Question about Pioneer Televison & Video
My pioneer vsx-90txv is not wired/connected to devices right....some connections were moved around when I tried to hook-up my Wii.....arrggg...I have TV / SAT / DVD / Xbox / Wii / surround sound , ...I cant figure out the hook-ups...do I do the receiver, to TV, to arrggg? What sequence?
leethedeuce
  • 4472 Answers
SOURCE: I have a Samsung HLP5063.
Have you gone through your onkyo receivers setup manual. You will most likely need to adjust the settings on your Onkyo receiver. I also have an onkyo reciever and I have to assign the inputs to the video source. Being that you got sound out of the front speakes. I am assuming when you were playing out of the dvd player your reciever was only on stereo sound. Once I get feedback I can assist you further
Thanks,
Lee
Posted on Sep 28, 2008
SOURCE: Pioneer VSX-4900S Receiver Connections
I know this is an old post but run front speaker outputs to the inputs on the sub then from the sub to the front speakers. bam!! it should work
Posted on Oct 15, 2008
  • 25 Answers
SOURCE: help hooking up tv to surround sound system with dvd player
with my Ws-65513 I run only right and left channel down to the aux from there your dolby 5.1 should doe the rest .most systems have center (speech) (R.front) (Lfront)(R.rear)(L,rear) and SW .center you want on the bottom or the top of your screen ,The SW you want Ever behind your set or under your couch.LEFT AND RIGHT REAR YOU WANT SOME WHERE BEHIND YOU OR AT LEAST 90% TO WHERE YOUR SITTING NOW THE FURTHER YOU SET THE REARS BEHIND YOU THE MORE DELAY YOU SHOULD HAVE ,THERE IS AND ADJUSTMENT SOME WHERE BETWEEN 10-30 MIL-A-SECONDS THIS GIVES A SLIGHT ECHO FROM FRONT TO BACK..
i HAVE AN AIWA AMP RUNNING A 12INCH FISHER,CABINET BOSE,AND A PANASONIC SUROUND AS MY FRONT, LEFT AND RIGHT STACKS.WITH A JBL CABNET AND PANA CENTER FOR SPEACH .THEN LET THE REAR GET BOOSTED WITH THE PANA SUROUND SYSTEM BECUASE i NEEDED AT LEAST ANOTHER 120 WATTS TO RUN THE THE JBL12,WITH A PANA SUROUND AND A SUPER TWEET WITH A I/2 POUND MAGNET AS MY L AND R REAR,
THE ***** IS WHEN IM RUNNING MY LOWLY 44 DOLLOR PHILLPS WITH A SEMI 10801 ,I CANT GET MITS SPEAKERS ON LINE,THERE IS ONLY ONE INPUT.wHAT YOU REALY WANT TO DO IS HAVE NO DELAY ON THE CENTER,THEN 5MIL TO YOUR MIT SET SPEAKERS.YOU WILL GET AUTOMATICLY IF YOU SET THE TV ON SURROUND,PUT ONLY KEEP AT 1/4 VOLUME OR YOU WILL SCREW UP THE WHOLE EFFECT HAS THE JUICE GOES TO YOUR LEFT AND RIGHT FRONT IT NATRUALLY HAS ANOTHER 3-5 DELAY AND SET YOUR REARS TO A LEAST 20 TO 30 MILL DELAY.iT WILL PUT YOUR LOCAL THEATER TO SHAME.
Warning make sure all your wires are in phase +to possative -to neg not only you get a ping pong effect if you plan push a lot of watts a surge could make you have a very bad day ,most wires are eather colored on the outside or silver or gold on the inside.if you plan on moveing one side away from the compared to the other side its better to increase at the gauge of the wire,or you will never get the balance right and end up throwing your equipment at whatever pissed you off in th first place.
it,s a type of balance of chi ONCE YOU HAVE IT RIGHT,ANY ONE OR THING THAT ENTERS YOUR SPACE WILL NOT BOTHER YOU AS LONG AS TUBES CONVERGE AND SOUND IS
TUNED LIKE A FORK AND IF SOMEONE ***** WITH YOUR SYSTEM THE TUBE IS SO BIG
YOU CAN AT LEAST FIT ONE BODY IN IT ,i THINK THE CASTORS CAN AT LEAST STROLL YOUR PROBLEM TO THE LOCAL LAND FILL.
i KIDDING PUT i LOVE MY SET ,.i WOULD LIKE TO KNOW IF THE NEW BLUE RAY WOULD CLEAN UP THE 1080i ANY BETTER. GOOD LUCK
Posted on Feb 08, 2009
petraman7
  • 1175 Answers
SOURCE: No audio output from Pioneer VSX-D608 Receiver
If it's under warranty..get a new one.
It's an internal breakdown ...tech service only.
  • 53 Answers
SOURCE: hdtv checkboard pattern and/or green tint...
that's definitely a faulty mains board.
Posted on Apr 23, 2009
Please tell me how to hook up my Wii and my cd player and my dvd player to Pioneer VSX-D309 receiver
Greetings and good health to you.
Ok, so on the back of the unit there should be labeled connections, AUX, DVD, etc. These will be your inputs.
If your Wii has RCA connectors (the plug like ends that are usually Red, White & Yellow) then you would connect the Red plug to the AUX right speaker input. The White plug to the AUX left speaker input. If you want to run the video through the unit to the TV, then you would plug the Yellow plug to the AUX video input. If not, the yellow plug with go straight to the TV. If you are using HDMI from you Wii, then you would plug that into one of your HDMI inputs.
You will do the same for CD player but using the inputs labeled CD or whatever you have available. You can use any of these inputs for any of your devices it just helps to know what is connected where.
The DVD player may be a different story. Depending on what type of connection you are using from the DVD player will depend on where you plug it in. If they are red, white and yellow...then follow as above. If they are red & white on half the cable and blue, green and red on the other, you will plug the red & white ones that are close together into the red and white audio inputs under the DVD labeled connections. Then the other 3 will go into their matching colored inputs. If the connection from the DVD player is HDMI, that will go into a HDMI slot.
Finally, connect the unit to the TV. Keep in mind that if you are using any HDMI inputs, you will need to connect the unit to the TV via a HDMI cable.
Hope that helps.
Nov 05, 2015 | Pioneer VSX-D307 Receiver
Im having trouble hooking up my equalizer to my Pioneer audio/video multichannel receiver vsx-814
Looking at the back..bottom right corner is CDR/Tape in and out. Connect the in on the eq to the out of CDR/tape, connect the out of the eq to the in of CDR/tape.
You should then be able to use the CDR/tape monitor button to switch the equalizer in and out.
Sep 25, 2014 | Pioneer Audio Players & Recorders
How do i connect a sub wooferto my reciever
I own 2 of these Pioneer VSX-D903S units.
The only way to hook a powered subwoofer up to a VSX-D903S is if your subwoofer is equipped with amplified/speaker level terminals on the back, in addition to the line-level input. If you only have a line-level input, do not attempt to hook it up to this receiver.
If you're lucky, and have speaker-level inputs on your powered subwoofer, you would use the amplified terminals (connect to B-channel on the receiver). DO NOT connect anything to the line-level connection.
Alternatively, you could build two unpowered subwoofers, then set the receiver's Impedance switch to LOW, then connect one enclosure to each of the "B-channel" outputs. Connect your regular left and right speakers to their corresponding "A-channel" outputs. [Impedance range: 4 Ohm minimum, 16 Ohm Maximum]
Jul 20, 2012 | Pioneer VSX-D903S Receiver
Nead a remote and book and where do i plug my computer in vsx-90txv 7.11080p elite pioneer how much and where do i get it
Your PC can be connected like any other digital or analog audio source within its sound connection capabilities to any compatible input on the VSX. Just make sure you enable the PC's audio outputs and raise the volume.
Apr 08, 2011 | Pioneer VSX-90TXV Receiver
Where do my subwoofer speaker wires get hooked up to on the back of the reciver vsx-815 ??
Hi there, the Pioneer VSX-815 amplifier only feeds out a mono LINE LEVEL output with the subwoofer signal. Therefore you would need to connect the SUB PREOUT jack at the rear of the unit to the "line level input" on a self-powered subwoofer. Hope this helps.. Cheers, Yusuf
Nov 12, 2010 | Pioneer VSX-815-K Receiver
Analog is cutting in and out while channel isn't being changed. Also, channels in analog have no sound at all. I tried to switch signal select to auto and the problem continues. what should I try next?
If you're only using analog audio, switch the signal selection to manual or analog.
If the source(s) that do this are primarily digital and they experience any problems the unit will want to dynamically switch to its analog path. If there's no analog path connected from the same device(s) you'll get silence every time it switches to analog. Observe the display when the problem occurs.
May 30, 2010 | Pioneer VSX-90TXV Receiver
I have a pioneer 1080 receiver. it turns on but no sound
Could be in protect! Possibly a channel is out and won't let the unit turn on. Is this the picture of model or is it the older SX-1080?
Apr 13, 2010 | Pioneer VSX-90TXV Receiver
SPEAKER CONNECTION
problem with connection
Jan 07, 2008 | Audio Players & Recorders
Elite VSX-90TXV AV Receiver Installation w/surround sound & Plasma TV & DVD
Elite might have one or more wiring diagrams you could take advantage of.
Aug 22, 2017 | Audio Players & Recorders
Televison & Video Logo
Top Pioneer Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
