Question about Frigidaire FRS26R4A Side by Side Refrigerator
Refrigerator not cold enough
The refrigerator section of my side-by-side is not cold enough. The freezer is fine. The fan seems to be running fine. The freezer is certainly cold enough. Could you help me? FR23F4CW0 I listed below the closest number I could find that would match our Model #
SOURCE: Condensation on refrigerator front btwn top freezer and refrigerator doors
I have the same problem with my frig in the basement. I get condensation and resulting mold on the top outer surface and related areas. This is from the surface being cold, with resulting outside moist air condensing on the cold surface. Best solution - spray/wipe the surface with a bleach and water solution, let it soak a few minutes, then wipe off with a rag. Add a drop of dishwasher soap to a mixture of roughly 4 parts water to one part bleach. Repeat if necessary. Do this as often as the problem seems to creep up again. Good luck!
Handyman in NJ
Posted on Oct 11, 2008
SOURCE: Kenmore refrigerator model 253 not getting cold
i have the same problem: botttom of refrigerator does not cool.
freezer working ok.
Posted on Mar 18, 2009
  • 3 Answers
SOURCE: the refrigerator is not getting or staying cold enough. the freezer seems to working ok
Check the vent at the top of the shared refrigerator wall for cold air from the freezer. If not, then you can either replace the motorized flap inside the vent or prop the flap open with a stick or something. The manual solution won't harm anything. The motorized flap is an over-engineered solution designed to create service calls. :<)
Posted on May 21, 2009
  • 3741 Answers
SOURCE: The freezer is cold and keeps things frozen, but
This can occur because of any of the 2 possibilities given below: 1) if the timer is faulty it will clog the air vents with ice and not defrost them at all so no air passes to the refrigerator section to cool it.
To solve this problem getting the timer replaced should solve the issue.Timer costs approx 35 dollars.
2)Refrigerator air vents may be clogged by some other foriegn particles and blocking the cold air to reach
To solve this you need to manually clean the clogged airvents and pipes.also try defrosting your unit for aprox 18 hours.It should help in solving the issue to particular extent too.
keep us updated .thanks for using fixya.
Posted on Aug 28, 2009
BMT60
  • 126 Answers
SOURCE: Both the freezer section and refrigerator stopped
YOUR REF. MAY BE STUCK IN DEFROST. IN THE CEILING OF YOUR REF. THERE IS A CONTROL HOUSING. THERE IS AN ACCESS HOLE ABOUT 6 INCHES BACK MORE OR LESS IN THAT AREA. INSIDE THIS HOLE IS A ROUND GREY, BLACK OR RED PIECE THAT CAN BE TURNED IN ONE DIRECTION WITH A FLAT BLADE SCREW DRIVER. TURN IT. IF IT STARTS YOU WILL NEED A DEFROST TIMER. NEED MORE HELP JUST ASK.
http://www.searspartsdirect.com/partsdirect/index.action
Posted on Apr 25, 2010
I have model number PDE18LZRBB. Freezer works fine; refrigerator section will not cool properly.
Your problem is usually caused by poor air circulation. The only way the refrig section gets cold is from the fan in the freezer blowing cold air into the refrig section. The fan should be behind the back wall of the freezer and should be running at the same time the complete refrigerator is running. No fan run---no cold in the fresh food section.
Apr 01, 2015 | GE Refrigerators
Freezer side not cold enough, similar temperature as Refrigerator side
It could be many things. My first guess would be the defrost. The coil that gets cold in your freezer builds ice on it and the only way to get the ice off is to run a heater near the coil long enough for the ice to melt. All freezers have something built in to defrost and domestic are typically just an electric heater on a timer. When your freezer stops working again, you may want to pull open the panel of your freezer and see if your coil (a heat exchanger that probably looks a lot like your car radiator) is covered in ice. If it is, it could be the timer or the actual heater that is bad.
Nov 12, 2013 | Refrigerators
Usually when this happens it is because of a problem with the fan that moves cold air from the freezer section of your unit to the refrigerator section. Either the fan has gone bad or the unit has frosted up to the point of stopping the fan. Try defrosting (unplugging) the unit over night and then check it to see if the fan runs. If not then replace the fan. If it runs and then stops after awhile like days or even a few weeks, then you may need a defrost timer.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Nov 26, 2009 | Maytag Performa PAV2200
The food and drinks in the refrigerator does not feel and taste cold enough. The freezer is just fine.
Check for proper operation of the freezer fan. This fan moves cold air from the freezer to the refrigerator. If the fan is not turning, the freezer will be too cold and the refrigerator will not be cold enough.
The fan should be behind an access plate at the rear of the freezer. Listen for the sound of the fan. If you can't hear it, remove the cover and look at the fan. If it's not turning, you will need to replace the fan motor.
Oct 15, 2009 | Maytag MZD2766GES Side by Side...
Upper section of refrig. not cooloing. Remainder
check to make sure the freezer fan is turning. This should be inside the freezer unit at the top. It is probably behind an access panel.
If this fan is not turning, not enough cold air will move to the refrigerator side to keep it cold enough. If the fan has died, it will have to be replaced.
Oct 12, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer is cold but not keeping icecream frozen.
If, the fresh food section is 34- 38 degrees, then the freezer should be cold enough to keep ice cream solid. All of the cooling capability comes from the freezer section. I, personally, would not waste time or money on a ten year old box. Ten years ago it cost $1000, so, the outlay is $100 per year. Dump the old refrigerator and get a new one.
Aug 27, 2009 | Refrigerators
Freezer cold /refrigator warm . we have a side by side unit a couple of years old the freezer seems to work fine but the refrigator is warm .It don,t seem to make any funny noises and the back is clean
When the compressor is running, if the fan by the compressor and the fan inside the freezer are both running, and there is no frost on the back wall of the freezer (if there was frost would indicate a defrost issue) then check the air dampener. It is located at the very top left back side of the fresh food section. If it is not opening up, no air will flow from the freezer compartment (where all the cooling takes place) into the refrigerator section.
Jul 04, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge side by side not cold enough in fridge or freezer
if there is no frost build up in freezer section sounds like a refrigerant leak
Apr 14, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
My refigerator and freezer are not cooling enough
Is the fan in the freezer running?? Is there frost on back panel of freezer??
Oct 03, 2007 | Kenmore 50522 / 50524 Side by Side...
Frigidaire FRS26R4A Side by Side Refrigerator Logo
26 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
