Question about Dryers
Maytag Neptune Gas Dryer MDG 5500Aww Dryer runs and heats when cold, then after about 5 minutes the flame cuts off, after a few minutews, the ingiter glows red, but the flame does not come on again unless it is cold... Belt is tight. Any ideas? Thank you for your help, mb
    President:
  • 1,796 Answers
Hi!!
I seems like you have a plugged up filter and/or an obstruccion in the exhaust hose/pipe.
Remove and clean lint filter, also remove exhaust hose/pipe from back of dryer and remove any lint accumulated. Check also the exhaust hole in the dryer.
Don't forget to rate this post. Good Luck!!
Posted on Jul 06, 2010
Can my Magtage Neptune MDG 5500AWW dryer be convered from gas to electric?
No but you can convert it from natural gas to propane gas and vise versa.
Sep 26, 2011 | Maytag Dryers
I have a Maytag Neptune model number MDG9700A gas dryer...When I first turn the dryer on the dryer will get hot for about minute then the gas turns off and will not heat up again...It glows fine after...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 01, 2011 | Maytag Neptune MDG9700A Gas Dryer
My neptune mdg 5500 dryer starts and runs but will not get hot
heatman101
Jul 10, 2011 | Maytag Neptune MDG5500AW Gas Dryer
When my mdg 6000bww is turn on heating element glows, flame ignites, then flames goes off within 5 minutes. After waiting approximately 15 to 20 minutes, until it seems to cool down can restart and goes...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 23, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Mdg 4000aww turns on and heats when started. runs for 5 five minutes then flame goes out. ignitor glows but no flame. one minute later dryer still running ignitor glows, no flame. this repaets until turned...
Either the venting needs cleaned or the coils on the gas valve are bad. Unhook the venting from the back of the unit and run. If works ok then clean venting. If you still have the problem, replace the two coils on top of the gas valve.
Sep 29, 2009 | Maytag Neptune MDG5500AW Gas Dryer
The glow plug just lights up but no flame on my maytag mdg 5500aww
If the ignitor is glowing but the gas does not light check the flame sensor. If it is OK then the gas valve coils may have to be replaced.
Aug 12, 2009 | Dryers
Maytag Neptune dryer MDG 7500Aw won't heat
Replace the glow bar ignitor.
Aug 04, 2009 | Maytag Dryers
Dryer runs but will not heat-vent and exhaust hoses appear clear.
Disconnect power from the dryer. Open the door and remove the 4 phillip screws from the inside lip of the door opening. Lift the door slightly and remove by sliding the hinge out from the slot on the cabinet. Grasp the front panel near the upper holes of the screw just removed. Twist from the inside out and pull away from the cabinet at the same time. Lift the front panel off of the bottom clips to gain access to the igniter. DO NOT touch the new ignitor surface as it is extremely fragile. The ignitor is attached by a single screw. Make sure the molex connector to new ignitor is secure.
Reverse the above procedure to reassemble.
Apr 25, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune MDG 5500 AWQ heats sporatically
your dryer has a safety feature that it will not run or heat when the door is opened. It is so no gas fumes are exhauseted into your home. Once the safety is engaged, It will not allow the dryer to restart for a short while. It should clear itself after only a few minutes. Hope this helps, good luck.
Apr 18, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Dryers Logo
149 people viewed this question
Top Dryers Experts
