Question about Tamiya America Tamiya 14044 Yamaha Virago Xv1000 Motorcycle 112
I have a 1997 Virago 1100 my headlight quit working. I checked it directly to the battery to make sure it works. It does. Is there a relay or switch interfering with power on the yellow wire?
Its your starter switch.Exercise it & wd40 it. Jake
Posted on Oct 09, 2010
Headlight does not come on
Check the light switch , wiring circuit for broken wires ,loose connection or corrosion or even a blown headlight bulb .
Sep 18, 2014 | Yamaha Xv1100 Virago Xv 1100 1989-1998...
1997 Honda VT 1100 C2 Shadow Sabre headlight not working
Hi, Anonymous if your headlight is not working, only one beam works, keeps burning out, blinking, dim or surges from bright to dim to bright the first thing you need to check is the headlight bulb for damaged filaments then check your light circuit fuse, then check your head light bulb socket ground wire for a clean tight connection, that being said the usual suspects are:
1. Faulty ground or power supply wire to headlight bulb socket.
2. Worn down solder contacts or loose fit of the bulb base in the socket due to vibration.
3. Worn, chaffed, or broken wires in the light circuit.
4. Corroded, broken, or loose pins/sockets in wire connectors.
5. Faulty hi/lo beam switch.
6. Faulty ignition switch.
7. Fuse is good but no continuity on both sides.
8. Faulty headlight relay.
9. Faulty wiring between battery positive and headlight bulb socket.
10. Weak charging alternator/generator/lighting coil.
11. Faulty voltage regulator/rectifier ground or overcharging.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Headlight problem
Installing HID light on Honda Shadow
Honda shadow vt1100 Owners Workshop Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda VT1100C2 Owner Manual Page 3
Nov 24, 2013 | 1997 Honda VT 1100 C2 Shadow Sabre
1998 Honda CBR 1100 XX Super blackbird headlights not working
3. Worn, chafed, or broken wires in the light circuit.
5. Faulty hi/low beam switch.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Headlights are out need part of relay
Headlights not working CBR Forum Enthusiast forums for Honda CBR Owners
1997 1998 Honda CBR1100XX Service Repair Workshop Manual Download Download... $15
Honda 1998 CBR1100XX Owner Manual
Oct 22, 2017 | 1998 Honda CBR 1100 XX Super blackbird
1994 Virago 535 wont start, and the headlight wont turn on?
Hi, Anonymous and the usual suspects are:
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, needs to be 12.5 volts or better and be able to pass a load test if necessary, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Bank angle sensor tripped and ignition/light key switch not cycled to the "OFF" position and then back to the "ON" position.
5. Faulty ignition switch.
6. Faulty starter button.
7. Faulty kickstand or clutch pull in switch/sensor.
8. Security alarm needs a reset.
9. Starter control circuit, relay, or solenoid faulty.
10. Main fuse or circuit breaker may be blown or faulty.
11. Electric starter shaft pinion gear is not engaging or over-running starter clutch slipping.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
1987 Virago will not start
XV535 Won start
Yamaha XV 535 DX Virago Service Manual
OEM parts for Yamaha
http://www.starmotorcycles.com/assets/service/manuals/2000/LIT-11626-13-16_110.pdf
Jun 08, 2013 | 1988 Yamaha XV 535 Virago DX
Headlight keeps blowing out 1996 yamaha virago 1100
Hi, Anonymous if your headlight is not working, only one beam works, keeps burning out, blinking, or is dim the first thing you need to check is the headlight bulb for damaged filaments then check your light circuit fuse, then check your head light bulb socket ground wire for a clean tight connection, that being said the usual suspects are:
8. Faulty wiring between battery positive and headlight bulb socket.
9. Weak charging alternator/generator.
10. Faulty voltage regulator/rectifier ground or overcharging.
Headlight globes keep blowing
Yamaha Virago XV535 1100 1981 1994 Service Manual
Yamaha Virago XV1100K Owner Manual
Jul 22, 2012 | Yamaha Motorcycles
1995 yamaha virago 1100 headlight wont work
ViragoTechForum com
Headlight stopped working
Jul 13, 2012 | Yamaha Motorcycles
1998 Honda CBR 1100 XX Super Blackbird headlight intermittent
Hi, Kschatek if your headlight is not working, intermittent, only one beam works, keeps burning out, blinking, dim or surges from bright to dim to bright the first thing you need to check is the headlight bulb for damaged filaments then check your light circuit fuse, then check your head light bulb socket ground wire for a clean tight connection, that being said the usual suspects are:
Funny Head light relay CBR Forum Enthusiast forums for Honda CBR Owners
https://www.partsfish.com/page/oem-parts-for-honda
Jul 22, 2011 | 1998 Honda CBR 1100 XX Super blackbird
I have a 1997 Virago 1100 my headlight quit working. I checked it directly to the battery to make sure the headlight is good & it is. The fuse is good but no voltage coming out of headlight receptical....
did you check the ground were the light plugs into the wiring harness ?
strip the hot wire and check before the plug ... also may want to check ground on unpainted surface..
hope this helps
Oct 07, 2010 | Tamiya America Tamiya 14044 Yamaha Virago...
1997 jeep cherokee headlights quit working at the same time and will not come back on.
check the position of the automatic headlights switch. If it is placed in the auto position and the road becomes lit then the lights will go off automatically. Before condemning the switch try placing in it on the other positions. If the switch works fine, try checking the headlights relay, there are two relays (one is for the automatic headlights)
Apr 15, 2009 | 1997 Jeep Grand Cherokee
No power to headlight or headlight switch.
Hi, Dutchmen73 if your headlight is not working, keeps burning out, blinking, or is dim the first thing you need to check is the headlight bulb for damaged filaments then check your light circuit fuse, that being said the usual suspects are:
2. Worn, chaffed, or broken wires in the light circuit.
3. Corroded, broken, or loose pins/sockets in wire connectors.
4. Faulty hi/lo beam switch.
6. Fuse is good but no continuity on both sides.
7. Faulty wiring between battery positive and headlight bulb socket.
8. Weak charging alternator/generator.
9. Faulty voltage regulator/rectifier, overcharging.
Headlight has no power fuse does
Electrical fault 1982 Yamaha Virago 920J
http://www.starmotorcycles.com/assets/service/manuals/2005/LIT-11626-18-21_1000.pdf
Mar 16, 2009 | 1997 Yamaha XV 535 Virago DX
Tamiya America Tamiya 14044 Yamaha Virago Xv1000 Motorcycle 112 Logo
449 people viewed this question
Top Tamiya America Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Tamiya America Toy Expert? Answer questions, earn points and help others
