Question about Poulan Pro PP4620AVX 46cc Gas Chainsaw With 20" Bar
Is there a picture of part placement? gas is leaking
    Brigadier General:
  • 4,088 Answers
Check the fuel lines for decay or other damage. Make sure that none of the lines have been replaced with plastic--use only the original rubber type. Check the carburetor fasteners for tightness. If the fuel seems to leaking from the case, you may have a cracked tank. If so, replace the tank as no glue or epoxy will provide a permanent repair. Check the fuel filter, air cleaner and muffler for plugging. Good luck!
Posted on Jul 11, 2010
Water softener leaks
check if in proper placement or replace O ring gasket if damaged or worn
Sep 22, 2016 | Kenmore 300 Series Water Softener
I have mislaid the instructions for my Genesis Miami gas fire, and need to relay the ceramic logs. can anyone please help?
This will depend on whether the fireplace is vented or is vent-free. Vent-free gas fireplaces are sold as a kit with the valve, burner, media (logs, glass, shapes, etc) all designed for a particular placement to work together to reduce dangerous chemicals. A vent-free burner and valve cannot have the logs removed and replaced with some other type of ceramic gas log because the exact placement of the logs is designed around the ports in the burner where the flames rise to minimize carbon created from the flames touching the logs.
If your fireplace is vented then the pull of the flue will remove dangerous fumes created by the same placement so there are no rules about re-arranging or replacing "media". If the fireplace is vented then you could use other log-placement-guides to identify the type of log and where it belongs with little worry because vented logs are designed to be able to have some adjustment anyway.
If vent-free and without a manual, an educated technician should do this for you because the BTU setting on the valve must be compared to the types of burners, port placement, size of ports, amount of ports and flame height. After this examination, someone familiar with the various hidden "tongue-and-groove" etchings in different types of gas logs can figure-out where to place the logs. They may have to test the fireplace burning once or twice to get it exactly correct but once you understand the idea of how a vent-free gas log diminishes the carbon-output of the amount of gas flowing through the burners then it is only a matter of watching the flames to see where the logs could be and comparing the size and layout of the logs to find the best fit.
Feb 02, 2014 | Grilling
Cylinder 5 placement?
if you have the V8 gas engine, the cylinders on the passenger side from front to back are #1 #2 #3 #4 the cylinders on the driver side are from front to back #5 #6 #7 #8. if you have a V6 gas engine the cylinder placement is passenger side from front to back #1 #3 #5 the cylinders on the drivers side are from front to back #2 #4 #6. if you have a diesel V8 engine the cylinder placement is passenger side from front to back #1 #3 #5 #7 drivers side from front to back #2 #4 #6 #8 and last but not least if you have the V10 the cylinder placement is passenger side from front to back #1 #2 #3 #4 #5 and driver side from front to back #6 #7 #8 #9 #10.
Dec 24, 2010 | 2001 Lincoln Town Car
Coal placement for Kingsdale Fires
google kingsdale gas fires you can down load a manual from there wed site
Apr 21, 2010 | Heating & Cooling
The spring placement for the trigger replacement
Look at the old trigger and see where the spring has been rubbing. Place the spring around the trigger post and slide it into the trigger housing. With help of a small screw driver or scribe to flip the trailing end of the spring over the stop post in the housing. Hope this helps
Sep 04, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
I dont know what year my gasgas is
hi liamryan,
post a picture of you bike in the site for good comparison. usually bike differ in placements of parts and frame, we will be able to know what year model your bike came out, just post a picture of it here.
Aug 08, 2009 | 2003 Gas Gas SM 250
I need a picture of a fuse box cover for a 1991 acura integra ls
If no-one supplies you a picture you could start your vehicle and switch everything on,remove 1 fuse at a time and see what stops working.Write down on piece of paper and you have your own fuse placement.Could also go to car wreckers and write down placement or just buy one.Good luck
Dec 28, 2008 | 1991 Acura Integra Hatchback
Poulan Pro PP4620AVX 46cc Gas Chainsaw With 20" Bar Logo
109 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
