Question about True 930208 SandwichSalad Food Prep Table 60 38 Long 2 Doors 16 Pans
Freezes up The cooler freezes up on a regular basis. I have cleaned the coils and had a tech put on a valve and recharged the freon. Still freezes over. Is it the thermostat?
    President:
  • 1,796 Answers
Hi!!
That sounds about right!! Make sure the thermostat's sensing tip is free of dirt and almost touching the evaporator coil.
Don't forget to rate this post!! Good Luck!!
Posted on Jul 06, 2010
What is the problem when an air conditioner begins to freeze up?
Freezing up is caused by
•dirty air filter or evaporator coil(indoor coil)
•dirty blower wheel or blower fan blades
•low freon
•weak or slow blower motor
If air filter and indoor coil are clean may be low on freon. Blower wheels seldom get dirty on window units. Pull unit from window and clean both coils with a water hose. Careful not to get any electrical wet. Let dry for a while and reinstall. If it continues to freeze its a freon problem most the time.
Jun 23, 2015 | Norpole 5000BTU Mechanical Window Air...
I have a roof top ac on my rv. its about 5 years old.it will run for a while then I can see ice on it.and the air flow stops..i cut it off and wait for a few hours and then cut it back on and it works...
Any reduced air flow though the coils will cause this as well. check for dirty coils and fins as well as your filter on the inside. Althogh it is not recommended and very rarely that one of these needs a re charge it can be done by a good AC repair person, They would have to open the lines and put in valves to accept a charge but like I said these usually don't leak similar to most window type ac units they are sealed from the factory.
Jul 05, 2011 | Dometic Rooftop RV Air Conditioner
I have the 8000 WKL Breezaire it has started to frost up over and over. I turn it off to melt and it starts to frost as soon as it starts to cool the wine room. Why?
IF THE BLOWER ON THE COLD SIDE IS NOT RUNNING THAT WOULD BE THE REASON WHY THE COIL FREEZES UP AND IT COULD BE DUE TO A BAD BLOWER CAPACITOR LOCATED ON THE BACK OF THE UNIT LEFT SIDE (SMALLEST OF THE TWO OVAL CANISTERS), BUT IF THE BLOWER IS RUNNING ON THE COLD SIDE IT MOST LIKELYIS A FREON LEAK, AND UNIT NEEDS TO BE RECHARGED WITH FREON AFTER REPAIRING THE LEAK.
Sep 27, 2010 | Breezaire WKL 4000 Wine Cooler
FREEZING UP AND BLOWING ONLY COOL AIR
Hi, when your unit starts to freeze-up on the indoor unit and on the suction copper line on the outdoor unit, this is due to a loss of freon. Because in your case, the air is not as cool as it should be or normally is. Some will ice up if the filter has not been changed on a regular basis, and the evaporator coil gets plugged with dirt. When it starts to ice over, you will loose 50% to 95% of your air flow. As long as you have good air flow, but not as cool with the ice ( you will loose some air flow if its been iced up for awhile ) you have a very small leak in the system and will need a recharge. They will normally leak at a place of least resistance like at the schradder valve where the freon is put in. If you have a older system, it may be in the evaporator coil. It depends on how much you have lost. You will need to call out a licensed tech to charge this unit. This is your problem indeed. Please keep me posted and informed on this. When you rate me, please be kind as I know you will. I thank you for this.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor.
Aug 02, 2010 | Heating & Cooling
Not cooling looked at inside behind filter and it is frozen
A frozen evaporator coil means one of two things, a lack of air flow or low refrigerant (freon).
Make sure the filter is clean and the coils are free of dust and dirt. If the unit blows good air (strong flow on high) when it first starts up and then freezes you are low on refrigerant and need to have it recharged.
Jul 21, 2010 | Goldstar Heating & Cooling
My Carrier PTAC Unit Model # 52cec309331rc freezes up continuously We have 79 of these units and for 21/2 years they have frozen up on a regular basis! the units are cleaned regularly, They are full of...
you have taken care of the compressor side but I am wondering if the problem in in the ductwork and filter side. An air restriction on the delivery side will also cause the unit to freeze up on a regular basis. I would have a peofessional come out and do a CFM test on the delivery of air through the duct work and past the filter and make sure the filter is the right medium for that unit. The filter medium you are using may have too much restriction for your setup.
Sep 16, 2009 | Carrier Heating & Cooling
Central air unit two part system, inside and outside. Freezes
If coils are clean and blower is working properly,
then you're probably low on freon.
Jun 09, 2009 | Goodman GMS90703BXA Heater
What causes my evaporator to freeze up
This can be caused by a few things.Check for a clean air filter. If the filter is dirty the air flow is slowed and lets ice form and over time the coils freeze over. The next thing to look for is a dirty evap coil. Same thing. if the coils are dirty the air flow is restricted and causing freeze ups. if this all looks ok then its time to call in the pro's. For environmental purposes all HVAC techs are citified to handel freon in the correct way. They will check the system for leaks and repair them followed by a freon recharge.
May 11, 2009 | Heating & Cooling
Unit freezes up.......Freon Leak?
Your AC unit is low on refrigerant. It should be recharged. be sure to keep the filter cleaned all the time as well. If this is an inexpensive unit, it may be cheaper just to get another one, since a lot of people would charge around $100. to charge it. hope this helps you, Rick
Apr 18, 2009 | Heating & Cooling
It keep freezing up!
First clean the unit entirely maiking sure the indoor coils and the exterior coils are free of dirt, debris or other obstructions.
Once the unit is dry and reassembled if it still freezes up then the freon level is low. If so, have a qualified A/C technician give you a quote on topping off the freon level. Some units that are older than 10 years are better off being replaced instead of recharged.
Jun 23, 2008 | Intertherm Heating & Cooling
True 930208 SandwichSalad Food Prep Table 60 38 Long 2 Doors 16 Pans Logo
318 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
christian nielsen
Are you a True Refrigerator Expert? Answer questions, earn points and help others
