Maytag Bravos MTW600TQ0 top loading washing machine. The washing machine will begin the normal cycle (which water starts running, stops, lid locks) then it just hums. Occasionally it will run a full cycle if you try long enough starting and stopping and trying different cycles and different heat settings. We have unplugged and plugged back in numerous times for numerous amounts of time, checked all the hoses to make sure there are no kinks, no clogs. The machine will work perfectly in the spin cycle, with no issues. We replaced the control board which did not fix the issue. Eventually the LF code will come up if it sits long enough. We also replaced the outlet. I need help!
  • 12,061 Answers
Https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/45e6530dafa3e726852572c30065ca7e?OpenDocument
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/3fb1b0a63366238b852572c3006ea9ce?OpenDocument
Above are your service and repair manuals use these to troubleshoot and remedy your issue. Belwo is a DIY self help, How To, washer repair between these you should be able to work through the steps and arrive at a fix. http://www.washerhelp.co.uk/washing-machine-repairs.html
You need to look at the Inlet solenoid/Valve, this is most likely the problem, LF == Long Fill. IE: Machine's taking too long to fill up, suspect water, and inlet valves.
Posted on Jul 06, 2010
  • Lori Jul 06, 2010
    They guys looked at all the valves, but is there a way to test the valve?
Maytag Bravos Quiet Series 400: F01 Error code
maytag washer with error code F01 means a obstruction in a hose or tube, not a control panel issue like people say. How can I clear the small tube? see pics
Dec 08, 2016 | Maytag Washing Machines
How to run diagnostic
Maytag Bravos MTW6600T Top Load Washer Run ... - Fixya
www.fixya.com > ... > Maytag Bravos MTW6600T Top Load Washer
Maytag Bravos MTW6600T Top Load Washer, run diagnostic test cycle related issues. Get free help, solutions & advice from top Maytag experts.
Maytag Bravos MTW6600T Top Load Washer, run diagnostic test ccu related issues. Get free help, solutions & advice from top Maytag experts.
Maytag Bravos MTW6600T Top Load Washer Diagnostic ...
Dec 02, 2015 | Maytag Bravos MTW6600T Top Load Washer
Why does my washing machine unlock itself in mid-cycle?
Sorry but I think you will have to call the repairman on this one. Hope it is still in warranty.
May 25, 2015 | Maytag Bravos MTW6600T Top Load Washer
What is hd code????
Hi Peter, If I understand your question correctly, you are asking what the code "HD" means for your machine. I am unable to find the code "HD", however, here is a list of the codes for these Maytag models, perhaps one looks similar to "HD". Hopefully this answers your question!
Washer displaying code messages
- "LF" (Washer is taking too long to fill)
Check the following:
Are the water inlet hoses kinked or clogged?
Are the water inlet valve screens clear?
Press PAUSE/CANCEL to clear display.
- "Ld" (Washer is taking too long to drain water from the wash tub)
Is the drain hose kinked or clogged?
Is the drain hose installed properly? See "Connect the Drain Hose." Press PAUSE/CANCEL
to clear display.
- "uL" (Unbalanced Load)
If the load is unbalanced, the washer will display this code while running an imbalanced
load correction routine at the end of the wash cycle and before the final spin. If the code
remains and the wash cycle dial is flashing after the recovery routine has stopped, open
lid and redistribute the load. Close lid and press START.
- "oL" (Over Load)
Is the washer overloaded? The washer has attempted to fill and begin the wash cycle. If
the washer is overloaded, it will drain any water and detergent that was added during the
fill. To correct the overload, remove several items and add detergent. Close lid and press
START.
- "Sd" (Suds Detected)
Did you use regular detergent?
Regular or hand-washing detergents are not recommended for this washer. Use only High
Efficiency ("HE") detergent.
Did you add too much detergent?
Always measure detergent. Follow detergent manufacturer's directions.
If excessive suds are detected, the washer will display this code while running a suds
reduction correction routine at the end of the wash cycle. The suds reduction routine
removes extra suds and assures proper rinsing of your garments. If the code remains and
the wash cycle dial is flashing after the recovery routine has stopped, re-select your
desired cycle using cold water. Press START. Do not add detergent.
- "lid" (Lid Opened)
Is the lid open? Close the lid to clear the display. If the lid remains open for more than 10
minutes, water in the wash tub will drain.
- "HC" (Cold and Hot hoses switched)
This code will appear at the end of the wash cycle to indicate that the cold and hot water
inlet hoses are switched. See "Connect the Inlet Hoses."
- "dL" (Door/Lid cannot lock)
Indicates lid is not locked. Check for items caught in the lid keeping it from closing. Press
PAUSE/CANCEL once to clear the code.
- "dU" (Door/Lid cannot unlock)
Is there excessive weight on the lid, such as a basket of laundry? Excessive weight will
keep the lid from unlocking. Press PAUSE/CANCEL once to clear the code.
- "F##" code
Press PAUSE/CANCEL once to clear code. Press START. If code appears again, call for
service.
May 01, 2014 | Maytag Bravos MTW6600T Top Load Washer
Lid lock broken can I overide?
Washer not starting Cycle:
I would have to slam the washer lid before the washer recognized the lid was shut.
What I did to fix:
1. Ref the link below for Schematics
http://blog.kennyluong.com/Tricking-A-Maytag-Bravos-Washer/
2. Looking at the Lid Lock section of the Schematic:
Place a jumper between pins 2 and 3 of J15
This engages the 1st switch (Lid Lock) so, I don't have to slam the lid anymore
3. Since my Lock switch (2nd switch), which is engaged with a magnetic, is working, my work is done.
If you find that your machine is still not starting the cycle, you will need to
replace the Lid Lock mechanism or ref the above link for temp bypass.
Mar 30, 2014 | Maytag Bravos Top Load Washer
Maytag bravos x lid lock overide or bypass
dpthom's wife is the smartest woman on earth! :)
Feb 11, 2013 | Maytag Bravos Top Load Washer
Lid lock button is flashing and wont unlock
I u unplugged the machine and it stopped blinking, the lid unlocked but when I tried starting it again the same thing happened. I cleaned the contacts on the lock but that did not help.
Jan 08, 2013 | Maytag Bravos MTW6600T Top Load Washer
Washer won't run through a complete cycle-stops at 29 minutes
There is a service manual behind the control panel it will show you how to test the door locks. If might have a bad lock solenoid.
Aug 01, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Washing Machines Logo
42 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
