Question about Amana AP076E Portable Air Conditioner
Need window mounting kit for amanA ap076e - Amana AP076E Portable Air Conditioner
2 Suggested Answers
  • 82 Answers
SOURCE: Manual for Amana AP076E portable a/c
The manual is by Haier but you will see it is or the Amana AP76E. - http://service.haieramerica.com/documents/User%20Manual%20AP076E.pdf
Posted on May 11, 2010
Testimonial: "Great job!!"
I need a manual for portable A/C Technitrend TN09E
Stick it in a bowl of rice leave it overnight then take it to an iPhone repair place if the rice seams infective
May 15, 2014 | Amana AP076E Portable Air Conditioner
Doesn't get cold
be more descriptive there are several things that can cause it not to get cold.
Aug 31, 2012 | Amana AP076E Portable Air Conditioner
I am looking to convert my kenmore 970-c92062 ng dryer to lp.
The supplier of the LP gas can supply the needed parts for conversion.
Aug 09, 2017 | Amana Dryers
THE UNIT BLOWS COOL AIR OUT THE FRONT BUT HOT AIR OUT THE BACK THE MODEL IS aP076E .i DO NOT HAVE A MANUAL BUT IT DOES NOT SEEM TO BE REAL HARD TO RUN THANKS
Yes, that is the way a typical air conditioner works. The portable types need to have the hot discharge air direct outside via flexible hose and an adjustable window bracket. The window closes on the bracket to create a seal, and the hose connects between the air conditioner discharge and the opening in the bracket. This is called "venting". Most portable air conditioners include (or offer as an accessory) a "vent kit" or "window kit".
Some portable air conditioners do not provide a way to vent - fortunately yours appears to have a kit for this purpose. You may wish to check out this page on venting. It has plenty of ideas and suggestions for venting. This site has some very good pictures to document making a vent - and is worth a look, too.
If this was helpful, please rate it "4 thumbs up" - thanks!
Aug 02, 2011 | Amana Heating & Cooling
Hi, My husband and I recently purchased a couple thru wall/window air conditioners. We are planning on putting them in our windows, but they did not come with any mounting kits. We are having a hard...
Hello, you can purchase mounting kits at a local heating and cooling supply store. Here is a link to a online store that carries window kits http://www.apwagner.com/index.php?main_page=index&cPath=10_48
May 26, 2011 | Toyotomi Heating & Cooling
HOW DO I GET AN OWNERS MANUAL
Please check this link and see if you get the specs.
www.portableacguide.com/unit/?Amana-AP076E
Sep 26, 2010 | Amana AP076E Portable Air Conditioner
I have an amana self evaporating portable ac for my 500sf condo. I have had to unhook it and roll it outside 4 times to drain it. Lately water is now spilling out the back vent on to my floor. What's the...
It appears to me that because of the small size of your condo, you are just recirculating the humidity in the apartment. The unit is condensing the moisture in the air and then reheating it in the pan causing it to evaporate back into the air. The unit is working properly but the humidity level in your apartment continues to rise. You really need to add a drain from the pan of your portable air conditioner.
Jul 20, 2010 | Amana AP076E Portable Air Conditioner
Need instruction manuel for amana AP076E
ManualsLib has the manual here: https://www.manualslib.com/manual/5170/Amana-Ap076e.html . Click on the Download button and follow the instructions there if you do not want to go through the manual page by page.
I hope this helps.
Aug 29, 2017 | Amana AP076E Portable Air Conditioner
Amana Gas Dryer LG3912W When dryer is turned on ignitor glows for 5-10 seoonds, then shuts off. I don't hear any opening and closing of gas valve. Is it the gas valve solenoid? Also when dryer is tumbling...
Good day,
If your sure it is getting gas, then the problem is with the gas valve. There are 2 coils mounted on top of the gas valve and they are either shorted or open. In either case they need replace.
Simple job, just remove both wire connections, then the bracket is held on with one screw. Remove the bracket, and the coils will lift right off. Very common problem.
P.S. When purchasing the dual coil kit, if the Amana seems pricey, check with the counterman and ask for the Whirlpool kit. It's identical except for the part number.
The rollers are an obvious solution. You'll have to inspect them first. The belt tensioner is another item, and in rare cases the blower wheel attached to the motor.
Dec 16, 2009 | Amana ALG331RAW Gas Dryer
Amana AP076E Portable Air Conditioner Logo
89 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
