Question about JVC HX-D7 Shelf System
DISPLAY READS PROTECT AND SHUTS OFF - JVC HX-D7 Shelf System
  • 4,737 Answers
This is related to several problems, but the main problem is with the audio connection.
1. First disconnect the power cord from the mains and unplug the audio cable. Leave it for few minutes while you follow the next step
2. First check the audio cords, if possible try with another, (don't connect the audio cable this time).
3. Turn down the volume and all the controls, now turn on the system. [I hope the system's ok this time] Connect the audio cables one by one, and find out which on is creating the problem. [if it displays the same message at the first connection, try the second after removing the first, don't connect one after another, do it one by one, means if one connection is made and you find no problem, then unplug it and do the next] If this doesn't help, you need to follow the next step. *I hope this will definitely help you find out the culprit*
4. You final option is to call a technician.
Good luck.
Thanks for using FixYa.
Posted on Jul 06, 2010
RCA drc200n dvd player turns on & reads disc but
divx(R) protect video dvd model no.E370
Jun 09, 2013 | Televison & Video
My kenwood kdc-mp2035 display reads protect. how can it be reset so it works again?
Mine started to do the same thing and they said it was going into a power save mode and that I would just have to replace it :(
Nov 19, 2012 | Kenwood KDC-MP2035 CD Player
The display just reads "protect"
Protect is bad. It means the amplifier thinks it is overloaded. Check the speaker wires to make sure there are no loose connections or shorts.
Mar 01, 2011 | Sharp CD-BA2600 CD Shelf System
I have no sound..display reads protect...then shuts off
The amplifier board is burnt and needs to be replaced
Jun 11, 2010 | Samsung HT-Z310T Theater System
XL-MP60 Shelf System: stereo shuts down and reads protect...
Hello, the problem of you stereo appliances been shut down was as result of a mechanism jam of the system.
The way you could do this is to open the back cover of the appliances and check for the rubber attached to the motor of the appliances, also check and see if you can adjust the mechanism if it is a disorder manner, it require a careful approach.
This will require a skilled personnel to handle this
May 17, 2010 | Sharp XL-MP60 Shelf System
I hava an accurain 5048,reciever sound shuts off,protector reads
as you have described the unit is in protect mode. disconnect all cable/wires to this unit. - and try again. if it is still in protect-a definate short within this unit.
Mar 06, 2010 | Audio Players & Recorders
Need help with HT-z410
When your home theater's display reads PROTECTION, it means the home theater is over heating and the unit will shut down to prevent any damage. This can happen if the unit is stacked along with other electronic devices or the unit is in an enclosed area that prevents the unit from cooling properly. To decrease the chance of overheating, relocate your home theater to a more open area.
If the home theater display reads PROTECTION every time you turn it on, no matter where or how the unit is placed, it needs service. To set up service call Samsung Customer Care at 1-800-SAMSUNG (1-800-726-7864). Have your model number and serial number on hand to set up service.
Jun 29, 2009 | Samsung HT-Z310T Theater System
Getting a "Protect" message in the display which then shuts down
The speaker wires were al little frayed, so I cut and stripped new 3/8" leads and when re-inserted the receiver worked fine. The problem was a short from the frayed wires touching either the back of the receiver or some other metal near the terminal.
Dec 06, 2008 | Sony STR-DE185 Receiver
Denon CD Receiver display reads "Protect"
Always be the audio amplifier Ic damaged and need to be replaced
Jul 18, 2008 | Audio Players & Recorders
MHC-GS100 Shelf system
to restart, press stop, clear and display at the same time.
Nov 21, 2007 | Sony MHC-GS100 CD Shelf System
JVC HX-D7 Shelf System Logo
172 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
