Question about RCA D52W23 52" HDTV CRT TV
I have a great picture but only shows red and blue also the glare screen needs to be fixed, Is this something I can do myself?
  • RCA Master
  • 8,617 Answers
Sounds like the Green CRT drive board is defective. You can get a CRT drive board from www.tvrepairworld.com you can also get the replacement screen assembly there also.
Posted on Jul 06, 2010
Blue glare on screen, need to know how to fix the problem or adjust tv to it's normal settings on color tones.
Hello cuellarlori,
Welcome and thank you for using Fixya!
You need to have your Red Drive jet checked, repaired (if possible), or replaced.
Have a great evening!
Sep 09, 2011 | Philips Magnavox 9P6034C 60" Rear...
Tv works but has red glare on screen
You have contamiated fluild in red tube remove old projection fluild and put in New this should then give you a clear picture. call Mats for projection fluild 1-800-628-1118
Sep 18, 2009 | Televison & Video
Double lettering on red when in 1080i good picture in 480p
This is a common problem. Your convergence has gone out.
Common symptoms are...
1) 3D Video
2) Warped Video
3) Convergence menu does not adjust the red or blue correctly.
Go here for a solution...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Sep 06, 2009 | Philips 55PP9401 55" Rear Projection...
Samsung CRT HDTV - Red, Blue, but No Green.
If their is no green chances are the chip for RGB on the tubebase has packed up its usually something like a TDA 6107Q
Jul 06, 2009 | Samsung TXJ3676 36" TV
Picture is in 3d and green red blue
replace Both of your convergence ICs They are big black chips will have STK# on them also in same circuit there will be two low ohm resistors that might be bad 2.7 ohms CK them .
Jun 03, 2009 | Samsung HLR5667W 56" Rear Projection HDTV
I have a red and blue shadow in my picture
i think you need a new convergence board they rin from about 88.00 to about 140.00
Sep 08, 2008 | Akai PT5598HD 55" Rear Projection...
IT sounds like it needs to be degaused.
Before checking this, check for speakers placed by the set. this will cause it too.
The best way to avoid this situation is
  1. Don't place unshielded speakers near the set.
  2. Don't move the set while it is turned on.
The coil that is used is about $50 and can sometimes be found at industrial electronics stores. It's called a degausing coil. most TVs have a version of this built in and mutiple power on/off/ons may fix it, but don't hold your breath...
The trick is to turn the coil on with it right up to the screen. Move the coil in a big circular motion parallel to the screen as you S-L-O-W-L-Y move away from the screen. when you are as far away as you can get [about ten feet] turn the coil off. Caution. KEEP HARD DRIVES, CREDIT CARDS, AND FLOPPY DRIVES AWAY from the energized coil!
Good luck
Ken
Aug 15, 2008 | Akai PT5598HD 55" Rear Projection...
Picture Color
http://www.partstore.com/ModelDetai...close=1&exact=1
What do you think "CRT ASSY, Projection: Blue" might be?
CRT ASSY, PROJECTION: BLUE
RCA Part Number: 258486
RCA Model: D52W20
52" CRT BLUE P16LTG00BMB, DELTA 250
They want $183,
Jan 08, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
FADING TO BLUE SCREEN
Sounds like you have a problem with the blue gun in your picture tube or its drive circuit. You might remove the back cover and gently tap on the neck of the picture tube using a plastic screwdriver handle while watching the screen in a mirrow. If the picture flashes back on or on and off then the picture tube is the problem. If this is a projection tv you have three separate tubes : red, green & blue. you'd need to tap the blut one.Gently!!!! Stargazer
Feb 13, 2007 | Sony KP-53HS20 TV
Picture background is Red Sony KP-57wv700
Is it a reddish tint or the picture is just red? Did it just happened, or you are just noticing a gradual change? Reddish tint: Blue and/or green CRTs are getting weaker. More likely the green CRT. Unplug the unit and somehow remove the back cover, etc. to get a direct view of the CRTs. Use a flashlight to inspect each CRT through its lens. CRTs with excessive wear will show a definite "burn" mark where the picture forms. Compare the center CRT (green) with the other ones. Normal wear in all three tubes is expected. What is important is to notice the difference. A significant wear in one means it has to be replaced, but usually all three have to be replaced in order to get the right purity. This is a major overhaul, and unless the TV has a sentimental value, it's not worth it. Picture just red: Green and blue CRTs not firing. This is easily observed by running the TV with the back cover removed. Probably a loose connection, but you will need the manual to trace it. You could gently tap the chassis while the TV is running and see if this restores the blue and green CRTs.
Sep 28, 2006 | Sony KP-57WV700 57" Rear Projection HDTV
RCA D52W23 52" HDTV CRT TV Logo
100 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
