defrost cycle. if this drains to tray over compressor, check tray is not too full (water evaporates from heat of compressor) otherwise defrost water will go to a seperate container which may have a split or is overflowing. fault can also be caused by poor door seals which would produce too much ice on evaporator pipes
Mar 21, 2007 | GE GSS25JEMWW Side by Side
General Electric GTS18ICSR  Top Freezer Commercial Refrigerator Logo
71 people viewed this question
Top General Refrigerators Experts
John Tripp
John Tripp
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a General Refrigerator Expert? Answer questions, earn points and help others
