Question about Coby CAM5001BLK 2" TFT LCD Snapp HD Camcorder (Black)
Why does this unit not take a full charge and indicates low battery and shuts down when you attemot to record in hd ?
  • 3,083 Answers
The battery in it is going bad, or not charging due to oxidized contacts or faulty wiring. When it goes into HD mode, it requires a full voltage, and at least one cell may not be holding charge. You'll have to replace the battery, most likely, unless the charger or charger wire is bad.
Posted on Jul 06, 2010
Hi we have just bought a Disability scooter and when using the battery indicator is moving from right to left - full charge to low charge is this normal?
Yes that is normal. As you move, the meter shows the amount of voltage being drawn down. If it drops too low or doesn't recover to the full right side, its a clue that it needs charged or the batteries are too low and should be replaced.
Sep 18, 2014 | Health & Beauty
The volt gauge reads 14 volts when the truck is running (2004 Chevy 2500 HD, 6 Liter) after I shut it off Voltage gauge reads 9 volts as low as the gauge goes. The starter acts like it is not getting...
14 volts is close (14.5-14.8 volts is required
and 9 when shut down indicates a bad battery
have it load tested and then have the alternator tested for rectifier pack operation
there should be 14.5 volts DC at the battery when running or it is not charging the battery
if you have 14 volts AC replace the alternator with a serviceable unit
Aug 08, 2017 | 2004 Chevrolet Silverado 2500HD
For christmas i was given a Bush HD pocket camcorder 9909, i've just put new batteries in but the camera shuts down because of low battery even though they're new batteries. It is rather...
You need to fully charge your battery pack. When you buy new rechargeable batteries it has low or none charge at all.
Thanks for using fixya!
May 31, 2011 | Computers & Internet
Have a new Ultra HD Flip Video. How do I know when it is fully charged? Does the red light go off or what?
Hello there,
The Flip Ultra should have a rechargeable AA battery pack.
To verify it is charging, the battery icon will be flashing lightning bolt. The red light goes from red to green the moment it is fully charged. It takes six hours before it gets a full charge via the USB.
Please let me know if this gave you enough information. Thank you for using FixYa.
Oct 08, 2010 | Pure Digital Flip Video Ultra Camcorder
Unit shuts down after about one minute.
When you leave a Nuvi on a charger for several hours and don't see full green bars, this is an indication that the battery is defective. Most Nuvi batteries last about 2 years. Most of the batteries have a date code of 2007. I would have the battery replaced as soon as possible as it can bloat and crack the case open. More info can be found here:
http://www.sharc.net/gps_battery_repair.htm
- Jim
Jun 01, 2010 | Garmin Nuvi 660 GPS Receiver
Garmin 260 now failing to charge and shuts itself down
If the unit is only a year old? then I would suspect that the charger has a problem that has damaged your battery. Do you use an external power continuously?
Try a different charger or if you have a meter make sure the charger is putting out close to the specs on it. Try using the usb cable to charge it.
The low battery and shutting off are typical of a battery that won't/can't hold a charge. That is typical after 2-3 years plus but not one year. It can also be indicitive of the charging circuit needing to be reset. The problem is it needs to be started and run long enough for it to recognize the reset command. To do this, hold your finger on the bottom right corner of the screen while powering the unit, until it asks if you want to reset it. That might get you running.
While I would be suprised at the battery going out within a year or so it is not unheard of. You may have to replace the internal battery pack. The unit is new enough your only source is probablly going to be Garmin. They might replace the battery under warrenty or out (if you talk nice).
Jul 24, 2009 | Garmin nuvi 205 GPS Receiver
Flip Mino HD will not boot, charge or reset
Call Flip support, problems are happening to too many people, contact Flip support, if they cannot help, contact MacWorld or other online reviewers and let them know.
Jul 06, 2009 | Pure Digital Flip Mino Digital Camera
Battery Low indicator and Camera shuts Down
What brand of memory card are you using? Sandisc, Toshiba and Panasonic are the only ones that really work with the cameras. If using one of those trying resetting the camera.
Menu
go to setup
go up to reset
press right arrow
highlight reset
press set
If that doesn't work....Send it into repairs and they will send you an estimate on what it would cost to fix it. Give them a call at 800-706-2534 option 2.
Nov 18, 2007 | Casio EXILIM ZOOM EX-Z60 Digital Camera
False battery power alarm shut down
Ive had a look at the manufacturer web site but ther doesn't seem to be any driver for your model. You should be able to turn the battery warning alarm off in the management settings
Feb 03, 2007 | Balance CN6555 Notebook
Low Battery when using screen
cudgegong said in another forum:
To resolve the annoying "change the batteries" problem. Goto menu, choose yellow menu, select
file No. reset to ON. Turn camera off and back on.
Voila fixed.
Oct 21, 2006 | Canon PowerShot G2 Digital Camera
Coby CAM5001BLK 2" TFT LCD Snapp HD Camcorder (Black) Logo
113 people viewed this question
Top Coby Video Cameras Experts
Andrew Taylor
Andrew Taylor
Pamela Leach
Pamela Leach
Are you a Coby Video Camera Expert? Answer questions, earn points and help others
